    [Plugin][$] ThruPaint - v2.9a - 21 Apr 26
    195 Posts 55 Posters 90.1k Views 55 Watching
      artformoney @artformoney
      @fredo6 I managed to solve the problem. I uninstalled Sketchup, then manually deleted all associated Sketchup folders from Program Files, AppData/Local and AppData/Roaming, rebooted, reinstalled everything and now it works properly.
      I was Incorrect. The problem is back. After restoring all my preferences and extensions it's no longer working again.
        @artformoney said in [Plugin][$] ThruPaint - v2.4a - 02 Apr 24:
        I finally actually solved the issue. For anyone else having this problem, the folder I needed to find was C:\Users...\AppData\Local\LIBFREDO6_DATA_Dir. I uninstalled my Fredo6 plugins including LibFredo then deleted that folder. Then reinstalled my extensions.
        *Adding some language below so maybe this post is more visible to search engines on this issue:
        ThruPaint window missing. ThruPaint window closes automatically. ThruPaint window disappears.
        Re: [Plugin][$] ThruPaint - v2.4a - 02 Apr 24
        Hi @fredo6 ,
        I had an issue with thruPaint with the object painter not working. I updated LibFredo and now I cant get the window to open, only the top bar when i hit TAB. Prior to updating LibFredo I had the option to activate ThruPaint when invoking the paint bucket tool twice, and my bet is that if I could reset to factory settings my issue would be solved, but without being able to open the window, I cant access the extension settings. My guess is that setting preference is stored in some AppData file somewhere and I need to delete it.
        I've tried uninstalling all Fredo extensions and LibFredo, then uninstalling LibFredo then the rest one by one, restarting Sketchup each time, but can't get it to work.
        (Sketchup 2024, Windows 11)
        • fredo6F
          NEW RELEASE: ThruPaint v2.5a - 18 Sep 24
          Requirements:
          • LibFredo6 14.6a
          ThruPaint 2.5a is a release including:
          • Faster display of the Material Browser dialog. After the first display in the model (necessary to check materials), the dialog is fatser to display.
          • Option to avoid display of the Material Browser when starting ThruPaint (except very first launch). You can always make the browser appear by clicking in the empty space or the deciated button in the palette.
          Home Page of ThruPaint for information and Download.
          Main post of this thread.
            miszcz
            Hi @fredo6 ,
            Recently, I've been having issues with ThruPaint. I purchased a new version, but it’s not working as expected. I'm encountering two errors: one when I double-click,
            Error: #<NoMethodError: undefined method []' for nil:NilClass> c:/users/szcze/appdata/roaming/sketchup/sketchup 2024/sketchup/plugins/fredo6_thrupaint/thrupaintmiro.rbe:1864:in _initial_calculate'
            c:/users/szcze/appdata/roaming/sketchup/sketchup 2024/sketchup/plugins/fredo6_thrupaint/thrupaintmiro.rbe:498:in continue_session' c:/users/szcze/appdata/roaming/sketchup/sketchup 2024/sketchup/plugins/fredo6_thrupaint/thrupainttool.rbe:3173:in miro_prepare_session'
            c:/users/szcze/appdata/roaming/sketchup/sketchup 2024/sketchup/plugins/fredo6_thrupaint/thrupainttool.rbe:3101:in start_painting' c:/users/szcze/appdata/roaming/sketchup/sketchup 2024/sketchup/plugins/fredo6_thrupaint/thrupainttool.rbe:2057:in handle_click_down'
            c:/users/szcze/appdata/roaming/sketchup/sketchup 2024/sketchup/plugins/fredo6_thrupaint/thrupainttool.rbe:4257:in onLButtonDown' Error: #<NoMethodError: undefined method []' for nil:NilClass>
            c:/users/szcze/appdata/roaming/sketchup/sketchup 2024/sketchup/plugins/fredo6_thrupaint/thrupaintmiro.rbe:1864:in _initial_calculate' c:/users/szcze/appdata/roaming/sketchup/sketchup 2024/sketchup/plugins/fredo6_thrupaint/thrupaintmiro.rbe:498:in continue_session'
            c:/users/szcze/appdata/roaming/sketchup/sketchup 2024/sketchup/plugins/fredo6_thrupaint/thrupainttool.rbe:3173:in miro_prepare_session' c:/users/szcze/appdata/roaming/sketchup/sketchup 2024/sketchup/plugins/fredo6_thrupaint/thrupainttool.rbe:3101:in start_painting'
            c:/users/szcze/appdata/roaming/sketchup/sketchup 2024/sketchup/plugins/fredo6_thrupaint/thrupainttool.rbe:2057:in handle_click_down' c:/users/szcze/appdata/roaming/sketchup/sketchup 2024/sketchup/plugins/fredo6_thrupaint/thrupainttool.rbe:4257:in onLButtonDown'
            and the other when selecting any material from the materials manager.
