    Medeek Wall Plugin
    1.6k Posts 29 Posters 1.7m Views 28 Watching
    • medeekM Offline
      medeek
      Version 2.5.0 - 11.06.2021
      • Added a rainscreen option for rectangular walls (vertical furring strips).
      http://design.medeek.com/resources/wallplugin/images2/wall_su591_800.jpg
      !!! WARNING !!!
      This update will require deleting and recreating any rectangular wall presets. This update will not affect any other preset types (ie. gable wall, shed wall, hip wall, door, window etc…)
      This feature has been requested multiple times lately so I thought I might try and get a rudimentary rainscreen feature put together. Note that the current rainscreen module is fairly simple and does not trim around openings. If you want the furring strips to line up with the studs you can set the offset value to 1/2 of the stud spacing (or any other value for a different alignment).
      I consider this feature more representational at this point but please give me additional feedback with regards to future improvements or additional options/requirements.
      Nathaniel P. Wilkerson PE
      Medeek Engineering Inc
      design.medeek.com
      • medeekM Offline
        medeek
        Version 2.5.1 - 11.14.2021
        • Added a horizontal rainscreen option for rectangular walls (horizontal furring/girt boards).
        • Added an option for top and bottom furring/girt boards for horizontal rainscreens.
        http://design.medeek.com/resources/wallplugin/images2/wall_su592_800.jpg
        If you set the top or bottom sizes to "zero - 0.0" then it will eliminate that respective option.
        design.medeek.com
        • medeekM Offline
          medeek
          In recognition of the overwhelming support I have received from the SketchUp community during 2021 I will be immediately offering 35% off of the mdkBIM bundle price (permanent license) using the coupon code GIVETHANKS21 . (promotion ends Dec. 1, 2021).
          This will reduce the bundle price from $280.00 USD to $182.00 USD. This promo code does not apply to any of the extensions purchased separately or to the electrical plugin. The offer also ends on Dec. 1 and no rain checks will issued thereafter.
          https://aws1.discourse-cdn.com/sketchup/original/3X/1/7/171932bd5c293a4396c7d2cd8e160a41cf227ab8.jpeg
          design.medeek.com
          • medeekM Offline
            medeek
            Version 2.5.2 - 11.15.2021
            • Fixed a bug with exterior trim (corners) for shed walls.
            • Fixed a bug with rectangular wall presets.
            design.medeek.com
            • medeekM Offline
              medeek
              Version 2.5.3 - 11.23.2021
              • Added a Custom Column Library/Manager in the Columns tab of the Global Settings.
              • Enabled custom sizes for Sawn Lumber, Timber and SCL(PSL,LSL,LVL) columns.
              • Created the Medeek Wall API: wall_regen
              • Enabled an additional wall justification option for all wall types: Sheathing.
              http://design.medeek.com/resources/wallplugin/images2/wall_su593_800.jpg
              http://design.medeek.com/resources/wallplugin/images2/wall_su594_800.jpg
              *Note: Just a reminder that the Alt key is the hotkey for toggling the wall justification.
              design.medeek.com
              • medeekM Offline
                medeek
                Note: To call the wall_regen method:
                Medeek_Engineering_Inc_Extensions;;MedeekWallPlugin;;Wall;;MedeekMethods.wall_regen entity
                where the entity is the Medeek wall group.
                The column update required modifying at least 10 files and took about five days of concerted effort, some of it quite tedious and I will say boring, but yeah, it is always worth it. Basically an entire rewrite of the in-wall column module, a lot of the code under the hood was reviewed and updated to bring it up to speed with the highly efficient beam module. Now all of the menus are HTML as well.
                The addition of the API took all of 15 minutes to add.
                The wall justification was only about another 1.5 hours of work.
                Mostly it was me deciding whether it would muddy the waters too much to go from three options to four (front, center back → front, center, back, sheathing). You will notice that when you use the draw wall tool now it will show a small text near the wall length dimension letting you know which justification mode that you are in. The placement and the size of this specific text may yet require some fine tuning, I want that information to be available to the user but I don’t want it to be so obtrusive that it is annoyingly so. Feedback required…
                design.medeek.com
                • medeekM Offline
                  medeek
                  Version 2.5.4 - 11.26.2021
                  • Improved the organization of the HTML draw and edit menus for rectangular walls.
                  design.medeek.com
                  • medeekM Offline
                    medeek
                    Version 2.5.5 - 11.27.2021
                    • Updated the SSW draw menu with an HTML menu.
                    http://design.medeek.com/resources/wallplugin/images2/wall_su595_800.jpg
                    design.medeek.com
                    • medeekM Offline
                      medeek
                      Just a reminder that the Thanksgiving promotion (Black Friday/Cyber Monday) is still ongoing and will be active until Dec. 1st:
                      http://design.medeek.com/ads/GIVETHANKS21_BANNER_800.jpg
                      design.medeek.com
                      • medeekM Offline
                        medeek
                        Version 2.5.6 - 12.05.2021
                        • Added a "Posts" tab into the Global Settings.
                        • Added a Custom Post Library/Manager in the Posts tab of the Global Settings.
                        • Enabled custom sizes for Sawn Lumber, Timber and SCL(PSL,LSL,LVL) posts.
                        http://design.medeek.com/resources/wallplugin/images2/wall_su596_800.jpg
                        This should complete the custom libraries for beams, headers, column and posts.
