    Medeek Electrical
    205 Posts 6 Posters 268.4k Views 5 Watching
    • medeekM Offline
      medeek
      Tutorial 6 - Annotation Formatting (9:47 min.)
      Nathaniel P. Wilkerson PE
      Medeek Engineering Inc
      design.medeek.com
      • medeekM Offline
        medeek
        Version 1.3.9 - 01.08.2024
        • Updated and improved the license verification module.
        • Disabled redundant logging to improve plugin performance.
        design.medeek.com
        • medeekM Offline
          medeek
          Version 1.4.0 - 01.12.2024
          • Added a "PIPE" shape to the wire module for electrical conduit.
          • Added an additional parameter for custom wires (conduits/pipes) within the library: Wall Thickness.
          • Added standard PVC (Schedule 40) electrical conduit sizes into the custom wire library.
          Note, that previous custom wire libraries will not be compatible with this latest update. If you have an extensive library already established please contact me directly with step-by-step instructions on how to bring an older wire library into this latest version of the plugin.
          http://design.medeek.com/resources/electricalplugin/images2/elec_su241_800.jpg
          http://design.medeek.com/resources/electricalplugin/images2/elec_su240_800.jpg
          The dimensions for the OD, wall thickness and bend radius were taken directly from CANTEX and JM Eagle literature, and should match exactly the standard specs for SCH40 PVC in the American and Canadian markets.
          design.medeek.com
          • medeekM Offline
            medeek
            Version 1.4.1 - 01.31.2024
            • Improved the serial number verification logic within the License tab of the Global Settings.
            • Updated the javascript logic within the License tab of the Global Settings.
            • Added standard PVC (Schedule 80) electrical conduit sizes into the custom wire library.
            • Fixed a minor bug with the edit wire profile logic of the wire module.
            http://design.medeek.com/resources/electricalplugin/images2/elec_su242_800.jpg
            It turns out the outer diameter and bend radius of schedule 80 conduit is the same as schedule 40, only the wall thickness is different. I learn something new everyday.
            design.medeek.com
            • medeekM Offline
              medeek
              Version 1.4.2 - 04.21.2024
              • Fixed a compatibility bug with SketchUp 2024 while maintaining compatibility with previous versions of SketchUp.
              design.medeek.com
              • medeekM Offline
                medeek
                Version 1.4.3 - 05.15.2024
                • Added a “SQTUBE” shape to the wire module for electrical chases.
                alt text
                design.medeek.com
                • medeekM Offline
                  medeek
                  Version 1.4.4 - 06.17.2024
                  • Added the "Draw Service Entrance" function to the primary toolbar.
                  • Enabled the ability to draw service entrance devices: CSED and Meter Socket.
                  http://design.medeek.com/resources/electricalplugin/images2/elec_su244_800.jpg
                  http://design.medeek.com/resources/electricalplugin/images2/elec_su245_800.jpg
                  For the callout and 2D symbol I'm not really sure what I should use, for now I'm showing the device part number and a simple rectangle.  Any thoughts or suggestions in this regard will be appreciated.
                  design.medeek.com
                  • medeekM Offline
                    medeek
                    Version 1.4.5 - 06.19.2024
                    • Added "disconnect switches" under misc. fixtures.
                    • Added a twin meter socket to the built-in library.
                    • Updated the Legend tool to include service entrance devices.
                    • Updated the Electrical Estimating module to include service entrance devices.
                    • Added voltage and amperage as parameters for service entrance devices.
                    • Changed the label text for service entrance devices to voltage and amperage.
                    http://design.medeek.com/resources/electricalplugin/images2/elec_su250_800.jpg
                    http://design.medeek.com/resources/electricalplugin/images2/elec_su247_800.jpg
                    http://design.medeek.com/resources/electricalplugin/images2/elec_su246_800.jpg
                    design.medeek.com
                    • medeekM Offline
                      medeek
                      Version 1.4.6 - 06.22.2024
                      • Added "generators" under misc. fixtures.
                      • Added "water heaters" under misc. fixtures.
                      • Added a variety of other common electrical devices categories under misc. fixtures.
                      design.medeek.com
                      • medeekM Offline
                        medeek
                        Version 1.4.7 - 07.18.2024
                        • Added combined "smoke/CO" detectors under safety devices.
                        • Updated the Legend tool to include combined smoke/CO devices.
                        The included device in the smoke/CO library is a KIDDE 30CUDR. Just bought this one yesterday and modeled it this morning.
