    Issue with rendering lines
    Scheduled Pinned Locked Moved LayOut Bug Reporting
    layout
    3 Posts 2 Posters 31.0k Views 2 Watching
      pibuz
      Hi to the community! I'm an old time user of SketchUp but a very recent user of Layout, which I love (like all loves, it has something to be adjusted to work perfeclty, but it's worth it).
      I recently noticed a misrendering of very close lines when using the vector modes. I'd like to know if it's a bug or something I'm doing wrong, since I usually use layout for technical specifications and I need to use vector mode in most cases.
      I'm attaching some images. Basically, randomly in the viewport, some very close lines are distorted (vertical lines come to be inclined).
      Can anybody point me to a solution?
      Thanks in advance!
      raster viewport as I see it in layout
      raster viewport after pdf export (everything ok)
      issue with unwanted inclined lines while in vector mode
      same as in vector mode (expected, since lines rendering of hybrid mode comes from vector mode)
      WEB (ita) - https://filipposcarso.wixsite.com/ordinentropico
      • O Offline
        orbital
        Are you still experiencing this problem?
        Are you able to share the Layout file?
          pibuz
          Hi Orbital! Yes, still experiencing,
          here are the files! Will you have a look at them?
          Thanks in advance!
          https://we.tl/t-3IvHPNk19Z
