    Medeek Wall Plugin
    1.6k Posts 29 Posters 2.0m Views 28 Watching
    • medeekM
      medeek
      Version 2.5.4 - 11.26.2021
      • Improved the organization of the HTML draw and edit menus for rectangular walls.
      Nathaniel P. Wilkerson PE
      Medeek Engineering Inc
      design.medeek.com
      • medeekM
        medeek
        Version 2.5.5 - 11.27.2021
        • Updated the SSW draw menu with an HTML menu.
        http://design.medeek.com/resources/wallplugin/images2/wall_su595_800.jpg
        design.medeek.com
        • medeekM
          medeek
          Just a reminder that the Thanksgiving promotion (Black Friday/Cyber Monday) is still ongoing and will be active until Dec. 1st:
          http://design.medeek.com/ads/GIVETHANKS21_BANNER_800.jpg
          design.medeek.com
          • medeekM
            medeek
            Version 2.5.6 - 12.05.2021
            • Added a "Posts" tab into the Global Settings.
            • Added a Custom Post Library/Manager in the Posts tab of the Global Settings.
            • Enabled custom sizes for Sawn Lumber, Timber and SCL(PSL,LSL,LVL) posts.
            http://design.medeek.com/resources/wallplugin/images2/wall_su596_800.jpg
            This should complete the custom libraries for beams, headers, column and posts.
            design.medeek.com
            • medeekM
              medeek
              Tutorial 24 - Custom Libraries (17:49 min.)
              A brief introduction and explanation of the custom header, beam, column and post libraries within the global settings.
              design.medeek.com
              • medeekM
                medeek
                Version 2.5.7 - 12.10.2021
                • Enabled opening and closing of single hung and slider windows.
                https://aws1.discourse-cdn.com/sketchup/original/3X/c/c/cce895f137c0b1e824b93f45076bbd004f2ed2d3.gif
                From a design and rendering standpoint I'm not really sure how useful this feature is but it stands to reason that if you can open the doors and garage doors you should also be able to open the windows.
                I have not enabled this feature yet for casement style windows.
                This feature was added per customer request.
                design.medeek.com
                • medeekM
                  medeek
                  Version 2.5.7b - 12.10.2021
                  • Enabled opening and closing of casement windows.
                  https://aws1.discourse-cdn.com/sketchup/original/3X/2/d/2daf1a18c630de79afb61c48d896f05f7fecc3c3.gif
                  design.medeek.com
                  • medeekM
                    medeek
                    Version 2.5.8 - 12.11.2021
                    • Added awning, fixed-awning and awning-fixed windows to the window module.
                    • Enabled opening and closing for all awning type windows.
                    http://design.medeek.com/resources/wallplugin/images2/OPEN_WINDOWS3.gif
                    The size ratio of the fixed to awning windows are 3:1. I currently don't have a way to customize this size ratio but I will be giving it some additional thought.
                    design.medeek.com
                    • medeekM
                      medeek
                      Version 2.5.9 - 12.12.2021
                      • Fixed a minor bug in the shearwall draw and edit menus.
                      • Enabled shearwall panel and fastener callouts/labels.
                      http://design.medeek.com/resources/wallplugin/images2/wall_su597_800.jpg
                      This additional annotation can be toggled on and off with the Framing Callout option in the General tab of the Global Settings. Eventually I will probably setup a separate callout option in the Shearwall tab of the Global Settings so control can be a bit more granular.
                      The bug in the menus was a simple typo with the nail size (10d).
                      design.medeek.com
                      • medeekM
                        medeek
                        Version 2.6.0 - 12.18.2021
                        • Converted the wall preset system to a Hash data structure.
                        • Wall presets are common to all wall configurations: Rectangular, Gable, Shed and Hip.
                        • The draw and edit menus for all wall configurations have been combined into a single, unified system.
                        • Walls can be converted between any configuration within the wall edit menu (ie. Gable -> Hip).
                        With some trepidation I release this update. Some very serious under-the-hood stuff is what this update is all about. I modified over 25 files with this latest upgrade and even after a full day of testing it is still impossible to for me to say whether I might have broken something inadvertently. Only time and more testing will determine if further bug fixes might be in store.
                        !!!! CAUTION !!!!
                        Before moving to this latest version of the plugin you will want to first delete all of your Rectangular Wall Presets. The new system is not compatible with prior wall presets (wall presets only). Also all of your wall presets stored for Gable, Shed or Hip walls will simply be ignored with this update since wall presets are now shared among all wall configurations.
