    [Plugin] Get Tags and Hide
    6 Posts 2 Posters 2.6k Views 2 Watching
      Architure
      Hi there,
      I don't know how to proceed to share a plugin I've just posted on the extension warehouse. It is a simple but effective plugin that allows you to hide tags, from the active selection of a scene, in all other scenes.
      How many times have you been in the situation that you built perfect scenes, well organized with tags visibility from one scene to another, then at "scene20" you decide to add object with new tags and all you previous tags visibility in other scenes become a mess...
      So I made this plugin to share with the community.
      SketchUp Extension Warehouse
      Your library of custom third-party extensions created to optimize your SketchUp workflow.
      (extensions.sketchup.com)
      The conditions to make it work is to have at least 2 scenes and not to use untagged layer. You have to select the objects to hide, and their tags will not be visible anymore in other scenes that the active one.
      Manu
        Would you like to add it to our repo too?
          Architure
          Yes, would be nice. Do you manage that, or do I have to do it myself? Let me know how
            If you logout and then login on our homepage you should see Dev Tools in the menu.
            Once there you can create an entry for your extension.
            https://i.imgur.com/BhWw0eY.png
            If you run into any probs let me know.
              Architure
              Done
              There it is:
              SketchUp Plugins | PluginStore | SketchUcation
              SketchUp Plugin and Extension Store by SketchUcation provides free downloads of hundreds of SketchUp extensions and plugins
              (sketchucation.com)
              Thank you Rich
                @architure said:
                Thank you Rich
                Lovely, thanks for sharing here. Feel free to poke around our API. Or ignore it. Up to you.
                Also Fredo Licensing system is available to devs here to use.
