Medeek Project
Version 1.1.6 - 02.13.2024
- Added foundations within the Medeek Estimator: Slab-on-Grade, Slab, Stemwall, Grade Beam
There is still a lot more work to be done with adding all of the various hardware and items into the estimating for foundations. This is just a start.
Version 1.1.7 - 02.17.2024
- Enabled custom rebar within the Medeek Estimator for Slab-on-Grade foundations
Per customer request.
Version 1.1.8 - 02.21.2024
- Updated custom rebar within the Medeek Estimator to include unit and total length.
- Added custom rebar within the Medeek Estimator for Slab, Stemwall and Grade Beam foundations.
- Updated the Medeek Estimator so that multi-ply (custom) Window and Door headers are properly called out and quantified.
- Added additional logic into the Medeek Estimator so that assemblies are ordered in the report logically by their assembly names.
Version 1.1.8b - 02.21.2024
- Fixed a bug in the ordering logic and a typo in the HTML preview menu.
Version 1.1.9 - 03.22.2024
- Added a Weight Database to the Medeek Estimating Module.
- Enabled Weight Analysis to the Medeek Estimating Module for Rectangular Wall Panels.
- Fixed some minor bugs with the estimating module for wall panels.
Version 1.2.0 - 03.23.2024
- Added Headers (window, door, garage) for walls within the Medeek Estimating Module.
- Added Blocking for walls within the Medeek Estimating Module.
Version 1.2.1 - 03.27.2024
- Added cost analysis for windows units in walls within the Medeek Estimating Module.
- Added additional logic into the Medeek Scene Generator so that assemblies are ordered in the report logically by their assembly names.
Version 1.2.2 - 04.20.2024
- Fixed a compatibility bug with SketchUp 2024 while maintaining compatibility with previous versions of SketchUp.
Version 1.2.3 - 05.14.2024 thru 05.15.2024
- Fixed a minor bug with the estimating module (wall header library initialization).
- Fixed a minor bug with the estimating module (wall material library initialization).
