    [Plugin] FredoTools::ColorByAltitude - v1.2a - 10 Jul 21
    26 Posts 7 Posters 24.3k Views 7 Watching
    • fredo6F Offline
      @cotty said:
      I think the most useful slope would be the maximum value for each face, something like the magnitude of the gradient: "it has the direction of fastest increase of the function at P, and its magnitude is the rate of increase in that direction." [Wikipedia]
      In fact I know more or less what to do to manage a continuous mapping of slope in any point of a face, since we compute the local gradient. The issue is that I cannot map a single texture for all faces, but would need individual texture by face. So it's a little bit overkill for the problem, which is mainly to visualize technicall the low and high slopes.
        • fredo6F Offline
          NEW RELEASE: ColorByAltitude 1.1e - 02 Nov 19
          ColorByAltitude 1.1a includes cosmetic adjustments and bug fixing.
          It is available as of FredoTools v3.7a.
          See FredoTools plugin home page for Download.
          See also main post of this thread for User Discussion.
          • zooenZ Offline
            zooen
            Bonjour,
            Je ne comprends pas, je n'ai pas la rampe de couleurs sur la gauche de la boîte de dialogue. Dans la vidéo elle est présente dès l'ouverture de la boîte de dialogue. J'ai désinstallé puis réinstallé FredoTools_v3.8c et il me manque aussi des icônes dans le lanceur FredoTools.
            Quelqu'un a-t-il une réponse?
            I don't understand, I don't have the color ramp on the left of the dialog. In the video it is present from the opening of the dialog box. I uninstalled and then reinstalled FredoTools_v3.8c and I'm also missing icons in the FredoTools launcher.
            Anyone have an answer?
            • fredo6F Offline
              Which version of Windows?
              Do you have the latest version of LibFredo6 (v9.5k)?
              • zooenZ Offline
                zooen
                Bonsoir Fredo,
                Merci de répondre aussi rapidement. Je suis bien à jour: 9.5k et je suis sous Win 10 Pro.
                Zooen
                • fredo6F Offline
                  There seems to be a problem with the SVG files in the default web browser (and also a problem for supporting Canvas). With Windows 10, this should be OK, unless you did something to the browser and still have an old version of IE.
                  Also, with LibFredo6 v9.5k, you should have a small eye icon on the right of each line.
                  • zooenZ Offline
                    zooen
                    Thank you for the answer,i do not use IE as a browser!
                    I look at that and come back to you to inform you of the rest.
                    Merci pour la réponse, je n'utilise pas IE comme navigateur!
                    je regarde ça et reviens vers toi pour t'informer de la suite.
                    Zooen
                    • zooenZ Offline
                      zooen
                      Bonjour,
                      J'ai fait deux ou trois choses pour essayer de résoudre le problème (et comprendre la teneur de ton message).
                      J'ai installé SU 2020 sur mon portable (Win 8.1) avec Mozilla firefox comme navigateur par défaut (c'est toujours celui que j'utilise depuis des années) en y associant les SVG, pour voir si j'avais le même problème. Avec uniquement les extensions et plugins suivants:
                      Sketchucation plugin store et tes plugins et extensions.
                      j'ai fait un test avec avec ColorByAltitude Avec les trois variantes de dégradé, cela fonctionne (il y a déjà un progrès 😄 ). La matière est présente et varie en fonction de la variante choisie : Géographique, Niveaux de gris et Arc-en-ciel.
                      J'ai fait la même association SVG sur mon ordi de Bureau, même résultat c'est OK.
                      Mais je n'ai toujours pas la rampe et les icônes (voir la capture d'écran).
                      Quant à "Canvas" j'ai fais quelques recherches sur le net pour voir et comprendre ce que c'est, bon cela reste assez flou pour moi.
                      TruePaint et les autres plugins que j'utilise fonctionnent très bien aussi et je n'ai pas de problème d'affichage pour eux.
                      Voilà où j'en suis. Notre échange devrait-il sur faire sur le forum français?
                      Zooen
                      • V Offline
                        varioushemrog
                        Bon Jour Fredo! 😄
                        I found today your extensions. Thank you so much for creating all these wonderful tools!
                        I use a Macbook Pro 2021 M1 not intel and installed today: LibFredo6 12.8a, TopoShaper 2.6a and FredoTools 4.3a
                        Sadly ColorByAltitude is NOT showing in my toolbar and it shows in in pink in the "Check Fredo6 Plugins for Update".
                        This is the reason I downloaded the FredoTools 😄 I need to color by altitude a 20 acre land.
                        Please help!
                        Thanks for all you do! (I will post a message under TopoShaper for I have a couple of questions I hope you can help me with too)
                        Have a happy one!
                        Helena
                        • fredo6F Offline
                          Could you show a screenshot of this.
                          In principle, FredoTools::ColorByAltitude should work on Mac M1.
                          • V Offline
                            varioushemrog
                            Hi Fredo! 😄
                            Of course, here is the Screenshot.
                            Merci beaucoup!
                            Helena
                            Showing Palette
                            • fredo6F Offline
                              Then, can you check the version of FredoTools. It cannot be v4.3a.
                              • V Offline
                                varioushemrog
                                Hi Fredo,
                                I went to Tools> FredoTools> About FredoTools 4.3 and it opens a window that says: "Fredo Tools 4.3a - 06 Mar 22"
                                See attached screenshot please. 😄
                                version
                                • fredo6F Offline
                                  Your screenshot shows that you run Sketchup 2017.
                                  ColorByAltitude only works with SU2018 and above.
                                  So, it is normal you do not see it in the menu.
                                    As Fredo6 points out your screen shot shows you are using 2017 Make. Your profile says you are using 2022 Pro. Do you actually have 2022 Pro? If so, try FredoTools in that version. If not, please correct your profile. The wrong information makes it more difficult for us to help you.
                                    • V Offline
                                      varioushemrog
                                      Thanks! I thought I had downloaded the Pro! I am on the trial and going to buy the Pro. Maybe while in the Trial it downloads the Make? Anyhow, thanks. I will purchase the version Pro next week. 😄
                                        Uh, no. If you had downloaded SketchUp 2022 it would show as SketchUpPro 2022. There is no Make version of 2022.
                                        • V Offline
                                          varioushemrog
                                          Yes, thanks, I saw that. As I said above. I will have to re-download it and make sure I get the 2022 Pro this time.
