    Here is how you can use PhotoMatch with cropped photos
    19 Posts 7 Posters 8.7k Views 7 Watching
    • thosfordT
      thosford
      @davidboulder said:
      By the way, I also believe it should be pretty easy to model one point perspective. I'll post on that another time.
      David,
      Were you ever able to figure out how to photo match a one point perspective?
      I did a quick search but couldn't find anyone with a solution.
      Thanks,
      Todd
      • mitcorbM
        mitcorb
        @Todd:
        You just unearthed an ancient thread that has mentions of things being wished for in Sketchup 9.
        • DavidBoulderD
          DavidBoulder
          @thosford said:
          David,
          Thanks,
          Todd
          Kind of, although not quite a one point perspective. If you have a situation like a main street where you have a bunch of connected facades where you only see the front of the building, but not the sides; I have a solution. Take a picture, but not straight on, shoot the photo off to the side a little so you have an x or y vanishing point. So how to you get a second vanish point? you cheat, Tilt the camera up or down so the z vanishing is your second one. To get this to work in Match Photo, before you import your photo, setup a special axes setup where you take the blue axis that is normally vertical and set it instead for your unknown x or y. Then that x or y axis becomes vertical z axis for your photo match scene. In essence if you turn your photo 90 degree sideways, it is like a normal old match photo. You are just changing which Axis Sketchup determines for you without having to really having to rotate your photo. This same technique allows you to use Match Photo on a building that doesn't have any 90 degree angles in plan, however you now need walls that are vertical, which should cover most buildings, but certainly not all. I don't have a tutorial up now, but I can try to make one when I get a chance.
          David Goldwasser
          OpenStudio Developer
          National Renewable Energy Laboratory
          • Alan FraserA
            Alan Fraser
            The picture book version. I'm assuming that you can have the image any size/proportion you like, as long as the all-important centre of perspective is smack in the middle.
            Jakob, those of us who attended Basecamp 1 and saw David demo Photomatch before it's launch (except it wasn't called Photomatch back then) already know who he is. 😉
            3D Figures
            • DavidBoulderD
              DavidBoulder
              Sorry I missed the 2011 activity here. It is a shame that in 2013 I still can't have auto-calibrated photo match scenes that work with any photo 😞
              Alan, your drawing describes the technique much more clearly.
              David
              David Goldwasser
              • mitcorbM
                mitcorb
                I must be missing something in establishing the start point for the uncropped outline. The bottom is coincident with the bottom of the image, but how is the left side established?
                • DavidBoulderD
                  DavidBoulder
                  You could just keep it coincident with the left as well. In Alan's drawing he might have just been trying to maintain the same aspect ratio as his starting photo.The main goal is to re-center the image. You can't really tell how much of the original photo was cropped, just that it was cropped in a way that moved the center. This technique just expands one or two of the for sides to re-create the original center point.
                  If you took a good photo and cropped x" off both the left and the right, and then y" off the top and bottom MatchPhoto would work fine. The real problems are introduced when you crop X" from the left and Y" from the right.
                  David Goldwasser
                  • mitcorbM
                    mitcorb
                    Thanks, David. Your explanation clears that up for me.
                    • E
                      efeme75
                      Hi David,
                      Does your method work with any kind of photographs, or are there limitations to the orientation of the camera vs. horizon?
                      Did you continue to work on the subject?
                      • DavidBoulderD
                        DavidBoulder
                        efeme75 I have not done anything this this in a while, although there are more photogrammetry and LIDAR based options out now that may be more automated that PhotoMatch. With the approach from this thread, the orientation of the photo relative to the horizon doesn't matter, but it does require an orthogonal object in the scene large enough to find vanishing points, and create perpendicular lines as shown in Alan's example.
                        David Goldwasser
                        • E
                          efeme75
                          Dear David,
                          Pursuant to my last message, please find illustrations of your method in 4 cases (the edge colors are identical to the ones in Alan's attachment). In the first one (upper left uncropped image), the parallelepiped box is centred, and the resulting Central Point as well. In all other cases where the box is not centred in the uncropped image, the resulting Central Point is not in the centre of the image... Any thoughts?
                          • DavidBoulderD
                            DavidBoulder
                            Its a little hard to work with the small thubnails but the bottom two phots pretty clearly have misplaced vertical vanishing point. The top right is a big tricker to tell, with the camera plane seemingly in line with the top of the box, very small movement in the left or right vanishing point will swing the magenta line form vertical vanishing left or right. In three of the photos I've added new yellow vanishing point triangle, and new magenta lines perpendicular to the horizons. I've added while ring where the magenta lines cross.
                            annotated on top of image from last post
                            David Goldwasser
                            • E
                              efeme75
                              Central point determination-1.jpgCentral point determination-2.jpgDear David, Thousand apologies, my sloppiness and Sketchup's inferences caused the inaccuracies of my initial central point's graphical determination (see corrected drawing). In a second attachment, the superposition of the original photograph (magenta edge), the yellowish cropped image), the greenish reconstructed uncropped photo show the usefulness of the method. Since I am dealing with 1900 photos, LIDAR and other techniques aren't really helpful here... Many thanks for diving in after so many years!
