    Foundation Plugin
    439 Posts 15 Posters 433.4k Views 15 Watching
    • medeekM Offline
      medeek
      Version 1.8.2 - 03.03.2022
      • Enabled window and door bucks for polyline stemwall openings.
      http://design.medeek.com/resources/foundationplugin/images2/foundation_su94_800.jpg
      http://design.medeek.com/resources/foundationplugin/images2/foundation_su95_800.jpg
      Nathaniel P. Wilkerson PE
      Medeek Engineering Inc
      design.medeek.com
      • medeekM Offline
        medeek
        To be honest I've never actually had to deal with a basement door opening in any of my various projects (design or structural) so now I have a bunch of questions.
        Notice that typical prehung door frame is not deep enough to span two 2x4's and a 1/2" air gap:
        https://aws1.discourse-cdn.com/sketchup/original/3X/e/6/e6b32e6674f250ad04f27f9c9bd32e7b696119bc.jpeg
        So how is this typically framed out and trimmed? Are there special order door frames that are deeper that can better accommodate this situation?
        *Note: I have not shown the brickmould that would trim out the exterior of the door and cover the door buck.
        design.medeek.com
        • medeekM Offline
          medeek
          https://aws1.discourse-cdn.com/sketchup/original/3X/b/3/b3dbd0dd7caffaf1043fb5ee727ad6c972b4eead.jpeg
          Something along these lines for an inswinging door (however I have shown the door frame and jamb extension as a single solid for simplicity).
          Also note that I have shown the brickmould as 2.25" however 2" is a more common width so there would probably be a 1/4" gap between the brickmould and concrete (caulking).
          https://azekexteriors.com/images/products/moulding/moulding-options/AZM-180_Brick_Mould.png
          design.medeek.com
          • medeekM Offline
            medeek
            First look at doors installed within the foundation plugin:
            https://aws1.discourse-cdn.com/sketchup/original/3X/3/d/3d75eb3c87a3f514328507e63248c000921360de.jpeg
            design.medeek.com
            • medeekM Offline
              medeek
              Still a few details to work out with the door and window opening module.
              https://aws1.discourse-cdn.com/sketchup/original/3X/4/4/44c3487b8d6aaa6400e27eab04efe1673a76e3ce.gif
              design.medeek.com
              • gullfoG Offline
                gullfo
                one thought - maybe create a windows and doors module and only add the bucks for the doors and windows in the foundation. then the windows and doors modules become reusable across your other products. also maybe the option to apply commercial product names / models, etc, even if minimal drawing detail, so the reporting shows up as a commercial product (e.g Pella)
                Glenn
                http://www.runnel.com
                • medeekM Offline
                  medeek
                  As I am wrapping up the details on the new window and door module of the foundation plugin it occurred to me that it might also be useful to have a basement entrance option:
                  https://aws1.discourse-cdn.com/sketchup/optimized/3X/8/f/8f01b795bb20cfce47ee5ca9336b24b77171eb61_2_622x500.jpeg
                  https://aws1.discourse-cdn.com/sketchup/optimized/3X/1/7/17eaa98114ff3ea5d309006bfb68523e4c06dcbc_2_358x500.jpeg
                  A whole bunch more parameters with this option (ie. number of steps, landing width and length etc...) but it would actually be quite easy to code.
                  I would probably have three directional options (Left, Right and Center).
                  The problem with this option would be much the same as every other option, I need to make it as flexible as possible for it to be useful but not overly complex (too many parameters).
                  I'm also looking for some plans for this type of entrance to better educate me on what is common practice.
                  Any thoughts in this regard?
                  design.medeek.com
                  • medeekM Offline
                    medeek
                    Version 1.8.3 - 03.10.2022
                    • Enabled the installation of windows and doors for polyline stemwall openings.
                    • Enabled lumber and pressure treated lumber textures in the Materials tab of the Global Settings.
                    • Added a door and window opening tool to the Stemwall Opening Toolbar.
                    • Animation option added to the General tab of the Global Settings.
                    http://design.medeek.com/resources/foundationplugin/images2/foundation_su102_800.jpg
                    http://design.medeek.com/resources/foundationplugin/images2/foundation_su101_800.jpg
                    http://design.medeek.com/resources/foundationplugin/images2/foundation_su97_800.jpg
                    http://design.medeek.com/resources/images/foundation_opening_su_menu_active.jpg
                    http://design.medeek.com/resources/foundationplugin/images2/foundation_su105_800.jpg
                    This is a fairly substantial upgrade to the foundation plugin. Note that windows and doors can only be installed into "polyline" stemwalls, this new feature does not work with the legacy stemwall tool.
                    design.medeek.com
                    • medeekM Offline
                      medeek
                      Tutorial 11 - Windows and Doors (13:00 min.)
                      design.medeek.com
                      • medeekM Offline
                        medeek
                        I've been giving the Basement Entrance some more thought and I've come up with the following parameters for this option:
                        1.) Entrance Direction: Left, Right or Center
                        2.) Stemwall Height
                        3.) Stemwall Thickness
                        4.) Footing Width
                        5.) Footing Depth
                        6.) Landing Width
                        7.) Landing Depth
                        8.) Slab Thickness
                        9.) No. of Steps
                        10.) Riser Height
                        11.) Tread Depth
                        12.) Tread Overhang
                        13.) Nosing Radius (Typically 1/2")
                        Let me know if I am missing anything.
