    3D Truss Models
    1.5k Posts 31 Posters 937.0k Views 30 Watching
    • medeekM Offline
      medeek
      Version 3.3.1b - 09.04.2023
      • Refined the framing algorithm for hip, valley and flying hip rafters.
      http://design.medeek.com/resources/trussplugin/images3/truss_su804_800.jpg
      All of the major framing members are now being drawn however the trimming of certain rafters is still not quite correct, further refinement and correction will be necessary.
      I've also noticed that with certain large roof planes an occasional stray edge is generated (or left behind when the roof primitive is created), I will need to look into this further and rectify the issue. It does not appear to be a critical error but it does effectively split the roof plane into to separate faces which then makes the plugin treat the roof plane as two separate faces.
      With the flying hips terminating adjacent to valley rafters I'm not entirely sure how that is typically framed.
      Please download and test this latest release and then email me comments or suggestions directly.
      Nathaniel P. Wilkerson PE
      Medeek Engineering Inc
      design.medeek.com
      • medeekM Offline
        medeek
        Version 3.3.1c - 09.05.2023
        • Minor bug fix within the rafter framing module for complex roofs.
        design.medeek.com
        • medeekM Offline
          medeek
          Version 3.3.1d - 09.09.2023
          • Fixed a bug within the global settings for complex roofs.
          • Updated the straight skeleton algorithm to better remove redundant edges within roof planes/faces.
          • Improved the robustness of the complex roof module (framing and cladding) for specific cases.
          http://design.medeek.com/resources/trussplugin/images3/truss_su806_800.jpg
          The complex roof module is now a bit more robust than it was and should be able to handle more cases than it did previously.
          However there still does exist the special cases where the fascia line is not all on one level that is still not possible to draw. The discussion on that topic is presented in this video:
          Hip and Ridge is still pending. Previously I was unable to fully work out the algorithm in order to deal specifically with flying hips. I will need to give this another hard look and see if my topological problem solving skills have improved since 2021.
          design.medeek.com
          • medeekM Offline
            medeek
            Version 3.3.2 - 09.17.2023
            • Added statistics for complex roofs (Medeek Estimator integration).
            http://design.medeek.com/resources/trussplugin/images4/truss_su809_800.jpg
            design.medeek.com
            • medeekM Offline
              medeek
              Tutorial 25: Estimating Complex Roofs (13:13 min.)
              design.medeek.com
              • medeekM Offline
                medeek
                Version 3.3.3 - 09.22.2023
                • Improved the responsiveness of the "Edit Roof Plane" tool and the "Move Roof Edge" tool for complex roofs.
                Previously when a complex roof was positioned on top of any wall assemblies and either of the two tools mentioned above were executed there existed the possibility of collinear edges with the roof assembly and the wall assemblies below. This conflict would then not allow one to properly select the desired roof edge unless the wall assemblies were hidden, or put on a hidden tag/layer. This fix should mitigate that problem and allow one to select a roof edge (on the roof outline) without having to take that additional step.
                I highly recommend upgrading to this latest version if you are using complex roofs.
                design.medeek.com
                • medeekM Offline
                  medeek
                  Version 3.3.4- 10.01.2023
                  • Added a "Complex Roof" tab to the Global Settings.
                  • Added a "Roof Framing" and "Advanced Options" parameter to the Complex Roof tab of the Global Settings.
                  • Added a "Primitive" option to the roof framing parameter within the Draw and Edit menus for complex roofs.
                  • Enabled the Up Arrow key as a method to toggle between "face" or "polygon" mode within the complex roof draw tool.
                  Tutorial 26: Complex Roof Primitives (6:42 min.)
                  design.medeek.com
                  • medeekM Offline
                    medeek
                    Version 3.3.4b - 10.02.2023
                    • Added a "Draw Mode" parameter to the Complex Roof tab of the Global Settings.
                    • Enabled a vertex (roof plane) selection method within the face selection algorithm of the Draw tool for complex roofs.
                    Tutorial 27: Drawing Complex Roofs (6:01 min.)
                    design.medeek.com
                    • medeekM Offline
                      medeek
                      Tutorial 28: Drawing Complex Gable Roofs (4:16 min.)
                      design.medeek.com
                      • medeekM Offline
                        medeek
                        Version 3.3.5 - 10.06.2023
                        • Sheathing Vertical Offset parameters added for common and monopitch trusses.
                        • Cladding Vertical Offset parameters added for common and monopitch trusses.
                        http://design.medeek.com/resources/trussplugin/images4/truss_su814_800.jpg
                        http://design.medeek.com/resources/trussplugin/images4/truss_su815_800.jpg
                        By customer request.
