    โ„น๏ธ Licensed Extensions | FredoBatch, ElevationProfile, FredoSketch, LayOps, MatSim and Pic2Shape will require license from Sept 1st More Info
    Porsche 356C
    7 Posts 4 Posters 3.0k Views 4 Watching
      I would like to thank Loo for his posted render (https://sketchucation.com/forums/viewtopic.php?f=81&t=74495) which has inspired me to try similar with Twilight render.
      Long way to go yet with better shadow catcher and improved angle from the hdri.
      The model has a few small issues when imported into Sketchup but frankly, very minor and for a model offered freely, it shows up well.
      Wotcha fink folks?
        OK, a few self made errors due to be an unthinking plank which I finally discovered the cause of but, there is a problem with the hdri presentation in all views. Shadow catcher and hdri might be the issue but I doubt it seeing as I discovered that particular snafu of my own making.
        • Bryan KB Offline
          I'm not seeing any flaws. Do you mean the angle of the lighting? If that's all, then you'll solve that by tomorrow! ๐Ÿ‘
          Other than that? Yeah, looks great. ๐Ÿ‘
          • locoL Offline
            loco
            Ooooh, my favourite car ๐Ÿ˜Ž I am following this ๐Ÿค“ Don't forget the licence plate ๐Ÿ˜‰
            Windows 10, gpu rtx 3060 12gb ram, cpu AMD Ryzen 5 5600X 64gb ram, SketchUp 2022, Twinmotion 2022. My Little Tutorial
              Thanks folks, the hdri has a horizontal split half way up the 'wall' which should not be there. As for the plate, I am looking at several varieties with one being a typical plate for the years it was in production but, a German plate. When I get the various 'bits' flipped I will do a UK version, possibly.
              Trying to fix the hdri at the moment.
              The 'A' pillar has been cleaned up due to some messy geometry but there are still a few details I would like to add like dashboard and clocks etc.
              • pbacotP Offline
                This is beautiful work. I like the tail lights though could be more depth to them. I don't get what's going on in the background but the lighting and all is fine AFIK / can see. Great job and thanks for sharing. It's helpful to see good renderings.
                  Thanks mate, I mention cleaning it up but it is basically a very fine model and a credit to the guy who made it. HDRI aside, it's a joy to work with. ๐Ÿ‘Š