                        The really good news is that one can convert walls from gable to rectangular and any other combination and back again. The plugin just got a lot more flexible and powerful.
                        The even better news is that if I do add more features to the walls the new preset system should allow for backwards compatibility, which means we no longer have to keep deleting and recreating wall presets when new features are added.
                        You will also notice that you can now create all wall configurations in polyline mode and switch back and forth between wall configurations as you are wrapping around the exterior of the structure.
                        design.medeek.com
                        • medeekM
                          medeek
                          Version 2.6.0b - 12.18.2021
                          • Updated the Wall Copy Tool to include gable, shed and hips wall types.
                          design.medeek.com
                          • medeekM
                            medeek
                            Version 2.6.0c - 12.19.2021
                            • Fixed a bug with the Wall Copy Tool.
                            This addresses a bug wherein you cannot sample the properties of a non-rectangular wall with the Wall Copy Tool.
                            !!! Attention !!!
                            Recommended update if you just installed 2.6.0 or 2.6.0b.
                            design.medeek.com
                            • medeekM
                              medeek
                              So I've decided to enable another option/parameter so that the standard window callout can be replaced by any custom label or text the user wants to display:
                              https://aws1.discourse-cdn.com/sketchup/original/3X/c/0/c09240380e6a1b72e6c5c3caa09c92b77afb1e9c.jpeg
                              If you leave this option blank then the plugin will automatically display the standard callout. If you enter in any text/numbers etc... it will then replace the standard callout with whatever is specified here.
                              This parameter will not be saved with the window preset however I may change that depending on feedback.
                              I will enable this same feature for doors and garage doors and then release it.
                              design.medeek.com
                              • medeekM
                                medeek
                                Version 2.6.1 - 12.21.2021
                                • Added a Custom Label option for Windows, Doors and Garage doors.
                                http://design.medeek.com/resources/wallplugin/images2/wall_su599_800.jpg
                                design.medeek.com
                                • medeekM
                                  medeek
                                  Version 2.6.2 - 12.21.2021
                                  • Added fixed - twin awning and twin awning - fixed windows to the window module.
                                  http://design.medeek.com/resources/wallplugin/images2/OPEN_WINDOWS4.gif
                                  Two more window types per customer request.
                                  design.medeek.com
                                  • medeekM
                                    medeek
                                    Version 2.6.3 - 12.22.2021
                                    • Added an additional vertical offset parameter for symbols that are positioned on the top of walls.
                                    http://design.medeek.com/resources/wallplugin/images2/wall_su600_800.jpg
                                    This update applies to the top-of-wall symbols for doors, garage doors, windows, in-wall columns, SSW's and shearwalls.
                                    design.medeek.com
                                    • medeekM
                                      medeek
                                      Version 2.6.4 - 12.23.2021
                                      • Added an "End Wall" dimension option for Construction Dimensions within the General tab of the Global Settings.
                                      • Enabled "End Wall" construction dimensioning for the window, door and garage door draw tools.
                                      http://design.medeek.com/resources/wallplugin/images2/wall_su602_800.jpg
                                      http://design.medeek.com/resources/wallplugin/images2/wall_su601_800.jpg
                                      There might be a better descriptor for this parameter but "End Wall" dimension seemed to fit at the time. Basically this will allow the user to view the distance from both the start and end of the wall while inserting openings. This option is turned off by default.
                                      design.medeek.com
                                      • medeekM
                                        medeek
                                        Note the dual construction dimensions with the End Wall parameter enabled:
                                        https://aws1.discourse-cdn.com/sketchup/original/3X/c/d/cddadbc84605045281a2a1f0fbaa8930f7ee3075.gif
                                        design.medeek.com
                                        • medeekM
                                          medeek
                                          Version 2.6.4b - 12.23.2021
                                          • Enabled "End Wall" construction dimensioning for the in-wall column, shear wall and SSW draw tools.
                                          Just squeezing in a few last minute updates before the Christmas holiday begins.
                                          design.medeek.com
                                          • medeekM
                                            medeek
                                            Version 2.6.5 - 12.29.2021
                                            • Added a holdown option to the in-wall column module.
                                            http://design.medeek.com/resources/wallplugin/images2/wall_su603_800.jpg
                                            design.medeek.com
                                            • 57
                                            • 58
                                            • 59
                                            • 60
                                            • 61
                                            • 80
                                            • 81
                                            • 59 / 81
