    Some tips and tricks from out of the Box
    203 Posts 20 Posters 183.0k Views 20 Watching
    • BoxB Offline
      Making quick work of what would be a tedious job by using solid tools.
      I've used Split, but Difference is all you need if you just want the grid structure.
      https://i.imgur.com/PeiNTZ9.gif
        La fiรจvre d'Urbicande by Schuiten & Peeters ๐Ÿ˜‰
        • BoxB Offline
          This is one of those things you don't think of until you need it. Wanting to rotate something around a specific point can be problematic in certain circumstances.
          In this example you can see the whole group is off-center from the wanted rotation point and the normal rotate tool can be difficult to position on the very center. So by opening the group you can select all the groups and components and use the Move tool to rotate them all using the Wheel component's rotation handles.
          https://i.imgur.com/1svNbDV.gif
          • bazB Offline
            baz
            You need to get out more I reckon ๐Ÿ˜„ Come visit.
            PS: I have never understood the inclusion of the word 'from' in your subject title, is this deliberately ungrammerely or simply bad grammer?
            Or something else entirely, I s'pose.
            • BoxB Offline
              It's just a play on words, think outside the box, things from outside the box... not the normal way of thinking. and my user name is box. ๐Ÿ˜ฎ
              • bazB Offline
                baz
                Ok, bad grammere then. Cool.
                • BoxB Offline
                  I must admit I'm struggling to see the grammar problem. But I'll take your word for it.
                  • bazB Offline
                    baz
                    I was hoping it wouldn't come to this...how does this look?
                    Some tips and tricks out of the Box
                    • BoxB Offline
                      But they have come from me, therefore From out of the Box.
                      • bazB Offline
                        baz
                        i will delete these off top posts.
                        • BoxB Offline
                          No need, nobody in here except you and me to read them.
                          • bazB Offline
                            baz
                            Ok, I will concede the point.
                            Still shits me 'tho. xx
                            • bazB Offline
                              baz
                              I very much doubt that.
                              • bazB Offline
                                baz
                                Therefore, these things are 'Out of the Box'.
                                Therefore 'FROM' not required.
                                N'est Pas?
                                • BoxB Offline
                                  I think the fact you are struggling with it explains the meaning of the title, it is a neither one thing nor the other. It isn't only out of the box it is also out of the box and even some stuff in the box. On that rather ambiguous note I'm for my bed (as they colloquially say in one of the places I have lived, dreadful grammar tho). ๐Ÿ’š
                                  • BoxB Offline
                                    Fredoscale has the ability to change the plane that is used for scaling, allowing you to control the -1 scale of off axis objects, making for an easy mirror tool.
                                    https://i.imgur.com/ZU6FXfy.gif
                                    • tuna1957T Offline
                                      tuna1957
                                      Your never ending supply of โ€œtips and tricksโ€ is much appreciated ! Many many thanks for your efforts. ๐Ÿ‘ ๐Ÿ‘
                                        Technic of the Circle + inclined segment! ๐Ÿ˜Ž
                                        Was very efficient and yet seen at Kito Raupp more ten years ago! ๐Ÿ˜‰
                                        Many tricky things there! ๐Ÿ˜Ž
                                        • BoxB Offline
                                          And yes I have acknowledged Kito and posted links to his videos many times when I have shown these techniques elsewhere. Probably even earlier in this thread.
                                          • BoxB Offline
                                            Not a tip or trick just some fun with Fredo's Animator.
                                            https://i.imgur.com/nfNT2St.gif
                                            • 11
                                            • 10 / 11
