    [Plugin][WIP][OpenSource] Bezier Surface
    245 Posts 69 Posters 57.6k Views 69 Watching
      cuttingedge
      I got it finally working.. It will do wonders for me...For once, I have a feeling Im working in Max environment. Clean mesh... Thank you so so much Thomthom. I look at you and I see possibilities for our beloved SU to conquer the 3d world..May your kind multiply..
      BTW, Im still awaiting updates for the non destructive SubD..
        @cmeed said:
        Sorry no i didn't look at the ruby console.
        So in future - do I have the ruby window open while I work or open it when something's happened. Just do I know for next time.
        Great work. (As always)
        C
        Before - otherwise it won't be recorded. So if you experience problems, undo, open Ruby Console and try again.
          It's coming along. πŸ˜„
            saldstudio
            hello,
            im litttle confused with this plugin. Ive got latest version, and toolbar looks different
            http://s18.postimg.org/jsbuls3ih/bar.jpg
            Its about some older version, that had triangle surface?
            And how can I precize manipulate with green, bezzier lines (to modify shape)?
            Always when I try to model sommething symmetricval, I fail, becouse I cant do the same thing on both sides, becouse those green lines cant react with sketchup tricks (like shift+direction, or set lenght manualy).
            Still great work and plugin πŸ˜„
              That was some an older version. The Triangle Patch is removed because it was never implemented. The control points handling changed as well.
                saldstudio
                Thanks for reply. I hope this plugin will have a chance to develop πŸ˜„
                • deaneauD Offline
                  deaneau
                  @thomthom
                  could you guide me how i can open the complete pallete?
                  i try to model a a bus. how i can setup the texture?
                  blue print setup?
                  could you develop like this?
                  many thanks when this is possible.
                    Why i have not more this lovely interface ?
                    https://sketchucation.com/forums/download/file.php?id=125578
                    I have now only this small one! (4 icons) against 5 & PopUp...It's yet fabulous! πŸ˜‰
                    https://i.postimg.cc/Pr5hjkBC/Add-Quad-Patch.jpg
                    • Gus RG Offline
                      Gus R
                      14 years later I discover Bezier Surface. What a great plugin. Working in SU 2022 Pro.
                      www.instagram.com/gusrobatto/
                      www.facebook.com/gusrobatto
                      • Gus RG Offline
                        Gus R
                        I'm getting the same but then again it's a 14 year old plugin. Works nice.
                        • 11
                        • 12
                        • 13
                        • 8 / 13
