    Can specify entity length only once
    5 Posts 4 Posters 979 Views 4 Watching
      poumtatalia
      I realise that I can only specify once an entity's length.
      After doing so once, if I select another entity (let's say a line), select the entity information, write a value in the length field, and the value shows but doesn't apply. I try closing the entity info windows, re opening it, the old value is again. The only workaround I found was to completely shut the application, thenm re open it which allows me to successfully change the length of one entity then I have to close the app again.
      Any idea anyone?
        remus
        I cant replicate this, im not sure what might be going wrong.
        One thought actually, are you pressing enter after youve entered the length?
          bytesyzeZ
          All of a sudden.. I cannot change the length of a drawn line. I cannot define the offset between two guidelines. What is happening. Using SKETCHUP PRO Version 23.1.341 Could do all this last week!
            bytesyzeZ
              SketchUp 2023 hasn't changed since last week. What did? This sounds like you've changed your process. Are youu clicking in the Measurements window? Are you changing tools before trying to change the value?
              Please update your forum profile. It says you're still using SketchUp 2022.
