    Extension Migrator
    4 Posts 2 Posters 732 Views 2 Watching
    • Gus RG
      Gus R
      Anyone know if you use the extension migrator for let's say from 2022 to 2026 that it retains the old licensing in 2022? I've never used that plugin "migrator" before so I was wondering if anyone has first hand experience.
      Thanks.
      www.instagram.com/gusrobatto/
      www.facebook.com/gusrobatto
        All the Migrator does is copy the extensions from the Plugins folder of the older version and paste them into the new version. If you have outdated extensions, they may create errors when you start the new version of SketchUp again. As for the licensing of extentions, it depends on the extensions and how the licenses are managed. For extensions from SketchUcation, you should use the Sketchucation ExtensionStore to install your bundle of extensions. First install the latest version of the ExtensionStore. Doing that will ensure you get the latest versions of those extensions installed and that they will be installed correctly.
        Gus RG 1 Reply Last reply
        Reply Quote 2
        • Gus RG
          Gus R @Dave R
          @Dave-R OK, thanks, Dave. That's what I thought but wanted to be sure. Can't be too careful sometimes. Might take SU 2026 for a spin even though I'm still glued to SU 2022.
            I've been enjoying SU2026.
            1 Reply Last reply πŸ‘