            Error: #<NoMethodError: undefined method delete_if' for nil:NilClass> c:/users/szcze/appdata/roaming/sketchup/sketchup 2024/sketchup/plugins/fredo6_!libfredo6/body_lib6materialbrowser.rbe:3647:in matos_history_store'
            c:/users/szcze/appdata/roaming/sketchup/sketchup 2024/sketchup/plugins/fredo6_!libfredo6/body_lib6materialbrowser.rbe:3575:in matos_set_current_from_matbro' c:/users/szcze/appdata/roaming/sketchup/sketchup 2024/sketchup/plugins/fredo6_!libfredo6/body_lib6materialbrowser.rbe:2454:in matinfo_event'
            c:/users/szcze/appdata/roaming/sketchup/sketchup 2024/sketchup/plugins/fredo6_!libfredo6/body_lib6materialbrowser.rbe:2319:in dialog_process_events' c:/users/szcze/appdata/roaming/sketchup/sketchup 2024/sketchup/plugins/fredo6_thrupaint/thrupaintmaindialog.rbe:1125:in dialog_callback_exec'
            c:/users/szcze/appdata/roaming/sketchup/sketchup 2024/sketchup/plugins/fredo6_thrupaint/thrupaintmaindialog.rbe:1117:in dialog_callback' c:/users/szcze/appdata/roaming/sketchup/sketchup 2024/sketchup/plugins/fredo6_!libfredo6/body_lib6chromiumwdlg.rbe:2460:in call'
            c:/users/szcze/appdata/roaming/sketchup/sketchup 2024/sketchup/plugins/fredo6_!libfredo6/body_lib6chromiumwdlg.rbe:2460:in master_callback' c:/users/szcze/appdata/roaming/sketchup/sketchup 2024/sketchup/plugins/fredo6_!libfredo6/body_lib6chromiumwdlg.rbe:2225:in j_action'
            c:/users/szcze/appdata/roaming/sketchup/sketchup 2024/sketchup/plugins/fredo6_!libfredo6/body_lib6chromiumwdlg.rbe:2184:in j_callback' c:/users/szcze/appdata/roaming/sketchup/sketchup 2024/sketchup/plugins/fredo6_!libfredo6/body_lib6chromiumwdlg.rbe:2170:in block in j_dispatch'
            c:/users/szcze/appdata/roaming/sketchup/sketchup 2024/sketchup/plugins/fredo6_!libfredo6/body_lib6chromiumwdlg.rbe:2162:in each' c:/users/szcze/appdata/roaming/sketchup/sketchup 2024/sketchup/plugins/fredo6_!libfredo6/body_lib6chromiumwdlg.rbe:2162:in j_dispatch'
            c:/users/szcze/appdata/roaming/sketchup/sketchup 2024/sketchup/plugins/fredo6_!libfredo6/body_lib6chromiumwdlg.rbe:1439:in `block in create_dialog'
            Besides that, the extension acts inconsistently during other operations. The whole process can be seen in the youtube video linked below.
            Error Sketchup Thrupaint
            • fredo6F
              NEW RELEASE: ThruPaint v2.5b - 24 Sep 24
              Requirements:
              • LibFredo6 14.6a
              ThruPaint 2.5b is a release including:
              • Fix of a major bug introduced in v2.5a, creating unexpected errors
              fredo6F 1 Reply Last reply
              • fredo6F
                fredo6 @fredo6
                @miszcz
                Could you try with ThruPaint v2.5b just released.
