    Medeek Wall Plugin
    1.5k Posts 27 Posters 1.1m Views 26 Watching
    • medeekM Offline
      medeek
      Version 3.2.4 - 08.02.2023
      • Fixed a minor bug with the SW module and SW materials.
      Nathaniel P. Wilkerson PE
      Medeek Engineering Inc
      design.medeek.com
      • medeekM Offline
        medeek
        Version 3.2.5 - 08.06.2023
        • Added two parameters to the Walls tab of the Global Settings for Wall Panelization.
        • Enabled wall panelization for rectangular walls.
        http://design.medeek.com/resources/wallplugin/images5/wall_su707_800.jpg
        http://design.medeek.com/resources/wallplugin/images5/wall_su708_800.jpg
        design.medeek.com
        • medeekM Offline
          medeek
          Version 3.2.5b - 08.06.2023
          • Added a hotkey (Up key) to toggle wall panelization ON or OFF within the Draw Wall tool/menu.
          design.medeek.com
          • medeekM Offline
            medeek
            Tutorial 39 - Wall Panelization (8:52 min.)
            design.medeek.com
            • medeekM Offline
              medeek
              Version 3.2.6 - 08.09.2023
              • Fixed a bug with stacked openings and plan dimensions.
              • Added "Subtractive Framing" to the Wall tab of the Global Settings.
              • Enabled "SUBTRACT_FRAMING" custom boolean subtraction for all wall types.
              This now gives us a workaround for non-aligned stacked windows and doors. This update per customer request.
              design.medeek.com
              • medeekM Offline
                medeek
                Tutorial 40 - Stacked Windows (10:40 min.)
                design.medeek.com
                • medeekM Offline
                  medeek
                  Version 3.2.7 - 08.25.2023
                  • Updated steel studs and plates for all wall types.
                  • Fixed a bug in the statistics module for the gable walls.
                  http://design.medeek.com/resources/wallplugin/images5/wall_su709_800.jpg
                  Previously the steel studs and plates were merely cosmetic, now the are modeled a bit more realistically (however less attractively in my opinion). This update was specifically requested by users who specialize in steel stud framing and who wanted a more accurate model (stud length and channels for top and bottom plates) when it comes to steel framing. The plugin was never initially designed for steel framing and because of that I still consider the steel framing option more of a cosmetic model than an actual realistic model, but this latest update gets us a little closer to that objective.
                  design.medeek.com
                  • medeekM Offline
                    medeek
                    Version 3.2.7b - 08.26.2023
                    • Minor updates to the window and door framing modules with regards to steel framing.
                    http://design.medeek.com/resources/wallplugin/images5/wall_su710_800.jpg
                    design.medeek.com
                    • medeekM Offline
                      medeek
                      Version 3.2.7c - 08.28.2023
                      • Additional updates for steel framing for metric templates/units.
                      design.medeek.com
                      • medeekM Offline
                        medeek
                        Version 3.2.8 - 09.07.2023
                        • Enabled a feature to selectively remove specific studs from any wall assembly.
                        http://design.medeek.com/resources/wallplugin/images5/wall_su712_800.jpg
                        Note that this feature/option is very similar to the recent truss removal feature added to the Truss Plugin for common trusses and attic trusses. I've had a number of requests to add something similar into the Wall Plugin so specific studs could be removed. This update is per multiple customer requests.
                        I may make a tutorial video for this new feature but I do think it is fairly self explanatory.
                        design.medeek.com
                        • medeekM Offline
                          medeek
                          Version 3.2.8b - 09.07.2023
                          • Fixed a bug with the shearwall edit tool.
                          • Added directional logic into the Move Opening Tool's text entry method.
                          design.medeek.com
                          • medeekM Offline
                            medeek
                            Tutorial 41 - Selective Stud Removal (5:37 min.)
                            design.medeek.com
                            • medeekM Offline
                              medeek
                              I now have a system in place for those interested in a "lifetime" (30 year) license for the mdkBIM bundle. If you do purchase the "lifetime" bundle license I will also throw in a lifetime license for the Electrical plugin. The cost is $980.00 USD which is 3.5X the regular bundle price of $280.00 USD.
                              If you are interested please email me direct and I will give you instructions how to proceed. The same 14 day refund policy applies, so please be aware of that (5% restocking fee):
                              Medeek Design Inc. - Refunds
                              (design.medeek.com)
                              A lifetime license means that you have free upgrades and no renewal fees for the next 30 years (until 2053).
                              design.medeek.com
                              • gullfoG Offline
                                gullfo
                                could you also do a 10 year? i'm pretty sure i'll be gone in 8... πŸ˜›
                                Glenn
                                http://www.runnel.com
                                • medeekM Offline
                                  medeek
                                  Version 3.2.9 - 09.14.2023
                                  • Fixed a critical bug with loading wall presets in the wall edit menu (metric and imperial).
                                  design.medeek.com
                                  • medeekM Offline
                                    medeek
                                    What should I charge if I did a 10 year?
                                    $280.00 X 2 = $560.00
                                    I would probably be more inclined to charge this for a 5 year license.
                                    design.medeek.com
                                    • medeekM Offline
                                      medeek
                                      I realize that for many of my older customers (myself included) a 30 year license really has no practical meaning and having to invest almost a thousand dollars is a lot for anyone.
                                      For those that do not want to outlay as much money but still would like to get a multi-year discount I am also offering a 5 year license for $560.00, so basically you are getting five years for the price of two, which is still a fairly substantial discount, but not as deep as the 30 year discount rate. Basically it would be equivalent to paying $112.00 per year for the mdkBIM bundle for a total of five years.
                                      design.medeek.com
                                      • medeekM Offline
                                        medeek
                                        To better fill the gaps in the mdkBIM Multi-year licensing I've decided to offer one additional licensing price point. The three permanent licensing options (multi-year) are:
                                        5 Year - $560.00 (Discount Code: MDK5YEAR)
                                        10 Year - $770.00 (Discount Code: MDK10YEAR)
                                        30 Year - $980.00 (Discount Code: MDKLIFE)
                                        Each price point offers a progressively steeper discount as the number of years of licensing increases.
                                        To purchase a lifetime license, login to the Account Manager and then click on the mdkBIM icon. Click on purchase mdkBIM Suite, then enter in one of the discount codes above. You will notice that the price will adjusted accordingly and the expiration update date will also reflect the multi-year license.
                                        As mentioned previously if a multi-year license is purchased I am also willing to thrown in the Electrical plugin license at no additional cost and its license will also reflect the same number of years as whatever multi-year option was chosen.
                                        design.medeek.com
                                        • medeekM Offline
                                          medeek
                                          Version 3.3.0 - 09.21.2023
                                          • Moved the Geometry Markers section from the General tab to the Walls tab in the Global Settings.
                                          • Added a geometry marker size parameter to the Walls tab of the Global Settings.
                                          The General tab of the Global Settings has become too large (or cluttered) and it made sense to move the geometry markers to the Walls tab. I also received a number of requests about making the geometry markers larger. So I figured, why not let the user customize them to the size they would like.
                                          http://design.medeek.com/resources/wallplugin/images5/wall_su713_800.jpg
                                          design.medeek.com
                                          • medeekM Offline
                                            medeek
                                            Version 3.3.1 - 09.27.2023
                                            • Fixed a bug with the labeling algorithm for the molding module.
                                            design.medeek.com
                                            • 16
                                            • 17
                                            • 18
                                            • 19
                                            • 20
                                            • 74
                                            • 75
                                            • 18 / 75
