    Medeek Electrical
    205 Posts 6 Posters 245.4k Views 5 Watching
    • medeekM Offline
      medeek
      Version 1.2.9 - 05.30.2021
      • Added an option for vertically offsetting text and symbols within the General tab of the Global Settings.
      • Annotation text and symbols for outlets, switches, UK outlets and UK switches can be vertically offset a custom amount from the bottom of the wall.
      http://design.medeek.com/resources/electricalplugin/images/elec_su227_800.jpg
      http://design.medeek.com/resources/electricalplugin/images/elec_su228_800.jpg
      The default placement was at the bottom of the framed wall, and the default offsets still are zero unless otherwise specified differently. However in most situations this resulted in Z-fighting with the subfloor and if a finished floor was modeled then the symbols and text would be buried within the finished floor or carpet (not visible). This option allows the user to customize the vertical placement to suit their particular needs.
      This update was per customer request.
      Nathaniel P. Wilkerson PE
      Medeek Engineering Inc
      design.medeek.com
      • medeekM Offline
        medeek
        Version 1.3.0 - 06.01.2021
        • Added four additional parameters to the "User Interface" section of the General tab of the global settings. This allows the customization (colors) of the HTML menus and buttons.
        http://design.medeek.com/resources/electricalplugin/images/elec_su229_800.jpg
        design.medeek.com
        • medeekM Offline
          medeek
          Version 1.3.1 - 06.16.2021
          • Updated the wiring module/algorithm to improve performance and overall robustness.
          design.medeek.com
          • medeekM Offline
            medeek
            Version 1.3.2 - 07.11.2021
            • Enabled subscription and permanent licensing.
            • The License tab of the Global Settings now displays the license type.
            design.medeek.com
            • medeekM Offline
              medeek
              Version 1.3.3 - 01.11.2023
              • Enabled layer control integration with the Medeek Project extension.
              design.medeek.com
              • medeekM Offline
                medeek
                Version 1.3.4 - 06.13.2023
                • Enabled switches, outlets and lights to be inserted into "component" walls.
                Previously electrical fixtures could only be inserted into walls that were "groups", with this update the wall assemblies can be either groups or components.
                This update per customer request.
                P.S.
                I will still need to update the other misc. electrical fixtures (ie. panels, low voltage, safety, heaters, vents, low voltage panels etc...)
                design.medeek.com
                • medeekM Offline
                  medeek
                  Version 1.3.5 - 09.29.2023
                  • Added six additional dimmer switch combinations.
                  http://design.medeek.com/resources/electricalplugin/images2/elec_su233_800.jpg
                  design.medeek.com
                  • medeekM Offline
                    medeek
                    Version 1.3.6 - 10.04.2023
                    • Added an offset parameter (advanced options) for outlets which allows the symbol and label to be offset from the wall.
                    • Added two additional advanced parameters for vertically offsetting text and symbols for switches and outlets.
                    http://design.medeek.com/resources/electricalplugin/images2/elec_su235_800.jpg
                    http://design.medeek.com/resources/electricalplugin/images2/elec_su234_800.jpg
                    The text and symbol vertical offsets are driven by the global settings however these two parameters can now be adjusted separately for each individual outlet or switch.
                    This update is per customer request.
                    design.medeek.com
                    • medeekM Offline
                      medeek
                      Version 1.3.7 - 10.14.2023
                      • Added four timer switch combinations (Leviton VPT24-1PZ).
                      http://design.medeek.com/resources/electricalplugin/images2/elec_su236_800.jpg
                      Added per customer request.
                      design.medeek.com
                      • medeekM Offline
                        medeek
                        Version 1.3.8 - 11.22.2023
                        • Added two additional parameters for annotation formatting.
                        • Added the "Regen Electrical" function to the primary toolbar, enabled regeneration for all electrical fixtures.
                        • Moved the "Draw Safety Device" tool to the secondary toolbar.
                        http://design.medeek.com/resources/electricalplugin/images2/elec_su237_800.jpg
                        http://design.medeek.com/resources/images/electrical_su_menu_active.jpg
                        http://design.medeek.com/resources/images/electrical_ii_su_menu_active.jpg
                        design.medeek.com
                        • medeekM Offline
                          medeek
                          Version 1.3.8b - 11.23.2023
                          • Added the "Symbol Text Scale" parameter for scaling superscript of 2D electrical symbols.