                M 1 Reply Last reply
                  miszcz @fredo6
                  @fredo6 Generally material manager is still stuck on “please wait” also Thrupaint is giving Error: #<NoMethodError: undefined method delete_if' for nil:NilClass> after applying any material. Also, you cannot enter “edit mode” in face mode by double click and there is no material preview above the cursor. The only thing i noticed that have changed is actually a big one - that you can change modes in the “ribbon” after you closed and opened the plugin again which makes the plugin usable again.
                  • fredo6F
                    fredo6 @miszcz
                    @miszcz
                    I think there is a general problem with your environment. If you get the message 'Plese Wait' forever, then ThruPaint may not work correctly.
                    Could you please:
                    • Invoke the menu Window > LibFredo6 Settings... > Fredo6 Plugins Information for Sketchucation Support. Just send me the outpout displayed in the Ruby Console
                    • Tell me if the problem happens with any model, and say, in a new model
                    • Send me the trace of the error Error: "#<NoMethodError: undefined method delete_if' for nil:NilClass>", so that I have the line number in .rb files.
                      jusbell82
                      I'm also seeing errors while using the plugin. I can pretty reliably recreate the issue by opening multiple models with ThruPain open, then switching between them. Once it has an error the plugin becomes unusable. I've also had it fail in other contexts, for example, working on a single model, but those are tougher to recreate reliably.
                      Video Showing Repro
                      ThruPaintErrors.mp4
                      Plugin information for Support
                      Fredo6 Plugins Information on 2024-09-29 07:34:40 -0400
                      - Platform: arm64-darwin - Ruby: 3.2.2
                      - Sketchup: 24.0.595
                      - LibFredo6: v14.6a
                      - LibFredo6 Binary loaded
                      - Sketchucation ExtensionStore: 4.4.0
                      - SCFLicense: v6.4a - 72
                      - Fredo6 Plugins
                      - SCFLicense directory present
                          > Signature File: 2024-04-19 21:52:41 -0400
                          > ClothWorks: 2024-02-12 20:32:28 -0500
                          > ThruPaint: 2024-09-26 07:53:53 -0400
                      Errors Observed
                      First Error when switching between models
                      Error: #<NoMethodError: undefined method `each' for nil:NilClass>
                      /users/jusbell82/library/application support/sketchup 2024/sketchup/plugins/fredo6_thrupaint/bootstrap_thrupaint.rbe:397:in `exit'
                      /users/jusbell82/library/application support/sketchup 2024/sketchup/plugins/fredo6_thrupaint/bootstrap_thrupaint.rbe:302:in `model_activating'
                      /users/jusbell82/library/application support/sketchup 2024/sketchup/plugins/fredo6_thrupaint/bootstrap_thrupaint.rbe:283:in `onActivateModel'
                      Subsequent errors when trying to activate tool via toobar.
                      Error: #<NoMethodError: undefined method `[]' for nil:NilClass>
                      /users/jusbell82/library/application support/sketchup 2024/sketchup/plugins/fredo6_thrupaint/thrupainttool.rbe:547:in `paint_mode_change'
                      /users/jusbell82/library/application support/sketchup 2024/sketchup/plugins/fredo6_thrupaint/bootstrap_thrupaint.rbe:422:in `execute_direct'
                      /users/jusbell82/library/application support/sketchup 2024/sketchup/plugins/fredo6_thrupaint/bootstrap_thrupaint.rbe:79:in `action__mapping'
                      /var/folders/85/65t6bh0j5gb1ntqbpx3_20dm0000gn/T/com.sketchup.SketchUp.2024.jusbell82/Fredo6_LibFredo6_TemporaryFiles/data6.rb:65:in `call'
                      /var/folders/85/65t6bh0j5gb1ntqbpx3_20dm0000gn/T/com.sketchup.SketchUp.2024.jusbell82/Fredo6_LibFredo6_TemporaryFiles/data6.rb:65:in `launch_action'
                      /users/jusbell82/library/application support/sketchup 2024/sketchup/plugins/fredo6_!libfredo6/lib6plugin.rbe:244:in `launch_action'
                      /users/jusbell82/library/application support/sketchup 2024/sketchup/plugins/fredo6_thrupaint/bootstrap_thrupaint.rbe:69:in `launch_action'
                      /users/jusbell82/library/application support/sketchup 2024/sketchup/plugins/fredo6_thrupaint/bootstrap_thrupaint.rbe:145:in `block in startup'
