    [Plugin] FredoGuides - v2.9a - 19 Dec 25
    55 Posts 17 Posters 64.9k Views 17 Watching
    • SJS66S
      SJS66
      Thanks for the update Fredo. V1.9a working like a charm. Awesome. I did notice still only compatible to 2020 on download post description though. Could be updated too maybe?
      • fredo6F
        NEW RELEASE: FredoGuides v2.0a - 24 Apr 21
        Requirements
        • LibFredo6: v11.0a
        FredoGuides v2.0a is a technical release for performance of contextual selection menu
        **Home Page of FredoGuides** for information and Download.
        Main post of this FredoGuides thread.
        • fredo6F
          NEW RELEASE: FredoGuides v2.1a - 04 Aug 21
          Requirements
          • LibFredo6: v11.0a
          FredoGuides v2.1a is a release for extension of validity
          • T
            thuonghoailinh
            @sjs66 said:
            I'm getting an error with FredoGuides v1.8a. If I try to use the toolbar, SU 2021 keeps telling me it's out of date but Fredo6 Plugins Update Check says everything is up to date!
            I uninstalled then downloaded the latest version & manually installed using Extension Manager but still getting same message.
            I swear it was working fine the other day.
            I STILL HAVE NOT CORRECTED THIS ERROR, YOU HAVE CORRECTED THIS
            • fredo6F
              What are you referring to? Which message do you get (current version is v2.1)?
              • fredo6F
                NEW RELEASE: FredoGuides v2.2a - 09 Jan 22
                Requirements
                • LibFredo6: v11.0a
                FredoGuides v2.2a is a release for extension of validity
                • fredo6F
                  NEW RELEASE: FredoGuides v2.3a - 27 May 22
                  Requirements
                  • LibFredo6: v12.9a
                  FredoGuides v2.3a is a release for extension of validity
                    rv1974
                    Opening Protection Guide toolbar is making files (even not-so-heavy) lag as hell - not usable. Closing it - everything is fine
                    • fredo6F
                      NEW RELEASE: FredoGuides v2.4a - 25 Dec 22
                      Requirements
                      • LibFredo6: v13.6a
                      FredoGuides v2.4a is a release for extension of validity
                        Dankmar
                        Hi Guys! I'm trying to download this plugin, but it says that the file can't be found.
                        Exatly the text is as follows:
                        /pluginrepo/rbz/
                        /var/www/html/pluginrepo/rbz/FredoGuides.rbz
                        File does not exist. Make sure you specified correct file name.
                        It appears on a new page as soon as I click the red download button.
                        Thanks in advance!
                        UPDATE: Fixed. Just downloaded. Thanks a lot!!
                        • fredo6F
                          NEW RELEASE: FredoGuides v2.5a - 30 Dec 23
                          Requirements
                          • LibFredo6: v13.6a
                          FredoGuides v2.5a is a release for extension of validity
                          • fredo6F
                            NEW RELEASE: FredoGuides v2.6a - 02 Apr 24
                            Requirements
                            • LibFredo6: v13.6a
                            FredoGuides v2.5a is a maintenance release for
                            • Future compatibility
                            Home Page of FredoGuides for information and Download.
                            • F
                              FlorinAp
                              This one doesn't work - everything seems to be fine, but at a later time, when I open the model (second or third time...), I'm able to delete all the guides, although Fredo Guides report them (and show them) as being locked.
                              Tried and tested in SU 2022, 2023, and 2024.!
                              This extension is one and only, but until it is fixed I'm using EA Locked Guide, which works pretty well, but is infinitely simpler than Fredo Guides.
                              • fredo6F
                                NEW RELEASE: FredoGuides v2.7a - 31 Dec 24
                                Requirements
                                • LibFredo6: v13.6a
                                FredoGuides v2.7a is a release for extension of validity
                                • B
                                  buffalosky49
                                  Is there an update for FredoGuides 2.7a?
                                  • fredo6F
                                    NEW RELEASE: FredoGuides v2.8a - 01 Jun 25
                                    Requirements
                                    • LibFredo6: v14.3a
                                    FredoGuides v2.8a is a release for extension of validity
                                    • fredo6F
                                      NEW RELEASE: FredoGuides v2.9a - 19 Dec 25
                                      Requirements
                                      • LibFredo6: v15.6a
                                      FredoGuides v2.9a is a release for extension of validity
                                      • 3 / 3
