    Curviloft gets a bit confused by the aperiodic monotile
    3 Posts 2 Posters 140 Views 2 Watching
      j_jones
      I wanted to play around with the aperiodic monotile: https://cs.uwaterloo.ca/~csk/hat/
      I made a few polygons based on a few animation steps and tried to use Curivloft to join them into a solid shape: https://cs.uwaterloo.ca/~csk/hat/examples/animation.gif
      However, Curviloft seems to get rather confused by these shapes. It wants to wrap the vertices around corners creating a twisty result, as illustrated here:
      aperiodic_monotile3.mp4
      Google Docs (drive.google.com)
      I think my main problem is when I run Curivloft, I am unable to use the rotate tool to move the model around and make corrections on all sides...
      aperiodic monotile and curviloft
      aperiodic_monotile2.skp
      Thanks for any suggestions
      j_jones
        Omit these edges...
        https://i.imgur.com/N747Zgx.png
        Run Loft by Spline...
        https://i.imgur.com/tHeQVJS.png
        You run run Loft by Spline again on this selection...
        https://i.imgur.com/nBEiq92.png
        To reduce the geometry count set the Segments to 1s...
        https://i.imgur.com/hhFXtt3.png
          j_jones
          @rich o brien said:
          Omit these edges...
          OMG, thank you!!
