    Foundation Plugin
    439 Posts 15 Posters 415.1k Views 15 Watching
    • medeekM Offline
      medeek
      Tutorial 11 - Windows and Doors (13:00 min.)
      Nathaniel P. Wilkerson PE
      Medeek Engineering Inc
      design.medeek.com
      • medeekM Offline
        medeek
        I've been giving the Basement Entrance some more thought and I've come up with the following parameters for this option:
        1.) Entrance Direction: Left, Right or Center
        2.) Stemwall Height
        3.) Stemwall Thickness
        4.) Footing Width
        5.) Footing Depth
        6.) Landing Width
        7.) Landing Depth
        8.) Slab Thickness
        9.) No. of Steps
        10.) Riser Height
        11.) Tread Depth
        12.) Tread Overhang
        13.) Nosing Radius (Typically 1/2")
        Let me know if I am missing anything.
        design.medeek.com
        • medeekM Offline
          medeek
          Version 1.8.4 - 03.16.2022
          • Enabled entry stairs for polyline stemwall openings: Left, Right and Center.
          http://design.medeek.com/resources/foundationplugin/images2/foundation_su108_800.jpg
          http://design.medeek.com/resources/foundationplugin/images2/foundation_su109_800.jpg
          Note: I did not enable the radius for the nosing on the treads but I think this additional feature or lack thereof is not a major issue since it is purely cosmetic in my opinion. If there is enough additional demand for it I will look into it further.
          I also have not added any option for rebar into this concrete sub-assembly. Again, I will address that further if there is additional interest or requests for it.
          design.medeek.com
          • medeekM Offline
            medeek
            Version 1.8.5 - 03.20.2022
            • Fixed a bug with windows and doors when a polyline stemwall is in a RIGHT direction/configuration.
            • Added a "TRIAL" licensing notice at SketchUp startup to alert users to activate their license/serial numbers if running in trial mode.
            http://design.medeek.com/resources/foundationplugin/images2/foundation_su111_800.jpg
            design.medeek.com
            • medeekM Offline
              medeek
              Q: Can you do curved stemwalls?
              A: Multi-segment stemwalls are possible with the polyline stemwall tool however there is no function for a true curved stemwall. With enough segments one can approximate a curved wall as shown below:
              https://aws1.discourse-cdn.com/sketchup/original/3X/4/4/44974b520862d45fab41aae457d7056921d736ff.jpeg
              design.medeek.com
              • medeekM Offline
                medeek
                A couple of requests today for a grade beam option/tool:
                https://aws1.discourse-cdn.com/sketchup/original/3X/5/7/5749235b74fa0e73f392f4b8a139fa776a05e559.jpeg
                I think it is probably a good feature to add, with top and bottom bar and stirrups.
                design.medeek.com
                • medeekM Offline
                  medeek
                  Getting a little closer, now I just need to update the menus with all the new parameters:
                  https://aws1.discourse-cdn.com/sketchup/optimized/3X/6/b/6b30ff2fcde159dc1748bb64717dc8f18974ac13_2_555x499.jpeg
                  design.medeek.com
                  • medeekM Offline
                    medeek
                    Version 1.8.6 - 04.24.2022
                    • Enabled the "Draw Grade Beam" tool with the following geometry types: closed polyline, open polyline and line.
                    • Added longitudinal rebar for grade beams.
                    • Added hoop/stirrup rebar for grade beams.
                    http://design.medeek.com/resources/foundationplugin/images2/foundation_su115_800.jpg
                    design.medeek.com
                    • medeekM Offline
                      medeek
                      Tutorial 12 - Grade Beams (9:38 min.)
                      design.medeek.com
                      • medeekM Offline
                        medeek
                        So I drew this with the column and new grade beam module:
                        https://aws1.discourse-cdn.com/sketchup/original/3X/e/2/e24c8269689df9c916cbaecb3597d89f32de5fa1.jpeg
                        My oldest son then asked me, "What is it?"
                        My answer was, "I don't know, it's whatever you want it to be."
                        design.medeek.com
                        • medeekM Offline
                          medeek
                          I have begun posting older versions of the Foundation plugin for download but I would strongly encourage users to download and use the latest version of the plugin since I do not support older versions, especially if they are older than a year old. The number of bug fixes and feature additions make it very hard for me to keep track of which version addressed which issue. If you need support please make sure you have the latest version of the extension installed.
                          Medeek Design Inc. - Medeek Foundation Plugin Versions
                          (design.medeek.com)
                          Medeek Design Inc. - Medeek Foundation Changelog
                          Medeek Design Inc. - Medeek Foundation Plugin Changelog
                          (design.medeek.com)
                          design.medeek.com
                          • medeekM Offline
                            medeek
                            Version 1.8.7 - 07.31.2022
                            • Added slab depressions for rectangular and polygon slab assemblies.
