    Automatic Face Reverser 2025 - Alive or dead?
    3 Posts 3 Posters 291 Views 3 Watching
      kado
      Re: [Plugin] Automatic Face Reverser
      I have installed the latest version I can find but doesn't see to be functional in SKP2025.
      Does anyone have it running in 2025? If so what black voodoo magic did you invoke to make it work?
      Thanks in advance.
      Didier BurD 1 Reply Last reply Reply Quote 0
        It does work - it's in the right-click context-menu... but it is flaky in newer SUp versions - working but throwing errors in the Ruby Console.
        Have you tried https://sketchucation.com/pluginstore?pln=TIG_Click2flip
        Run it from the Extensions menu item and any reversed faces you clip on will be reversed...
        There are other more comprehensive tools like my https://sketchucation.com/pluginstore?pln=FixReversedFaceMaterials depending on your modeling and material application etc...
        • Didier BurD Offline
          Didier Bur @kado
          @kado
          Attached here is a rework of this old script.
          Unzip vbfr.zip and just put the RBE into your Plugins folder.
          Options are now available in the Tools menu, under the submenu "Automatic face reverser".
          Hope this helps.
          vbfr.zip
          DB
