    [Plugin] importDXFtext
    165 Posts 18 Posters 109.2k Views 18 Watching
    • uwesketchU Offline
      uwesketch
      Thanks for the quick reply.
      I just downloaded, installed and tried.
      But I still have the same issue and exact same error message.
      Looks like a new main prog, but same code file.
      Making 0 TEXT Entities...
      Making 0 MTEXT Entities...
      Making 16 ATTRIBUTE TEXT Entities...
      Error: #<NameError: undefined local variable or method cp'** for TIG::ImportDXFtext:Module> C:/Users/Birgit/AppData/Roaming/SketchUp/SketchUp 2022/SketchUp/Plugins/importDXFtext/importDXFtext_code.rb:**1273:in block in make_atext'
      C:/Users/Birgit/AppData/Roaming/SketchUp/SketchUp 2022/SketchUp/Plugins/importDXFtext/importDXFtext_code.rb:1118:in each' C:/Users/Birgit/AppData/Roaming/SketchUp/SketchUp 2022/SketchUp/Plugins/importDXFtext/importDXFtext_code.rb:1118:in each_with_index'
      C:/Users/Birgit/AppData/Roaming/SketchUp/SketchUp 2022/SketchUp/Plugins/importDXFtext/importDXFtext_code.rb:1118:in make_atext' C:/Users/Birgit/AppData/Roaming/SketchUp/SketchUp 2022/SketchUp/Plugins/importDXFtext/importDXFtext_code.rb:1776:in import'
      C:/Users/Birgit/AppData/Roaming/SketchUp/SketchUp 2022/SketchUp/Plugins/importDXFtext/importDXFtext_code.rb:1799:in new' C:/Users/Birgit/AppData/Roaming/SketchUp/SketchUp 2022/SketchUp/Plugins/importDXFtext/importDXFtext_code.rb:1805:in block in module:ImportDXFtext'
        And the Extension Manager reports it as the latest version v3.2 ?
        I'll look at it, but the line it reports the error in should not cause this error...
          The good news is I've managed to stop that error.
          The bad news is that SketchUp now Bugsplats after the import...
          So some work to do !
            I've now traced the Bugsplat - only happens when choosing mm as units - suspect it's because the size of the ext is too small and 1/1000" is SketchUp's tolerance...
            Testing a trap for this...
              Here's v3.3
              https://sketchucation.com/pluginstore?pln=importDXFtext
              It now sidesteps the 'cp' error message and also avoids a possible Bugsplat when processing Atxt, if you choose mm [or even cm] as your imported DXF's units the tiny size of any Attribute-text could result in very small geometry that crashes SketchUp, so in that case there's a closing message-box to warn you and the imported Attribute-text's units are assumed to be in inches, just for that DXF text-type...
              Please test and report back as necessary...
                uwesketch
                Hi TIG
                SketchUUp Ext. manger showed 3.2 after install. But I did not see the
                line with**cp =**gents.add... in the code file.
                Agree, the fix is to be applied about 10 lines further up than what is reported in the console.
                I think I also had crashes in Sketchup when working with mm.
                Cool, you could find a work around!
                Downloaded and installed version 3.3. So far all good.
                Will test later today and let you know.
                  uwesketch
                  out of curiosity, not saying it is wrong or I would know why πŸ˜‰
                  Yesterday evening, for testing, I did the same change for make_atext as it stands in make_mtext and then it worked.
                  For ***make_text ***and make_mtext you assigned the variable cp:
                        if string.tr(' ','').gsub(/\\P/,'')==""
                          string=""
                         ***cp = gents.add_cpoint(ORIGIN)***
                          puts "Empty String = Cpoint"
                          next
                          #height=100.mm
                        end#if
                        bold=false;italic=false
                        begin
                          gents.add_3d_text(string,align,font,bold,italic,height,0.0,0.0,true,thick) if string && string !=""
                        rescue Exception => ex
                          puts ex
                        ensure ### ?
                        next unless gp.valid?
