    Some tips and tricks from out of the Box
    203 Posts 20 Posters 242.3k Views 20 Watching
    • ntxdaveN
      ntxdave
      @box said:
      Surely the ipad has a context click option, tap and hold for example?
      Yes, Tao and hold will let you open in a tab but I have not figured out how to.pause or move backward.
      Press F1...thank me later
      • BoxB
        I've recently posted a couple of non extension thread techniques elsewhere, in truth tho they aren't really true threads because they have multiple 'paths'. So I just did this one for the hell of it, mistakes and all, and thought the best place to hide it was here.
        https://i.imgur.com/kdgCNDY.gif
        • BoxB
          Making quick work of what would be a tedious job by using solid tools.
          I've used Split, but Difference is all you need if you just want the grid structure.
          https://i.imgur.com/PeiNTZ9.gif
            La fiรจvre d'Urbicande by Schuiten & Peeters ๐Ÿ˜‰
            • BoxB
              This is one of those things you don't think of until you need it. Wanting to rotate something around a specific point can be problematic in certain circumstances.
              In this example you can see the whole group is off-center from the wanted rotation point and the normal rotate tool can be difficult to position on the very center. So by opening the group you can select all the groups and components and use the Move tool to rotate them all using the Wheel component's rotation handles.
              https://i.imgur.com/1svNbDV.gif
              • bazB
                baz
                You need to get out more I reckon ๐Ÿ˜„ Come visit.
                PS: I have never understood the inclusion of the word 'from' in your subject title, is this deliberately ungrammerely or simply bad grammer?
                Or something else entirely, I s'pose.
                • BoxB
                  It's just a play on words, think outside the box, things from outside the box... not the normal way of thinking. and my user name is box. ๐Ÿ˜ฎ
                  • bazB
                    baz
                    Ok, bad grammere then. Cool.
                    • BoxB
                      I must admit I'm struggling to see the grammar problem. But I'll take your word for it.
                      • bazB
                        baz
                        I was hoping it wouldn't come to this...how does this look?
                        Some tips and tricks out of the Box
                        • BoxB
                          But they have come from me, therefore From out of the Box.
                          • bazB
                            baz
                            i will delete these off top posts.
                            • BoxB
                              No need, nobody in here except you and me to read them.
                              • bazB
                                baz
                                Ok, I will concede the point.
                                Still shits me 'tho. xx
                                • bazB
                                  baz
                                  I very much doubt that.
                                  • bazB
                                    baz
                                    Therefore, these things are 'Out of the Box'.
                                    Therefore 'FROM' not required.
                                    N'est Pas?
                                    • BoxB
                                      I think the fact you are struggling with it explains the meaning of the title, it is a neither one thing nor the other. It isn't only out of the box it is also out of the box and even some stuff in the box. On that rather ambiguous note I'm for my bed (as they colloquially say in one of the places I have lived, dreadful grammar tho). ๐Ÿ’š
                                      • BoxB
                                        Fredoscale has the ability to change the plane that is used for scaling, allowing you to control the -1 scale of off axis objects, making for an easy mirror tool.
                                        https://i.imgur.com/ZU6FXfy.gif
                                        • tuna1957T
                                          tuna1957
                                          Your never ending supply of โ€œtips and tricksโ€ is much appreciated ! Many many thanks for your efforts. ๐Ÿ‘ ๐Ÿ‘
                                            Technic of the Circle + inclined segment! ๐Ÿ˜Ž
                                            Was very efficient and yet seen at Kito Raupp more ten years ago! ๐Ÿ˜‰
                                            Many tricky things there! ๐Ÿ˜Ž
                                            • 11
                                            • 9 / 11