                      /users/jusbell82/library/application support/sketchup 2024/sketchup/plugins/fredo6_!libfredo6/lib6plugin.rbe:1463:in `command_invoke'
                      /users/jusbell82/library/application support/sketchup 2024/sketchup/plugins/fredo6_!libfredo6/lib6plugin.rbe:1443:in `block (2 levels) in build_config_commands'
                      /users/jusbell82/library/application support/sketchup 2024/sketchup/plugins/fredo6_!libfredo6/lib6traductor.rbe:1446:in `block in add_command'
                        miszcz @fredo6
                        @fredo6 Here is the Window > LibFredo6 Settings... > Fredo6 Plugins Information for Sketchucation Support Ruby Console
                        Fredo6 Plugins Information on 2024-10-02 19:37:58 +0200
                        - Platform: x64-mswin64_140 - Ruby: 3.2.2
                        - Sketchup: 24.0.594
                        - LibFredo6: v14.6a
                        - Sketchucation ExtensionStore: 4.4.1
                        - SCFLicense: v6.4a - 74
                        - Fredo6 Plugins
                            > LordOfTheToolbars v2.7c
                            > Curviloft v2.0a - licensed FULL
                            > Curvizard v2.5a - licensed FULL
                            > FredoCorner v2.7a
                            > FredoScale v3.6a - licensed FULL
                            > FredoSpline v2.6a - licensed FULL
                            > FredoTools v4.5c
                            > JointPushPull v4.8a - licensed FULL
                            > MrHide v1.8a
                            > ThruPaint v2.5b - licensed FULL
                            > ToolsOnSurface v2.6a - licensed FULL
                            > Axyz v1.1a
                            > Signature File: 2024-01-12 19:58:04 +0100
                            > Curviloft: 2024-01-12 20:05:07 +0100
                            > Curvizard: 2024-01-12 20:06:02 +0100
                            > FredoScale: 2024-01-12 19:59:00 +0100
                            > FredoSpline: 2024-09-22 17:44:28 +0200
                            > JointPushPull: 2024-01-12 20:02:53 +0100
                            > ThruPaint: 2024-09-22 17:44:40 +0200
                            > ToolsOnSurface: 2024-02-18 06:28:48 +0100
                            > TopoShaper: 2024-01-12 20:10:57 +0100
                        Full errror "#<NoMethodError: undefined method delete_if' for nil:NilClass>", goes like this
                        Error: #<NoMethodError: undefined method `delete_if' for nil:NilClass>
                        c:/users/szcze/appdata/roaming/sketchup/sketchup 2024/sketchup/plugins/fredo6_!libfredo6/body_lib6materialbrowser.rbe:3647:in `matos_history_store'
                        c:/users/szcze/appdata/roaming/sketchup/sketchup 2024/sketchup/plugins/fredo6_!libfredo6/body_lib6materialbrowser.rbe:3575:in `matos_set_current_from_matbro'
                        c:/users/szcze/appdata/roaming/sketchup/sketchup 2024/sketchup/plugins/fredo6_!libfredo6/body_lib6materialbrowser.rbe:2454:in `matinfo_event'
                        c:/users/szcze/appdata/roaming/sketchup/sketchup 2024/sketchup/plugins/fredo6_!libfredo6/body_lib6materialbrowser.rbe:2319:in `dialog_process_events'
                        c:/users/szcze/appdata/roaming/sketchup/sketchup 2024/sketchup/plugins/fredo6_thrupaint/thrupaintmaindialog.rbe:1125:in `dialog_callback_exec'
                        c:/users/szcze/appdata/roaming/sketchup/sketchup 2024/sketchup/plugins/fredo6_thrupaint/thrupaintmaindialog.rbe:1117:in `dialog_callback'
                        c:/users/szcze/appdata/roaming/sketchup/sketchup 2024/sketchup/plugins/fredo6_!libfredo6/body_lib6chromiumwdlg.rbe:2460:in `call'
                        c:/users/szcze/appdata/roaming/sketchup/sketchup 2024/sketchup/plugins/fredo6_!libfredo6/body_lib6chromiumwdlg.rbe:2460:in `master_callback'
                        c:/users/szcze/appdata/roaming/sketchup/sketchup 2024/sketchup/plugins/fredo6_!libfredo6/body_lib6chromiumwdlg.rbe:2225:in `j_action'
                        c:/users/szcze/appdata/roaming/sketchup/sketchup 2024/sketchup/plugins/fredo6_!libfredo6/body_lib6chromiumwdlg.rbe:2184:in `j_callback'
                        c:/users/szcze/appdata/roaming/sketchup/sketchup 2024/sketchup/plugins/fredo6_!libfredo6/body_lib6chromiumwdlg.rbe:2170:in `block in j_dispatch'
                        c:/users/szcze/appdata/roaming/sketchup/sketchup 2024/sketchup/plugins/fredo6_!libfredo6/body_lib6chromiumwdlg.rbe:2162:in `each'
                        c:/users/szcze/appdata/roaming/sketchup/sketchup 2024/sketchup/plugins/fredo6_!libfredo6/body_lib6chromiumwdlg.rbe:2162:in `j_dispatch'
                        I checked, and this problem is happening in any model.
