    Fredo Lord of Toolbars no longer working
    26 Posts 7 Posters 2.1k Views 7 Watching
    • cmeedC Offline
      cmeed @fredo6
      @fredo6 apologies for leaving you hanging - I've been away
      heres the copy and paste of the ruby console after
      Window > LibFredo6 Settings... > Fredo6 Plugin information for Sketchucation Support.
      Fredo6 Plugins Information on 2024-04-17 10:35:20 +0100
      • Sketchup: 24.0.484
      • LibFredo6: v14.3b
      • LibFredo6 Binary loaded
      • Sketchucation ExtensionStore: 4.4.0
      • SCFLicense: v6.4a - 74
      • Fredo6 Plugins
        LordOfTheToolbars v2.7b
        Signature File: 2022-04-26 16:11:44 +0100
        ClothWorks: 2024-01-08 21:28:53 +0000
        Curviloft: 2022-06-15 11:06:32 +0100
        Curvizard: 2022-11-26 09:35:34 +0000
        FredoCorner: 2023-01-10 14:41:27 +0000
        FredoPortrait: 2022-10-24 11:05:49 +0100
        FredoScale: 2023-05-19 10:17:07 +0100
        FredoSpline: 2022-11-15 18:43:07 +0000
        JointPushPull: 2023-04-26 15:43:32 +0100
        RoundCorner: 2022-05-17 16:14:20 +0100
        ToolsOnSurface: 2022-11-24 18:36:54 +0000
      fredo6F 1 Reply Last reply Reply Quote 0
      • cmeedC Offline
        cmeed @fredo6
        looks like the 'check for Fredo6 ...' window is also not right.
        yes I have a multi monitor setup
        Laptop and a Monitor - SU on the main monitor
        • fredo6F Offline
          fredo6 @cmeed
          @cmeed
          Your installation looks correct, withe the latest version.
          For whatever reason, there seems to be an issue with the load sequence of dialogs. Some events seem not to be received, hence the partial display of dialogs.
          Could you open the Ruby console and copy/paste the following command (and then press Enter).
          UI.openURL File.join(LibFredo6.tmpdir, 'Binaries', 'SU24').
          This will open the folder where the active binary of LibFredo6, with the name: bin_body_Lib6G6.so. Can you tell me the date of the file.
          Then, close Sketchup, and try to delete this file.
          Then restart Sketchup (the file will be recreated).
          cmeedC 1 Reply Last reply Reply Quote 0
          • cmeedC Offline
            cmeed @fredo6
            @fredo6 said in Fredo Lord of Toolbars no longer working:
            Hi Fredo,
            Not sure this is what you were expecting ...
            Error: #<SyntaxError:"(eval):1: syntax error, unexpected end-of-input\n...o6.tmpdir, 'Binaries', 'SU24').\n... ^\n">
            SketchUp:in `eval'
            => nil
            • fredo6F Offline
              fredo6 @cmeed
              @cmeed
              Don’t include the final dot
                TECHDAVE02
                NO Luck still same issues 😞
                • cmeedC Offline
                  cmeed @fredo6
                  @fredo6
                  excluded the ' . ' and as expected file exploer showed this
                  • fredo6F Offline
                    fredo6 @cmeed
                    @cmeed
                    The binary is OK.
                    Did you try to check the Text scaling in Windows (see this post)?
                      TECHDAVE02
                      text scale no luck
                      • cmeedC Offline
                        cmeed @fredo6
                        @fredo6
                        Yes! this has done it for me!! - Thank you so much for helping me sort this out.... I enlarged my computer fontsize recently, also, I increased the text size on my phone.... its a sign of getting older!! booo!
                        BUTI refuse to say ahhh when i sit down...
                        Thank you again - this really is a productive tool for me. Cant thank enough!
                        @TECHDAVE02 - sorry this hasn't solved your issue!
                        • 2 / 2
