    ISSUE: SU 2024 Pro Export Animation
    2 Posts 2 Posters 224 Views 2 Watching
    • gullfoG Offline
      gullfo
      i'm experiencing a strange issue with the SU 2024 Pro export animation - exporting a jpg set. note - this is the first time i'm exporting since installing it 2 days ago.
      firstly - the exported images are retaining color even though the style is without color and using hidden line (back line).
      this image should be white.
      secondly - a group which is hidden in a given scene is showing up as the dot-line hidden view. even though in the scene it's hidden.
      definitely should not see the hidden object...
      i've tried turning off the aliasing. no-go; going back to the "classic" engine. no-go.
      definitely not working as expected. in 2023 this all works as expected. note - i'm using my customized style from 2023 in 2024, however, even using the default 2024 styles, same issues.
      Glenn
      http://www.runnel.com
        This is a known issue and the developers are aware of it and working on a solution. Hopefully they'll get it fixed in time for the first maintenance release.