                          http://design.medeek.com/resources/electricalplugin/images2/elec_su238_800.jpg
                          http://design.medeek.com/resources/electricalplugin/images2/elec_su239_800.jpg
                          With this update one can scale the 2D symbol superscript of the electrical symbols and make them more visible and legible when exporting to Layout, PDFs or paper.
                          design.medeek.com
                          • medeekM Offline
                            medeek
                            Tutorial 6 - Annotation Formatting (9:47 min.)
                            design.medeek.com
                            • medeekM Offline
                              medeek
                              Version 1.3.9 - 01.08.2024
                              • Updated and improved the license verification module.
                              • Disabled redundant logging to improve plugin performance.
                              design.medeek.com
                              • medeekM Offline
                                medeek
                                Version 1.4.0 - 01.12.2024
                                • Added a "PIPE" shape to the wire module for electrical conduit.
                                • Added an additional parameter for custom wires (conduits/pipes) within the library: Wall Thickness.
                                • Added standard PVC (Schedule 40) electrical conduit sizes into the custom wire library.
                                Note, that previous custom wire libraries will not be compatible with this latest update. If you have an extensive library already established please contact me directly with step-by-step instructions on how to bring an older wire library into this latest version of the plugin.
                                http://design.medeek.com/resources/electricalplugin/images2/elec_su241_800.jpg
                                http://design.medeek.com/resources/electricalplugin/images2/elec_su240_800.jpg
                                The dimensions for the OD, wall thickness and bend radius were taken directly from CANTEX and JM Eagle literature, and should match exactly the standard specs for SCH40 PVC in the American and Canadian markets.
                                design.medeek.com
                                • medeekM Offline
                                  medeek
                                  Version 1.4.1 - 01.31.2024
                                  • Improved the serial number verification logic within the License tab of the Global Settings.
                                  • Updated the javascript logic within the License tab of the Global Settings.
                                  • Added standard PVC (Schedule 80) electrical conduit sizes into the custom wire library.
                                  • Fixed a minor bug with the edit wire profile logic of the wire module.
                                  http://design.medeek.com/resources/electricalplugin/images2/elec_su242_800.jpg
                                  It turns out the outer diameter and bend radius of schedule 80 conduit is the same as schedule 40, only the wall thickness is different. I learn something new everyday.
                                  design.medeek.com
                                  • medeekM Offline
                                    medeek
                                    Version 1.4.2 - 04.21.2024
                                    • Fixed a compatibility bug with SketchUp 2024 while maintaining compatibility with previous versions of SketchUp.
                                    design.medeek.com
                                    • medeekM Offline
                                      medeek
                                      Version 1.4.3 - 05.15.2024
                                      • Added a “SQTUBE” shape to the wire module for electrical chases.
                                      alt text
                                      design.medeek.com
                                      • medeekM Offline
                                        medeek
                                        Version 1.4.4 - 06.17.2024
                                        • Added the "Draw Service Entrance" function to the primary toolbar.
                                        • Enabled the ability to draw service entrance devices: CSED and Meter Socket.
                                        http://design.medeek.com/resources/electricalplugin/images2/elec_su244_800.jpg
                                        http://design.medeek.com/resources/electricalplugin/images2/elec_su245_800.jpg
                                        For the callout and 2D symbol I'm not really sure what I should use, for now I'm showing the device part number and a simple rectangle.  Any thoughts or suggestions in this regard will be appreciated.
                                        design.medeek.com
                                        • medeekM Offline
                                          medeek
                                          Version 1.4.5 - 06.19.2024
                                          • Added "disconnect switches" under misc. fixtures.
                                          • Added a twin meter socket to the built-in library.
                                          • Updated the Legend tool to include service entrance devices.
                                          • Updated the Electrical Estimating module to include service entrance devices.
                                          • Added voltage and amperage as parameters for service entrance devices.
                                          • Changed the label text for service entrance devices to voltage and amperage.
                                          http://design.medeek.com/resources/electricalplugin/images2/elec_su250_800.jpg
                                          http://design.medeek.com/resources/electricalplugin/images2/elec_su247_800.jpg
                                          http://design.medeek.com/resources/electricalplugin/images2/elec_su246_800.jpg
                                          design.medeek.com
                                          • medeekM Offline
                                            medeek
                                            Version 1.4.6 - 06.22.2024
                                            • Added "generators" under misc. fixtures.
                                            • Added "water heaters" under misc. fixtures.
                                            • Added a variety of other common electrical devices categories under misc. fixtures.
                                            design.medeek.com
                                            • 11
                                            • 10 / 11