                        ***cp.erase! if cp && cp.valid?*** # we don't need a cpt inside text??
                  But for make_atext, you commented out the line causing errors:
                          string=""
                          ***gents.add_cpoint(ORIGIN)***
                          next
                        end#if
                        string=string.strip.gsub(/\\P/,"\n")### replace \P with \n
                        begin
                          puts ex
                        ensure ### ?
                       ***#cp.erase! if cp && cp.valid?*** # we don't need a cpt inside text??
                    It's possible to have an empty text string in ACAD Mtext etc, to trap for it I add a cpoint into the group containing the possible text - to ensure the group isn't prematurely deleted as there's no geometry made - at the end that cpoint is deleted to tidy up.
                    As it isn't needed in the Atxt, putting the # in front of the relevant line fixes the error message.
                    The unrelated splat with tiny text from Atxt when using model-mm is trapped by forcing inches for Atxt height when import units are set to mm/cm...
                      uwesketch
                      Ok, Clear, makes sense.
                      I tested and it turns out, that AText is by a factor of 39 too small (100/2.54).
                      So if I have a MText or Text at position (x,y,z) = (100mm, 100mm, 0mm) then the MText is imported into SketchUp at the right position, but the AText being at the same position in DXF, ends up in SketchUp at (2.54mm,2.54mm,0mm).
                      Also the height of the Text is much smaller.
                      I imported indicating units = meter.
                      Probably this is the reason why if choosing MilliMeter for import, it crashes, because a few mm divided by 39 is giving a too small text size.
                        So what is the outcome of this ?
                        Previously, for any type of ACAD text, you could specify a unit mm/cm/m/'/" and a matching factor was applied to the DXF's height/spacing etc [assuming it is initially stored in "].
                        In the newest version that adjustment still applies to Text & Mtext, but for Atext, where the text-height is often ~0.01", sometimes giving very tiny edges in the flat 3d-text characters, so I forced it to check if the unit is set to mm/cm, and if so it uses the DXF's " values instead...
                        So how should we fix this ? Forgetting the details of the coding itself... what do we need to check and change/keep... e.g. if it's Atext do we increase the height by x39 ? and them reduce if by the unit-factor ??
                          uwesketch
                          I checked again with version 3.2 (where I fixed the variable error by setting "cp = gents.add?...")
                          using units = meters: All works as expected. The MTexts, Texts and ATexts are all at the correct position and size in SketchUp.
                          As soon as I import with "unites = mm" (which I think is not correct for this drawing), SketchUp crashes. So nothing new.
                          Somehow I think the Plugin works fine, just that it causes a crash, if units are choosen too small (user error).
                          Could we not define, that objects are not imported, if the resulting 3D text height is below a limit?
                          (I assume it is the too small 3D text size which brings Sketchup 2021 and 2022 to a crash)
                          In the console or a dialog box, the number of skipped texts could be reported at the end of the import process.
                          I created in SketchUp a 3D text using the standard menu option:
                          The height of a 3D Text must be equal or bigger than 0.0254 mm(1/1000 inch). If you enter a smaller value, SketchUp gives an error message, saying the length entered is too small. (Probably Sketchup Team had these crashes as well and now there is a data entry validation)
                          0.0254mm is the smallest height to create a 3D Text
                            Here's v3.4
                            I've adjusted the code so that it partially reads the DXF file header before your choose the Units.
                            The resulting default in dialog should usually be accepted.
                            Now you cannot choose units less than the DXF's - which are often in inches - and if you try you are blocked.
                            However, you can choose units that are bigger, BUT you are warned about the discrepency Y|N...
                              uwesketch
                              Thanks.
