    [Plugin] SectionByCamera (V0.2) - UPDATED 4 June 2012
    26 Posts 16 Posters 22.2k Views 16 Watching
      methade
      This is my first post. And thank you for this great plugin. Its very very useful for me... Kind regards.
        methade
        Me again. I am testing the plugin but having difficulties with renderer maxwell fire. It seems its not working. Any help?. Thanks.
        • P
          pgarmyn
          Can't help that. Pbacot had the same experience (see above). I menshioned it in the description.
            sepo
            Does this plugin work with SU 2014 and btw where is the plugin folder in SU 2014?
            • V
              vidy
              Tested it... and it works like charm
              thank you pgarmyn for the update..
              regards,
              vd
              still so much to learn..
              • P
                pgarmyn
                Sorry doesn't work yet on SU 2014
                • mitcorbM
                  mitcorb
                  @pgarmyn:
                  From your first post- as edited: "Works with SKetchup 8 and 2014. NOT FOR Sketchup 2014 "
                  • P
                    pgarmyn
                    @mitcorb said:
                    @pgarmyn:
                    sorry, correction : 8 and 2013
                    Thanks mitcorb !
                      rayc
                      This looks like a great plugin and would be very useful for my workflow. When will it be updated for Sketchup 2016? Thanks.
                      • F
                        FlorinAp
                        This one doesn't work with SU 2023...!
                        Please somebody confirm.!
                        Dave RD 1 Reply Last reply
                          Dave R @FlorinAp
                          @FlorinAp reading through this thread, it hasn't worked for more than a decade. The author indicated that on 21 June, 2014. It would appear that the author has, for whatever reason, not continued to support it.
                          Didier BurD 1 Reply Last reply
                          • Didier BurD
                            Didier Bur @Dave R
                            @Dave-R
                            I made it work with SU2023, there were 2 syntax errors with the Ruby version used at that time (2023). Try it with 2024/2025.
                            SectionByCam_v0.2.1.rbz
                            DB
                            F 1 Reply Last reply
                            • F
                              FlorinAp @Didier Bur
                              @Didier-Bur Thank you for your effort, now it starts (no more error at start of SU), but it doesnt do what it is supposed to do, as it is described in the animation and description of the first post.
                              It only creates its own scene... and that's it, the shadow is the same...!
                              Edit: I dont know if it does matter, but i didnt test it in SU 2024 or 2025, but only in 2023.
                              I stopped at 2023, and there are many reasons not to go beyond until they fix many things that have been broken starting with 2024, among those being massive rgloader problems, many incompatibilities with extensions, and another one that i will not make it public.
                              • 2 / 2