                            • Enabled editing, moving and deleting of slab depressions for all slab assemblies.
                            • Added a "Regen" context menu item for polygon slab on grade (SOG) and slab assemblies.
                            http://design.medeek.com/resources/foundationplugin/images3/foundation_su117_800.jpg
                            design.medeek.com
                            • medeekM Offline
                              medeek
                              Version 1.8.8 - 07.31.2022
                              • Added a "Regen" context menu item for column footings and stemwall step assemblies.
                              • Added the ability to customize the texture/material for stemwall foundations.
                              • Added a "Stemwall Texture" parameter into the Materials tab of the global settings.
                              http://design.medeek.com/resources/foundationplugin/images3/foundation_su118_800.jpg
                              http://design.medeek.com/resources/foundationplugin/images3/foundation_su119_800.jpg
                              http://design.medeek.com/resources/foundationplugin/images3/foundation_su120_800.jpg
                              The "4x8 form" texture option was per customer request.
                              design.medeek.com
                              • medeekM Offline
                                medeek
                                !!!! BUG ALERT - SKETCHUP 2023 !!!!
                                I've just identified an issue with the Foundation plugin and the current release of SU 2023.
                                Many of the tools within the Truss plugin still use the UI.inputbox module for simple menus, see example below:
                                https://global.discourse-cdn.com/sketchup/original/3X/a/b/ab1923aa13e5f1d3fef95de34704e24cd0acdaf0.jpeg
                                If you notice that this type of menu appears (not an HTML menu) then press Alt-Tab which will then require you to refocus on the menu with your mouse and will also allow it to function correctly (unfreezes the menu).
                                I don't know all of the details however it appears that the backend framework has extensively changed and in the process a few focus bugs have slipped through and need to be ironed out with SU 2023. See status and more details at the thread below:
                                SketchUp 2023 - changes to UI.inputbox focus?
                                Question for the proper coders: A case of three ruby plugins; a plugin with a floating quad menu with my most-used commands - pressing items launches other plugins. a plugin that directly launches a UI.inputbox a plug…
                                SketchUp Community (forums.sketchup.com)
                                For now I would recommend staying with SU 2022 if you extensively use SketchUp combined with the Truss and Foundation plugins. However the alt-tab work around should also keep you up and running if you have already migrated to SU 2023.
                                I am hoping that minor update will be forthcoming in the near future from SketchUp, which will save me from having to rewrite a significant amount of code and pull me away from the Floor plugin development. If the bug is not fixed I will proceed to switch all remaining menus in the Truss and Foundation plugins to HTML dialog type menus, that process could take upwards of two to three weeks.
                                design.medeek.com
                                • medeekM Offline
                                  medeek
                                  Version 1.9.0 - 07.11.2023
                                  • Fixed a minor bug with the "Edit Outline" menus for various foundation types.
                                  design.medeek.com
                                  • medeekM Offline
                                    medeek
                                    Version 1.9.1 - 09.26.2022
                                    • Added a negative X and negative Y slope direction for slab depressions.
                                    http://design.medeek.com/resources/foundationplugin/images3/foundation_su121_800.jpg
                                    design.medeek.com
                                    • medeekM Offline
                                      medeek
                                      Version 1.9.2 - 11.30.2023
                                      • Enabled Openings for stemwall steps: Windows and Doors.
                                      • Enabled Blockouts for stemwall steps.
                                      http://design.medeek.com/resources/foundationplugin/images3/foundation_su122_800.jpg
                                      This update per customer request. Now openings and blockouts can be used in either polyline stemwalls or stemwall steps.
                                      design.medeek.com
                                      • medeekM Offline
                                        medeek
                                        Version 1.9.3 - 12.16.2023
                                        • Fixed a bug with drain pipes for polyline stemwall foundations which have openings or blockouts enabled.
                                        design.medeek.com
                                        • medeekM Offline
                                          medeek
                                          Version 1.9.4 - 01.07.2024
                                          • Updated and improved the license verification module.
                                          • Disabled redundant logging to improve plugin performance.
                                          design.medeek.com
                                          • medeekM Offline
                                            medeek
                                            Version 1.9.5 - 02.13.2024
                                            • Improved the serial number verification logic within the License tab of the Global Settings.
                                            • Updated the javascript logic within the License tab of the Global Settings.
                                            • Added statistics for the following foundation types (Medeek Estimator integration): Slab-on-Grade, Slab, Stemwall, Grade Beam
                                            design.medeek.com
                                            • 16
                                            • 17
                                            • 18
                                            • 19
                                            • 20
                                            • 21
                                            • 22
                                            • 18 / 22
