    [Plugin] jf_get_dimensions.rb
    61 Posts 21 Posters 79.1k Views 21 Watching
      @laurenceau said:
      it doesn't work with 2018 version
      plugin .rb instead of .rbz
      It works just fine in SketchUp 2018.
      You can either install the RB file manually or get the RBZ version here and use Install Extension or better, install the Sketchucation Extension Store tool and use it to automatically install the plugins and extensions host here on Sketchucation.
      • dereiD
        derei
        [attachment=0:25dij2zt]<!-- ia0 -->Screenshot - 12_5_2017 , 4_11_42 AM.png<!-- ia0 -->[/attachment:25dij2zt]
        Can't seem to find the plugin in Extension Store... is still available, or was removed?
        DESIGNER AND ARTIST DEREI.UK
          It seems that Jim has removed most if not all of his plugins.
          • B
            bsfranza
            hi there together,
            is there a working version of the plugin? or any alternative? because it seems its still gone from the extension store and sketchucation store πŸ˜•
            V 1 Reply Last reply
              As I wrote back in April of last year, Jim has withdrawn his extensions and plugins and they aren't available anymore. Get Dimensions was a useful one for me but I've not seen a similar one by any other author.
                dedmin
                Here we go:
                [mod=:1m1nlxa4]Edited to remove the file. It is up to the original author to share their plugins and extensions.[/mod:1m1nlxa4]
                • I
                  iamblindtoo
                  Any upgrade on this?
                    What sort of upgrade are you wanting for a plugin that has been withdrawn and is not available?
                    • V
                      vasia7777
                      This is "GetDimentions" plugin modified by russian guy which does work well with SU2014Pro on WinXPSP3 with out "Bug repot" window after exiting of SU14.
                      It was founded on YouTube channel "Geometry of Comfort".
                      GetDimentions_by Geometry of Comfort _SU2014.zip
                      Another version (it may matchs for more newer SU) was published here:
                      https://community.sketchucation.com/post/1239480
                      • V
                        vasia7777 @bsfranza
                        @bsfranza
                        @bsfranza said in [Plugin] jf_get_dimensions.rb:
                        hi there together,
                        Is this one match you:
                        • 4 / 4