                        design.medeek.com
                        • medeekM Offline
                          medeek
                          Version 1.8.4 - 03.16.2022
                          • Enabled entry stairs for polyline stemwall openings: Left, Right and Center.
                          http://design.medeek.com/resources/foundationplugin/images2/foundation_su108_800.jpg
                          http://design.medeek.com/resources/foundationplugin/images2/foundation_su109_800.jpg
                          Note: I did not enable the radius for the nosing on the treads but I think this additional feature or lack thereof is not a major issue since it is purely cosmetic in my opinion. If there is enough additional demand for it I will look into it further.
                          I also have not added any option for rebar into this concrete sub-assembly. Again, I will address that further if there is additional interest or requests for it.
                          design.medeek.com
                          • medeekM Offline
                            medeek
                            Version 1.8.5 - 03.20.2022
                            • Fixed a bug with windows and doors when a polyline stemwall is in a RIGHT direction/configuration.
                            • Added a "TRIAL" licensing notice at SketchUp startup to alert users to activate their license/serial numbers if running in trial mode.
                            http://design.medeek.com/resources/foundationplugin/images2/foundation_su111_800.jpg
                            design.medeek.com
                            • medeekM Offline
                              medeek
                              Q: Can you do curved stemwalls?
                              A: Multi-segment stemwalls are possible with the polyline stemwall tool however there is no function for a true curved stemwall. With enough segments one can approximate a curved wall as shown below:
                              https://aws1.discourse-cdn.com/sketchup/original/3X/4/4/44974b520862d45fab41aae457d7056921d736ff.jpeg
                              design.medeek.com
                              • medeekM Offline
                                medeek
                                A couple of requests today for a grade beam option/tool:
                                https://aws1.discourse-cdn.com/sketchup/original/3X/5/7/5749235b74fa0e73f392f4b8a139fa776a05e559.jpeg
                                I think it is probably a good feature to add, with top and bottom bar and stirrups.
                                design.medeek.com
                                • medeekM Offline
                                  medeek
                                  Getting a little closer, now I just need to update the menus with all the new parameters:
                                  https://aws1.discourse-cdn.com/sketchup/optimized/3X/6/b/6b30ff2fcde159dc1748bb64717dc8f18974ac13_2_555x499.jpeg
                                  design.medeek.com
                                  • medeekM Offline
                                    medeek
                                    Version 1.8.6 - 04.24.2022
                                    • Enabled the "Draw Grade Beam" tool with the following geometry types: closed polyline, open polyline and line.
                                    • Added longitudinal rebar for grade beams.
                                    • Added hoop/stirrup rebar for grade beams.
                                    http://design.medeek.com/resources/foundationplugin/images2/foundation_su115_800.jpg
                                    design.medeek.com
                                    • medeekM Offline
                                      medeek
                                      Tutorial 12 - Grade Beams (9:38 min.)
                                      design.medeek.com
                                      • medeekM Offline
                                        medeek
                                        So I drew this with the column and new grade beam module:
                                        https://aws1.discourse-cdn.com/sketchup/original/3X/e/2/e24c8269689df9c916cbaecb3597d89f32de5fa1.jpeg
                                        My oldest son then asked me, "What is it?"
                                        My answer was, "I don't know, it's whatever you want it to be."
                                        design.medeek.com
                                        • medeekM Offline
                                          medeek
                                          I have begun posting older versions of the Foundation plugin for download but I would strongly encourage users to download and use the latest version of the plugin since I do not support older versions, especially if they are older than a year old. The number of bug fixes and feature additions make it very hard for me to keep track of which version addressed which issue. If you need support please make sure you have the latest version of the extension installed.
                                          Medeek Design Inc. - Medeek Foundation Plugin Versions
                                          (design.medeek.com)
                                          Medeek Design Inc. - Medeek Foundation Changelog
                                          Medeek Design Inc. - Medeek Foundation Plugin Changelog
                                          (design.medeek.com)
                                          design.medeek.com
                                          • medeekM Offline
                                            medeek
                                            Version 1.8.7 - 07.31.2022
                                            • Added slab depressions for rectangular and polygon slab assemblies.
                                            • Enabled editing, moving and deleting of slab depressions for all slab assemblies.
                                            • Added a "Regen" context menu item for polygon slab on grade (SOG) and slab assemblies.
                                            http://design.medeek.com/resources/foundationplugin/images3/foundation_su117_800.jpg
                                            design.medeek.com
                                            • 11
                                            • 12
                                            • 21
                                            • 22
                                            • 10 / 22