                              Tested version 3.4, with the same dxf file as before: unfortunately 😞
                              I do not even get the unit dialog:
                              Error: #<TypeError: wrong argument type nil (expected Array)>
                              C:/Program Files/SketchUp/SketchUp 2022/Tools/sketchup.rb:121:**in inputbox'** C:/Program Files/SketchUp/SketchUp 2022/Tools/sketchup.rb:121:in inputbox'
                              C:/Users/Birgit/AppData/Roaming/SketchUp/SketchUp 2022/SketchUp/Plugins/importDXFtext/importDXFtext_code.rb:99:in get_units' C:/Users/Birgit/AppData/Roaming/SketchUp/SketchUp 2022/SketchUp/Plugins/importDXFtext/importDXFtext_code.rb:1880:in new'
                              C:/Users/Birgit/AppData/Roaming/SketchUp/SketchUp 2022/SketchUp/Plugins/importDXFtext/importDXFtext_code.rb:1894:in `block in module:ImportDXFtext'
                                Aaargh !
                                I'll republish the version asap...
                                  Here's v3.4 again
                                  I think I've fixed the typo ??
                                    uwesketch
                                    Thanks a lot.
                                    Still the same at the beginning.
                                    Can it be, that the units list returned from the DXF is empty in certain cases?
                                    After I tried with another dxf it worked. And from then on, the first dxf file also worked.
                                    Seems to me as if the array is not always initialized.
                                    Other point: I have another dxf which the plugin now identifies being "inch". But this is not the correct unit. It must be meter. Are there multiple units in the file where you can look which unit is the right?
                                    C:/Program Files/SketchUp/SketchUp 2021/Tools/sketchup.rb:121:in inputbox' C:/Program Files/SketchUp/SketchUp 2021/Tools/sketchup.rb:121:in inputbox'
                                    C:/Users/Birgit/AppData/Roaming/SketchUp/SketchUp 2021/SketchUp/Plugins/importDXFtext/importDXFtext_code.rb:99:in get_units' C:/Users/Birgit/AppData/Roaming/SketchUp/SketchUp 2021/SketchUp/Plugins/importDXFtext/importDXFtext_code.rb:1880:in new'
                                    C:/Users/Birgit/AppData/Roaming/SketchUp/SketchUp 2021/SketchUp/Plugins/importDXFtext/importDXFtext_code.rb:1894:in `block in module:ImportDXFtext'
                                      I've tried v3.4 with your very DXF and it works just fine !
                                      Are you installing all of the contents from the RBZ and restarting SketchUp ?
                                      I'll look at forcing the array better - since if seems to partially work !
                                      Watch for a new update...
                                      A DXF has one header section - it tells us whether it's English or Metric, and then what the units are, so if it says it's 'inches' it is !
                                      Look for $MEASUREMENT - 2 lines below - there are two choices - 0 is English, 1 is metric
                                      Look for $INSUNITS - 2 lines below - various entries mean different units - e.g. 0=unitless, 1=inches, 2=feet, 3=miles, 4=mm, 5=cm, 6=m, 7=km
                                        Here's v3.4 again
                                        I think I've fixed the array issues ???
                                          uwesketch
                                          yes, installed via extension manager and restarted SketchUp.
                                          For the file block.dxf, which shows inch, but in fact should be meter, the entries are:
                                          $MEASUREMENT
                                          70
                                          $INSUNITS
                                          70
                                          for the dxf which causes a crash if loaded as the first file after opening SketchUp, I find:
                                          $MEASUREMENT
                                          70
                                          But there is NO $INSUNITS in this file!
                                          What I find is a code without the $ sign:
                                          INSUNITS
                                          350
                                          4CE6
                                          3
                                          In a third file, which also works, I have:
                                          $MEASUREMENT
                                          70
                                          $INSUNITS
                                          70
                                          6
                                          9
                                          all files have as well Codes called $LUNITS and $AUNITS
                                          $LUNITS
                                          70
                                          $AUNITS
                                          70
                                          Hope this helps finding the cause for error message.
                                            uwesketch
                                            @tig said:
                                            Here's v3.4 again
                                            Now it does not crash anymore when loading the file and I get:
                                            The list of units is set to mm as a default:
                                            when pressing ok, I get this warning:
                                            When changing the units to something different than mm, I get:
                                            Seems like the units found in the DXF file are "empty": []
                                            With another file lke the block.dxf, I get as the default unit [inches]
                                            • 4 / 9