                        Amazon.com
                        (www.amazon.com)
                        Note the 2D symbol text for this type of device is "SC".
                        design.medeek.com
                        • medeekM Offline
                          medeek
                          Version 1.4.8 - 07.02.2025
                          Added "hvac" under misc. fixtures.
                          Added four generic hvac condensor units/sizes into the built-in library: 30X28, 30x32, 30x40, 36x32.
                          design.medeek.com
                          • medeekM Offline
                            medeek
                            Version 1.4.9 - 02.11.2025
                            • Added three generic hvac condensor units/sizes into the built-in library (with WeatherGuardTM tops): 30X28_WG, 30x32_WG, 30x40_WG.
                            These additional variants added per customer request. They are the exact same as the similar sized units other than the addition of the weather guard top. Hopefully this gives enough selection for typical residential AC units however if there is need for any other styles etc... please let me know.
                            design.medeek.com
                            • medeekM Offline
                              medeek
                              Version 1.5.0 - 02.16.2025
                              • Added two generic side discharge hvac/heat pump condensor units into the built-in library: HP_XV19_42, HP_XV19_36.
                              • Added various "Wilkerson Art" framed art prints within the "art" category under misc. fixtures: Wasco, Frog, Hummingbird, Eagle under Sun, Killer Whale, Abstract and Medeek (Grizzly Bear).
                              Medeek Internet Services - NT200 Windows 2016 Server
                              (www.wilkersonart.com)
                              The funny thing is that I added the hummingbird framed art back in June (2024) as an Easter Egg but I guess no one noticed, or at least no one ever messaged me about it so I guess it went undetected. I've also added in a decent wall clock as well for those needing a wall clock mounted in a room.
                              Decided to take a much needed break from the code today and did some other misc. tasks. This one just kind of popped up on my radar so I figured I would add a few more framed prints.
                              As far as using the artwork in any of your projects, so long as you hold a licensed copy of the Medeek Electrical plugin you are authorized to use my artwork in any personal or professional projects you see fit. My only request is that if you do decide to use the artwork, please give attribution where possible and applicable.
                              design.medeek.com
                              • medeekM Offline
                                medeek
                                Version 1.5.2 - 06.02.2025
                                • Updated the wire library to include all the common NMB wire sizes.
                                This update per customer request.
                                Wire sizes per the Southwire (Romex) documentation:
                                404 - File or directory not found.
                                (design.medeek.com)
                                design.medeek.com
                                • medeekM Offline
                                  medeek
                                  Version 1.5.4 - 08.11.2025
                                  • Added "chargers" (EV) under misc. fixtures.
                                  • Added a (Stiebel Eltron) tankless water heater and a (Tesla) wall charger/connector to the built-in libraries within misc. fixtures.
                                  design.medeek.com
                                  • medeekM Offline
                                    medeek
                                    Version 1.5.5 - 12.11.2025
                                    • Fixed the "terminal" wall corner configuration bug for all electrical fixtures.
                                    design.medeek.com
                                    • medeekM Offline
                                      medeek
                                      Version 1.5.6 - 12.14.2025
                                      • Added three and four gang dimmer and timer switches.
                                      design.medeek.com
                                      • medeekM Offline
                                        medeek
                                        I’m thinking about adding in a tool so that one can assign labels within a load center as well as configure the circuit breakers. Thoughts on this?
                                        design.medeek.com
                                        • gullfoG Offline
                                          gullfo
                                          so, on the white "paper" space you would have a list (slots) for entering text "kitchen light", "kitchen outlet", "garage door", "clothes washer", "clothes dryer" etc and add some parameters like voltage, amperage, single, dual, etc?
                                          "clothes dryer", 240V, 30A, SINGLE -> voltage logic would span a 240V across both busses?
                                          "air conditioner", 240V, 50A, DUAL -> would have two 240V splitting 25A across each for the air handler and compressor?
                                          "kitchen lights", 120V, 20A, DUAL -> split two 10A circuits on single breaker (dual switches) for overhead and under counter lights to save breaker slots
                                          etc
                                          Glenn
                                          http://www.runnel.com
                                          • medeekM Offline
                                            medeek
                                            Version 1.5.8 - 02.16.2026
                                            • Fixed a minor bug with misc. fixtures.
                                            • Added additional "Wilkerson Art" framed art prints within the "art" category under misc. fixtures.
                                            design.medeek.com
                                            • 11
                                            • 10 / 11
