    [Plugin] FredoTools::ColorByAltitude - v1.2a - 10 Jul 21
    26 Posts 7 Posters 24.5k Views 7 Watching
    • V Offline
      varioushemrog
      Bon Jour Fredo! πŸ˜„
      I found today your extensions. Thank you so much for creating all these wonderful tools!
      I use a Macbook Pro 2021 M1 not intel and installed today: LibFredo6 12.8a, TopoShaper 2.6a and FredoTools 4.3a
      Sadly ColorByAltitude is NOT showing in my toolbar and it shows in in pink in the "Check Fredo6 Plugins for Update".
      This is the reason I downloaded the FredoTools πŸ˜„ I need to color by altitude a 20 acre land.
      Please help!
      Thanks for all you do! (I will post a message under TopoShaper for I have a couple of questions I hope you can help me with too)
      Have a happy one!
      Helena
      • fredo6F Offline
        Could you show a screenshot of this.
        In principle, FredoTools::ColorByAltitude should work on Mac M1.
        • V Offline
          varioushemrog
          Hi Fredo! πŸ˜„
          Of course, here is the Screenshot.
          Merci beaucoup!
          Helena
          Showing Palette
          • fredo6F Offline
            Then, can you check the version of FredoTools. It cannot be v4.3a.
            • V Offline
              varioushemrog
              Hi Fredo,
              I went to Tools> FredoTools> About FredoTools 4.3 and it opens a window that says: "Fredo Tools 4.3a - 06 Mar 22"
              See attached screenshot please. πŸ˜„
              version
              • fredo6F Offline
                Your screenshot shows that you run Sketchup 2017.
                ColorByAltitude only works with SU2018 and above.
                So, it is normal you do not see it in the menu.
                  As Fredo6 points out your screen shot shows you are using 2017 Make. Your profile says you are using 2022 Pro. Do you actually have 2022 Pro? If so, try FredoTools in that version. If not, please correct your profile. The wrong information makes it more difficult for us to help you.
                  • V Offline
                    varioushemrog
                    Thanks! I thought I had downloaded the Pro! I am on the trial and going to buy the Pro. Maybe while in the Trial it downloads the Make? Anyhow, thanks. I will purchase the version Pro next week. πŸ˜„
                      Uh, no. If you had downloaded SketchUp 2022 it would show as SketchUpPro 2022. There is no Make version of 2022.
                      • V Offline
                        varioushemrog
                        Yes, thanks, I saw that. As I said above. I will have to re-download it and make sure I get the 2022 Pro this time.
                        • 2 / 2