                        design.medeek.com
                        • medeekM Offline
                          medeek
                          Tutorial 24 - Custom Libraries (17:49 min.)
                          A brief introduction and explanation of the custom header, beam, column and post libraries within the global settings.
                          design.medeek.com
                          • medeekM Offline
                            medeek
                            Version 2.5.7 - 12.10.2021
                            • Enabled opening and closing of single hung and slider windows.
                            https://aws1.discourse-cdn.com/sketchup/original/3X/c/c/cce895f137c0b1e824b93f45076bbd004f2ed2d3.gif
                            From a design and rendering standpoint I'm not really sure how useful this feature is but it stands to reason that if you can open the doors and garage doors you should also be able to open the windows.
                            I have not enabled this feature yet for casement style windows.
                            This feature was added per customer request.
                            design.medeek.com
                            • medeekM Offline
                              medeek
                              Version 2.5.7b - 12.10.2021
                              • Enabled opening and closing of casement windows.
                              https://aws1.discourse-cdn.com/sketchup/original/3X/2/d/2daf1a18c630de79afb61c48d896f05f7fecc3c3.gif
                              design.medeek.com
                              • medeekM Offline
                                medeek
                                Version 2.5.8 - 12.11.2021
                                • Added awning, fixed-awning and awning-fixed windows to the window module.
                                • Enabled opening and closing for all awning type windows.
                                http://design.medeek.com/resources/wallplugin/images2/OPEN_WINDOWS3.gif
                                The size ratio of the fixed to awning windows are 3:1. I currently don't have a way to customize this size ratio but I will be giving it some additional thought.
                                design.medeek.com
                                • medeekM Offline
                                  medeek
                                  Version 2.5.9 - 12.12.2021
                                  • Fixed a minor bug in the shearwall draw and edit menus.
                                  • Enabled shearwall panel and fastener callouts/labels.
                                  http://design.medeek.com/resources/wallplugin/images2/wall_su597_800.jpg
                                  This additional annotation can be toggled on and off with the Framing Callout option in the General tab of the Global Settings. Eventually I will probably setup a separate callout option in the Shearwall tab of the Global Settings so control can be a bit more granular.
                                  The bug in the menus was a simple typo with the nail size (10d).
                                  design.medeek.com
                                  • medeekM Offline
                                    medeek
                                    Version 2.6.0 - 12.18.2021
                                    • Converted the wall preset system to a Hash data structure.
                                    • Wall presets are common to all wall configurations: Rectangular, Gable, Shed and Hip.
                                    • The draw and edit menus for all wall configurations have been combined into a single, unified system.
                                    • Walls can be converted between any configuration within the wall edit menu (ie. Gable -> Hip).
                                    With some trepidation I release this update. Some very serious under-the-hood stuff is what this update is all about. I modified over 25 files with this latest upgrade and even after a full day of testing it is still impossible to for me to say whether I might have broken something inadvertently. Only time and more testing will determine if further bug fixes might be in store.
                                    !!!! CAUTION !!!!
                                    Before moving to this latest version of the plugin you will want to first delete all of your Rectangular Wall Presets. The new system is not compatible with prior wall presets (wall presets only). Also all of your wall presets stored for Gable, Shed or Hip walls will simply be ignored with this update since wall presets are now shared among all wall configurations.
                                    The really good news is that one can convert walls from gable to rectangular and any other combination and back again. The plugin just got a lot more flexible and powerful.
                                    The even better news is that if I do add more features to the walls the new preset system should allow for backwards compatibility, which means we no longer have to keep deleting and recreating wall presets when new features are added.
                                    You will also notice that you can now create all wall configurations in polyline mode and switch back and forth between wall configurations as you are wrapping around the exterior of the structure.
                                    design.medeek.com
                                    • medeekM Offline
                                      medeek
                                      Version 2.6.0b - 12.18.2021
                                      • Updated the Wall Copy Tool to include gable, shed and hips wall types.
                                      design.medeek.com
                                      • medeekM Offline
                                        medeek
                                        Version 2.6.0c - 12.19.2021
                                        • Fixed a bug with the Wall Copy Tool.
                                        This addresses a bug wherein you cannot sample the properties of a non-rectangular wall with the Wall Copy Tool.
                                        !!! Attention !!!
                                        Recommended update if you just installed 2.6.0 or 2.6.0b.
                                        design.medeek.com
                                        • medeekM Offline
                                          medeek
                                          So I've decided to enable another option/parameter so that the standard window callout can be replaced by any custom label or text the user wants to display:
                                          https://aws1.discourse-cdn.com/sketchup/original/3X/c/0/c09240380e6a1b72e6c5c3caa09c92b77afb1e9c.jpeg
                                          If you leave this option blank then the plugin will automatically display the standard callout. If you enter in any text/numbers etc... it will then replace the standard callout with whatever is specified here.
                                          This parameter will not be saved with the window preset however I may change that depending on feedback.
                                          I will enable this same feature for doors and garage doors and then release it.
                                          design.medeek.com
                                          • medeekM Offline
                                            medeek
                                            Version 2.6.1 - 12.21.2021
                                            • Added a Custom Label option for Windows, Doors and Garage doors.
                                            http://design.medeek.com/resources/wallplugin/images2/wall_su599_800.jpg
                                            design.medeek.com
                                            • 56
                                            • 57
                                            • 58
                                            • 59
                                            • 60
                                            • 79
                                            • 80
                                            • 58 / 80
