    Object has 2 Track Points and Each Follow Different Path
    3 Posts 2 Posters 123 Views 2 Watching
      Papaspride Newcomers
      I have an object (electric boat motor) that has 2 tracking points along its mounting tube. Each tracking point follows separate path.
      The object must follow each path, rotating the object in such a way as to clear obstacles.
      This animation is a test of the arcs (paths).
      Can I use 2 paths simultaneously and if so how? Ideally a video describing how to do this would work for me.
      • fredo6F Offline
        I am afraid I don't understand the request. How could an object follow 2 paths?
          Think of an animated car fish tailing around a corner. The front wheels follow the path around the corner, while the back of the car swings away from the direction traveled around the corner, hence the car fish tails.
          I would imagine this animateted car has a second path which would control the back end of the car causing the car to appear to fish tail.
          I hope this illustrates what I'm after when I say object follows 2 paths.
          Thanks.
