    THEA RENDER & ANIMATOR CRASH
    6 Posts 3 Posters 1.0k Views 3 Watching
      taoklai
      I updated to the latest Animator and Lib Fredo, and when I click "render animation" in Thea v.4 I get an instant crash and bug splat. Anyone else have this problem? Any advice? Thank you.
      • fredo6F Offline
        Does it happen with any model ?
        T 1 Reply Last reply Reply Quote 0
          taoklai @fredo6
          @fredo6 Yes, I tried even with a simple cube spinning 360 degrees. I can render through Animator by selecting Thea but I loose the motion blur so I wanted to render from Thea interface but it crashes every time.
            tomasz
            Yes, something has changed. I will check why it is failing.
              tomasz
              @fredo6
              animator.api_dialog_clip_options() { |result| puts "OK" }
              USE SELECTION = false
              #<NoMethodError: undefined method `selection' for nil:NilClass>
              fredo6_animator/animatoranimal.rbe:204:in `animal_top_compute'
              fredo6_animator/animatoranimal.rbe:181:in `animal_compute_for_film'
              fredo6_animator/animatorclipmanager.rbe:3001:in `chain_compute'
              fredo6_animator/animatorclipmanager.rbe:1244:in `clip_compute_all'
              fredo6_animator/animatorclipmanager.rbe:977:in `clip_open'
              fredo6_animator/animatorclipmanager.rbe:2916:in `chain_set_film'
              fredo6_animator/animatordialogvideogeneration.rbe:619:in `assign_clip'
              fredo6_animator/animatordialogvideogeneration.rbe:602:in `build_list_clips'
              fredo6_animator/animatordialogvideogeneration.rbe:378:in `dialog_invoke'
              fredo6_animator/animatorapi.rbe:56:in `api_dialog_clip_options'
                tomasz
                As we have figured out the issue requires both Animator 4.5+ and Thea 4.0.1397+ update.
