    Sketchup is automatically colouring edges??
    Scheduled Pinned Locked Moved Solved SketchUp Discussions
    3 Posts 2 Posters 137 Views 2 Watching
      Paaavlova
      Hi, as per the title, it appears that my Sketchup file is automatically applying colours to some object's edges?
      Here's an example - I copied these seats from another Sketchup file
      alt text
      However when I pasted those seats into my current Sketchup file, it looks like this
      alt text
      Something is automatically applying a light colour to the edges when I copy paste objects over... if I go and select all the edges, I can reapply a dark material and it looks normal again.
      Not sure if I've accidentally enabled a setting somewhere without realizing, perhaps someone else knows the reason for it.
      If it makes any difference, I'm using Sketchup Pro 2021
      • Rich O BrienR Online
        Check if your Style > Edge Settings under Edit tab is set to By material
        • Rich O BrienR Rich O Brien marked this topic as a question on
          Paaavlova @Rich O Brien
          @Rich-O-Brien Aha that was it, thank you!