                        This feature is already implemented within the Wall plugin so it is about time that I bring the Truss plugin up to speed as well. I think these four parameters are self explanatory enough that I don't need a tutorial video but if I do please let me know.
                        design.medeek.com
                        • medeekM Offline
                          medeek
                          Tutorial 29: Vertical Offset of Sheathing and Cladding (13:26 min.)
                          design.medeek.com
                          • medeekM Offline
                            medeek
                            I still need to come up with a good porch module for wrap around porches and the like, but in the meantime with some careful use of the SUBTRACT function one can get pretty close:
                            https://global.discourse-cdn.com/sketchup/original/3X/0/9/09f9f559c4c6f61f5a0612816fcb524005805248.jpeg
                            https://global.discourse-cdn.com/sketchup/original/3X/f/7/f73652609dcf04402c42a15847acad918669fae4.jpeg
                            The model can be viewed here:
                            3D Warehouse
                            (3dwarehouse.sketchup.com)
                            design.medeek.com
                            • medeekM Offline
                              medeek
                              Version 3.3.7 - 10.29.2023
                              • Enabled the "Edit Truss Assembly" function for symmetric cathedral trusses (imperial and metric units).
                              • Added ceiling gypsum for symmetric cathedral trusses.
                              • Fixed a minor bug with parellel chord trusses.
                              http://design.medeek.com/resources/trussplugin/images4/truss_su819_800.jpg
                              design.medeek.com
                              • medeekM Offline
                                medeek
                                Version 3.3.9 - 12.30.2023
                                • Updated and improved the license verification module.
                                • Disabled redundant logging to improve plugin performance.
                                design.medeek.com
                                • medeekM Offline
                                  medeek
                                  Version 3.4.0 - 01.11.2024
                                  • Added a "Primitive" option to the roof framing parameter within the Draw and Edit menus for the following rafter roofs: Gable, Shed, Shed (with ledger), Hip.
                                  • Added lower pitches to the draw menus for the following rafter roofs: Gable, Shed, Shed (with ledger), Hip.
                                  http://design.medeek.com/resources/trussplugin/images4/truss_su821_800.jpg
                                  design.medeek.com
                                  • medeekM Offline
                                    medeek
                                    Version 3.4.1 - 04.18.2024
                                    • Fixed a compatibility bug with SketchUp 2024 while maintaining compatibility with previous versions of SketchUp.
                                    design.medeek.com
                                    • medeekM Offline
                                      medeek
                                      Version 3.4.2 - 04.23.2024
                                      • Fixed a compatibility bug with SketchUp 2024 (Fixnum & Bignum) while maintaining backward compatibility with previous versions of SketchUp.
                                      design.medeek.com
                                      • medeekM Offline
                                        medeek
                                        Version 3.4.3 - 04.30.2024
                                        • Added ceiling gypsum for tray and coffer trusses.
                                        • Enabled the "Edit Truss Assembly" function for tray and coffer trusses (imperial and metric units).
                                        • Enabled labels for tray and coffer trusses.
                                        • Updated the license verification system with a more secure and improved algorithm.
                                        http://design.medeek.com/resources/trussplugin/images4/truss_su822_800.jpg
                                        design.medeek.com
                                        • medeekM Offline
                                          medeek
                                          [b]Version 3.4.4[/b] - 05.02.2024
                                          • Added ceiling gypsum for cambered and mono cathedral trusses.
                                          • Enabled the “Edit Truss Assembly” function for cambered and mono cathedral trusses (imperial and metric units).
                                          • Enabled labels for cambered and mono cathedral trusses.
                                          • Fixed some minor bugs for mono cathedral trusses.
                                          alt text
                                          alt text
                                          design.medeek.com
                                          • medeekM Offline
                                            medeek
                                            Version 3.4.5 - 05.10.2024
                                            • Enabled ceiling insulation for shed rafter roofs: Batt, Blown-in.
                                            • Enabled ceiling insulation for gable rafter roofs: Batt, Blown-in.
                                            • Enabled ceiling insulation for hip rafter roofs: Batt, Blown-in.
                                            • Enabled the "Edit Truss Assembly" function for all flat trusses (imperial and metric units).
                                            alt text
                                            alt text
                                            alt text
                                            alt text
                                            alt text
                                            design.medeek.com
                                            gullfoG 1 Reply Last reply Reply Quote 1
                                            • 19
                                            • 20
                                            • 21
                                            • 22
                                            • 23
                                            • 75
                                            • 76
                                            • 21 / 76
