    [Plugin] SectionByCamera (V0.2) - UPDATED 4 June 2012
    26 Posts 16 Posters 21.7k Views 16 Watching
      sepo
      Does this plugin work with SU 2014 and btw where is the plugin folder in SU 2014?
      • V Offline
        vidy
        Tested it... and it works like charm
        thank you pgarmyn for the update..
        regards,
        vd
        still so much to learn..
          pgarmyn
          Sorry doesn't work yet on SU 2014
          • mitcorbM Offline
            mitcorb
            @pgarmyn:
            From your first post- as edited: "Works with SKetchup 8 and 2014. NOT FOR Sketchup 2014 "
              pgarmyn
              @mitcorb said:
              @pgarmyn:
              sorry, correction : 8 and 2013
              Thanks mitcorb !
                rayc
                This looks like a great plugin and would be very useful for my workflow. When will it be updated for Sketchup 2016? Thanks.
                • F Offline
                  FlorinAp
                  This one doesn't work with SU 2023...!
                  Please somebody confirm.!
                    Dave R @FlorinAp
                    @FlorinAp reading through this thread, it hasn't worked for more than a decade. The author indicated that on 21 June, 2014. It would appear that the author has, for whatever reason, not continued to support it.
                    Didier BurD 1 Reply Last reply Reply Quote 0
                    • Didier BurD Offline
                      Didier Bur @Dave R
                      @Dave-R
                      I made it work with SU2023, there were 2 syntax errors with the Ruby version used at that time (2023). Try it with 2024/2025.
                      SectionByCam_v0.2.1.rbz
                      DB
                      F 1 Reply Last reply Reply Quote 0
                      • F Offline
                        FlorinAp @Didier Bur
                        @Didier-Bur Thank you for your effort, now it starts (no more error at start of SU), but it doesnt do what it is supposed to do, as it is described in the animation and description of the first post.
                        It only creates its own scene... and that's it, the shadow is the same...!
                        Edit: I dont know if it does matter, but i didnt test it in SU 2024 or 2025, but only in 2023.
                        I stopped at 2023, and there are many reasons not to go beyond until they fix many things that have been broken starting with 2024, among those being massive rgloader problems, many incompatibilities with extensions, and another one that i will not make it public.
                        • 2 / 2