                        • fredo6F
                          NEW RELEASE: ThruPaint v2.6a - 15 Oct 24
                          Requirements:
                          • LibFredo6 14.6a
                          ThruPaint 2.6a is a release including:
                          • Fix of a future bug
                          • C
                            carlosmgilp
                            Hi how are you?
                            I'm trying to map this mesh with quadmesh uv, but I get an error.
                            I know the mesh is Quads.
                            How can I fix this error?
                            I'm attaching the sketchup file in case you want to try it.
                            Thanks.
                            Mesh blender.skp
                            • fredo6F
                              fredo6 @carlosmgilp
                              @carlosmgilp
                              The requirement is Quad, but actually more like a grid. Your mesh may be quad, but not grid-like.
                              C 1 Reply Last reply
                              • C
                                carlosmgilp @fredo6
                                @fredo6 Hello, how are you? Thanks for your prompt response.
                                Do you know of any way or plugin that I can use to improve the mesh before applying the material?
                                Thanks.
                                • P
                                  papdimitris
                                  Hello,
                                  I'm experiencing a problem with the ThruPaint v2.6a plugin in SketchUp after the update. When I try to use certain functions nothing works, I see the following error message in the Ruby Console:
                                  "1446:in `block in add_command" and
                                  I'm currently using SketchUp version 2024 and ThruPaint version 2,6a.
                                  I've tried troubleshooting by reinstalling the plugin and the LibFredo6, but the error persists. Any guidance you can offer to resolve this would be greatly appreciated.
                                  Thanks in advance!
                                    Darius
                                    Hello, just updated to ThruPaint 2.6a, and it does not work at all. Have 3 seats and same results on all of them.
                                    Pictogram appears but when you hit it nothing happens. License is ok, extension store is v4.4.1 and libfredo6 is v14.6a.
                                    Roo EvansR 1 Reply Last reply
                                    • Roo EvansR
                                      Roo Evans @Darius
                                      @Darius Same issue here!
                                      One of our colleagues and me have the same issue.
                                      We click a button, it stays "selected" but Thrupaint doesn't open or pop up.
                                      Quite unfortunate to have an update forced on you that doesn't work and leaves your work stranded.
                                      Does anyone have the .rbz for version 2.5b by any chance?
                                      Cheers,
                                      Roo Evans
                                      N 1 Reply Last reply
                                        alefebvre
                                        Bonjour,
                                        Cela ne fonctionne pas non plus chez moi...
                                        • N
                                          nickchun @Roo Evans
                                          I am also having this issue, having been prompted to update.
                                          The brush icon is highlighting but no tooltip is appearing to paint with, or the thrupaint toolbar.
                                          I've updated Thru Paint to V2.6 and LibFredo to 14.6a
                                            Mike Backman
                                            Why Does thrupaint keep asking me to validate my license? and I cant find my licensee file. c26ed4a0-68bd-43a0-98a4-afafc9dec5d7-image.png
                                            TIGT 1 Reply Last reply
                                            • 8 / 10
