    Making a selection in a ruby script and applying command
    9 Posts 2 Posters 991 Views 2 Watching
    • H
      hollymichel Newcomers
      I'm new to making ruby scripts and am attempting to automate a sequence of actions I use constantly. The basic idea is, I select an edge and my script will draw a triangle of my specified size and select all the edges that are connected to my initial selection and perform a followme on the triangle. Everything works up until the followme. My triangle is created and my selection set is accurate. If I stop the script there, I can manually click Followme and it works on the path. But I can't seem to get the script to recognize those additional selected lines. It will only do a followme on the very first line I picked before running the script. It doesn't collect the new edges.
      I used this language to attempt the followme:
      Convert the selection to an array of edges
      connected_edges_array = selected_edges.to_a
      Perform follow me on triangle face using selected edges as path
      triangle_face.followme(connected_edges_array)
      What am I missing?
      TIGT 1 Reply Last reply
        TIG Moderator @hollymichel
        @hollymichel
        You're not helping us help you.
        You have only posted a few lines of code, so we can't see where you're going wrong.
        Also a screenshot of the starting setup would be helpful...
        Also please use the 'Code' formatting for any Ruby code your are posting...
        As you seem to be able to do it manually the path and face seem OK - although we haven't seen them !
        ### something sets a selection of edges up ??
        ### the face is somehow selected ??
        How do you ensure that all of those selected edges which are to be used are connected ?
        How do you select the face ?
        More code please...
        H 1 Reply Last reply
        • H
          hollymichel Newcomers @TIG
          @TIG
          Here is all the code that works and results in a closed loop of the edges I want. Not sure how to get the results to make a followme. I am testing this on a simple rectangle to start.
          Get the active model and selection
          mod = Sketchup.active_model
          sel = mod.selection
          Define z and perpendicular measurements
          z_measurement = 2 * perpendicular_measurement
          perpendicular_measurement = 3.0
          Get selected edges
          selected_edges = sel.grep(Sketchup::Edge)
          Exit if there are no selected edges
          if selected_edges.empty?
          UI.messagebox('Please select an edge to draw the triangle connected to.')
          return
          Select the first selected edge
          selected_edge = selected_edges.first
          Get the start and end vertices of the selected edge
          start_point = selected_edge.start.position
          end_point = selected_edge.end.position
          Calculate the midpoint of the selected edge
          midpoint = Geom::Point3d.linear_combination(0.5, start_point, 0.5, end_point)
          Calculate the direction vector perpendicular to the edge
          direction_vector = end_point - start_point
          perpendicular_vector = Geom::Vector3d.new(-direction_vector.y, direction_vector.x, 0).normalize
          perpendicular_vector.length = perpendicular_measurement
          Calculate the third vertex of the triangle
          third_vertex = midpoint.offset(perpendicular_vector)
          Create a point at the desired height above the midpoint
          point_above_midpoint = midpoint.offset([0, 0, z_measurement])
          Define the vertices of the triangle
          triangle_vertices = [midpoint, point_above_midpoint, third_vertex]
          Create the triangle face
          triangle_face = mod.entities.add_face(triangle_vertices)
          Create an edge between midpoint and third_vertex
          midpoint_third_vertex_edge = mod.entities.add_line(midpoint, third_vertex)
          sel = mod.selection
          Get the selected edge
          selected_edge = sel.grep(Sketchup::Edge).first
          Exit if no edge is selected
          unless selected_edge
          UI.messagebox('Please select an edge to determine its Z height.')
          return
          Get the Z coordinate of the selected edge
          selected_edge_start_z = selected_edge.start.position.z
          selected_edge_end_z = selected_edge.end.position.z
          Define a tolerance for comparing Z coordinates
          tolerance = 1e-6
          Select all edges with starting and ending Z coordinates matching the selected edge
          mod.entities.each do |entity|
          if entity.is_a?(Sketchup::Edge)
          edge = entity
          next if edge == selected_edge
          # Get the starting and ending Z coordinates of the edge
          edge_start_z = edge.start.position.z
          edge_end_z = edge.end.position.z
          # Check if starting and ending Z coordinates match the selected edge
          if (selected_edge_start_z - edge_start_z).abs < tolerance &&
             (selected_edge_end_z - edge_end_z).abs < tolerance
            sel.add(edge)
          Remove the edge between midpoint and third_vertex to the selection
          sel.remove(midpoint_third_vertex_edge)
          • H
            • H
              If I add those last two lines I mentioned for followme, I get this:
                @hollymichel
                Please format your code properly using the 'Code' option above
                It's almost impossible to read.
                I think you are over complicating it.
                sel = mod.selection
                ### add the triangle code - where the face is located on the edges is academic, you can draw it on and selected edge.
                ### Add the face from the desired points. You can get a reference to it after it's added.
                triangle_face.followme(selected_edges.to_a)
                The selected_edges are not guaranteed to be all connected and in order [if they are connected there are somewhat complicated methods to order them].
                A simpler way to get an array of those edges is to get the 'base_face' rather than the what you are selecting the edges around, and use that -
                sel = mod.selection
                selected_base_face= sel.grep(Sketchup::Face)[0]
                ### make triangle...
                triangle_face.followme(selected_base_face.outer_loop.edges)
                ### automatically an order array
                • H
                  @TIG ```
                  Sorry, this should read better.
                  Will the base face method work if there is no face, just lines that could be a face?
                  <# Get the active model and selection
                  sel = mod.selection
                  <# Define z and perpendicular measurements
                  <# Get selected edges
                  <# Exit if there are no selected edges
                  return
                  <# Select the first selected edge
                  <# Get the start and end vertices of the selected edge
                  <# Calculate the midpoint of the selected edge
                  <# Calculate the direction vector perpendicular to the edge
                  <# Calculate the third vertex of the triangle
                  <# Create a point at the desired height above the midpoint
                  <# Define the vertices of the triangle
                  <# Create the triangle face
                  <# Create an edge between midpoint and third_vertex
                  sel = mod.selection
                  <# Get the selected edge
                  <# Exit if no edge is selected
                  return
                  <# Get the Z coordinate of the selected edge
                  <# Define a tolerance for comparing Z coordinates
                  tolerance = 1e-6
                  <# Select all edges with starting and ending Z coordinates matching the selected edge
                  edge = entity
                    sel.add(edge)
                  <# Remove the edge between midpoint and third_vertex to the selection
                  <# Convert the selection to an array of edges
                  <# Perform follow me operation on triangle face using selected edges as path
                  • H
                    @TIG said in Making a selection in a ruby script and applying command:
                    Awesome, the base face works great when a face with edges is selected!
                      @hollymichel
                      No, it doesn't read a lot better.
                      You must add the 'code' tag and put your Ruby code inside it.
                      Then the start and end tags [i.e. three back-quotes each: note I put spaces in front here to prevent the forum thinking it was more code...
                          ### ruby code text goes here
                      ] they must both be on their own lines.
                      Which looks like this in the post.
                      Simplify your process, and make it more complex only when you've got some good results.
                      Trying to do it all in one go is just too difficult.
                      How do you eat an elephant - take small bites !
