Plugin test version
hello,
i am working on a small ifc-viewer. is it allowed to put a download link here for someone, who would like to make some testing?
thanx
stan -
You have access here?
no. do i have to apply for access?
Can you log out then visit sketchucation.com homepage and login?
Do you now see Dev Tools in the header?
If you click then you should get the dashboard to upload directly to the ExtensionStore, site etc...
Let me know if you have any questions
hi rich,
thanx for this, the dev tools are accessible.could you please activate the tools also for my new account, user: areal3d.
i would like to run the plugin under this label.thank you very much.
stan
i would like to run the plugin under this label.Hi Stan,
Try the same steps as above for areal3d and let me know
got it! thank you very much .
best regards.
stan -
Your first few posts on this account will need approval once you get past that you'll be off the leash
ok. understood.
question:
where do i have to implement the version of the plugin according to this message?
in the ruby file or in the sketchucation system?thanx
stan
edit: found the filed for the version......upload worked
thanx for helping me !!!!
stan
