    I installed the latest plugin but it doesn't appear in the menu list
    4 Posts 2 Posters 82 Views 2 Watching
      rutpin
      TIGT 1 Reply Last reply Reply Quote 0
        TIG Moderator @rutpin
        @rutpin
        This is not enough information.
        What 'plugin' ?
        In which menu is it meant to appear ?
        R 1 Reply Last reply Reply Quote 0
          rutpin @TIG
          @TIG FredoScale v3.6a
          In the normal menu list, where do you open the icons
            @rutpin
            So you installed the FredoScale extension.
            I assume you installed it from an RBZ you've downloaded, using the Extension Manager > Install method...
            When it's installed it doesn't appear in the 'normal menu list' - by which is must assume you mean 'Extensions', it's under the 'Tools' menu, and also has a Toolbar which you could activate.
            I don't understand your 'where do you open the icons' ?? Please explain...
            You will also need LibFredo6 [for the helper methods] and the SketchUcation Tools [for the licensing] installing...
            Restart SketchUp after the installations to sync everything.
            After that it doesn't appear, or it is not at least listed in the Extension Manager dialog, then come back for more help...
