    Many projects
    303 Posts 18 Posters 26.2k Views 17 Watching
    • Bryan KB Offline
      Excellent as always! πŸ‘
        πŸ‘Š
        • majidM Offline
          majid
          Wow, these are great... I am wondering why I have missed this post...great as always... πŸ‘ πŸ‘
          • jo-keJ Offline
            jo-ke
            thank you.
            here's an update of one of the penthouses that I am currently planing:
            (doerr.bplaced.net)
            rendered with twinmotion.
            http://www.zz7.de
            • Bryan KB Offline
              @jo-ke said:
              thank you.
              (doerr.bplaced.net)
              Stunning as always! πŸ‘
                ^, What they said mate. Very sharp.
                • jo-keJ Offline
                  jo-ke
                  quick and dirty low res render in Twilightrender
                  http://www.zz7.de
                  • ntxdaveN Offline
                    ntxdave
                    What software do you use to create the pano views?
                    It would be neat if you could use the pano view and its facilities in PowerPoint or some type of presentation software. πŸ‘
                    BTW: Great view as always. πŸ‘ πŸ‘
                    Press F1...thank me later
                    • jo-keJ Offline
                      jo-ke
                      The pano itself is created in the rendersoftware like twinmotion or twilight.
                      To put it online and make viewable on my own webspace I use pano2vr software. nice and easy to use programm.
                      otherwise you can use onlineprotals like kuula.co
                      http://www.zz7.de
                      • ntxdaveN Offline
                        ntxdave
                        How do you create a pano with Twilight?
                        • jo-keJ Offline
                          jo-ke
                          yes.
                          choose this setting:
                          http://www.zz7.de
                          • ntxdaveN Offline
                            ntxdave
                            Thanks Jo-ke. I took a quick look at both tools. If I understand this correctly, you would follow the same process in Twilight as generating a video. You would the use the images generated by Twilight as the input for the other two products.
                            • jo-keJ Offline
                              jo-ke
                              yes, the picture is generated in twilght and you need a software to show it on a sphere.
                              http://www.zz7.de
                              • ntxdaveN Offline
                                ntxdave
                                Thanks for the response. At some point I will have to give it a try. πŸ˜„
                                • jo-keJ Offline
                                  jo-ke
                                  preview of a large supermarket project
                                  render
                                  su view
                                  http://www.zz7.de
                                  • marked001M Offline
                                    marked001
                                    Very nice πŸ‘
                                    http://www.revision21vis.com
                                    instagram: revi21on
                                    • Bryan KB Offline
                                      Saw this over on FB. Amazing work!
                                      Even my new PC could not handle this. Great job! πŸ‘
                                      • jo-keJ Offline
                                        jo-ke
                                        thank you. πŸ˜„
                                        here's a video of a current project:
                                        http://www.zz7.de
                                        • jo-keJ Offline
                                          jo-ke
                                          quick test with Twinmotion2023, models found in 3dwarehouse:
                                          http://www.zz7.de
                                          • ntxdaveN Offline
                                            ntxdave
                                            πŸ‘ πŸ‘
                                            • 15
                                            • 16
                                            • 3 / 16
