    [Plugin] LordOfTheToolbars - v4.0a - 22 Sep 26
    527 Posts 101 Posters 587.7k Views 99 Watching
      rv1974
      How many icons do you have in the row?
      ~90. all bottom area, from edge to edge.
      Do you mean that you get the cursor showing as if you were doing a drag and drop?
      I mean the menu attached below. Sometimes I grag new icons to my toolbar, then decide to say delete some of them, but nothing could be done because the right click menu is gone.
      P.S. Another glitch I forgot to mention: Sometimes adding a separator would put it 3 icons to the left 😄
      • L
        ltchest
        [/quote]
        You may have to restart Sketchup twice after installation of LOTT. The reason is that VRay installs in a special directory and arranges that its toolbars are not really accessible by program.[/quote]
        Could you say a little more about this - i mean i have restarted Sketchup many times since installing LOTT. Should i uninstall LOTT, and then reinstall LOTT and then quite and start Sketchup twice, and then Bobs your Uncle ? thx
        (Any news on the ability to make the vignette stay in position on the monitor where i want it ?)
        Sketchup 21.2.332 (windows 10.0.19043 Build 19043)
        RTX2070 + GTX1080, Driver 472.12
          simoncbevans
          Great extension. I wonder if it is possible to make a custom made toolbar fly out? Would save getting in the way when you have it in the work area.
          • C
            coreyfox
            This is an amazing plugin! I have moved my workflow into using it, but as of yesterday it has been crashing my sketchup, before it can fully load, every time. See attachment - any suggestions on what might be happening here?
            crash message
            • fredo6F
              Which version of Sketchup are you running? If SU2021, please migrate to the latest version, because it solves issues related to menus.
              • L
                ltchest
                OK so i realise now that there is a switch to "Exclude" vray from the options, so i turned that off and it solved my problem. Amazing ! The only thing i really would appreciate would be to have control over where the vignette appears every time i start sketchup. Currently, i have to move it from Screen 2 onto Screen 1 every time 😞
                R 1 Reply Last reply
                • L
                  ltchest
                  that is exactly what the vignette gives you
                  • C
                    coreyfox
                    I'm on sketchup 2021.1.332
                    • L
                      ltchest
                      one more thing about the Vignette. I am finding that, even without closing Sketchup, the Vignette jumps back over to the second screen (monitor). This doesnt happen all the time - just happens sometimes / occasionally. I will open a different drawing from Sketchup and the vignette moves back to where it was at startup 😞
                        SingulArita
                        Thank you for a great extension. Unfortunately, I have a few bugs. Line breaks are lost for some favorite vignettes. Icons rearrange and arrangement lose clarity. There is a problem with the line break for sure. Sometimes it happens to me that the icon duplicates and the original cannot be deleted, moved - right-clicked or removed the break before. I have not yet discovered the exact cause or procedure. But it's happening significantly and it's incredibly annoying.
                        SketchUp 2020 20.0.363. Martin
                        • H
                          hsy7758258
                          on master toolbar manager,i can do noting,cant click or move the icon...
                          show page dev tools,there are bug reporter
                          • cmeedC
                            cmeed
                            Hi Fredo,
                            An amazing plugin - truly a game changer for Plugin reliant Su users! especially helpful on my laptop
                            I got a suggestion and an issue.
                            My suggestion is - could the palettes appear with the use of a shortcut then disappear when a plugin has been hit. with an option for the Palette to appear where the cursor is and in a user defined locations.
                            My issue
                            I'm having trouble altering my palettes. Icons/separators double up when I move them, with these ghost icons/separators I can't right click on them. Ive done al ot of combinations of holding shift / control but the its seems the same what ever combo i use....
                            go here for a video of what i mean and then - of all things a crash!!
                            https://www.dropbox.com/s/2rzj2dadzplgqxd/2021-11-10_21-58-55.mp4?dl=0
                            Cheers
                              rv1974
                              Some observations:
                              The plugin misbehaves heavily in large files*:
                              Open command search window makes navigation (lags &freezing) in complex and heavy files practically impossible.
                              Command search itself becomes super slow.
                              Icons refuse to disappear when user tries to remove them.
                              Restoring from a good config file has no effect. Restart is needed to see the change.
                              *- normally 3-6+ SU windows are opened simultaneously. Hard to say if it influence, but standard UI elements in every file run perfectly.
                              • fredo6F
                                Could you check if there is a lag when you do a right-click in selection mode (with the LOTT Search closed)?
                                Where do you try to remove icons from?
                                Are you referring to the synchronization mechanisms between SU instances on Windows?
                                  rv1974
                                  *) no lags with SU right click menu (whith LOTT Search closed) IIRC.
                                  *) removed icons remain (untill restart) in user LOTT pallets
                                  *) I mean normally I keep open numerous different skp files (maybe it affects, but unlikely)
                                  Maybe its a good idea to send you some heavy file later on to take a look..
                                  Thank you
                                  • W
                                    whiterabbit
                                    I noticed that a number of plugins don't function when they are in a favorites folder, but work with the regular toolbar? attached a gif to show.\Is there something I have done wrong - windows 10 with skup 2018
                                    • fredo6F
                                      Can you open the Ruby Console before clicking on the LOTT palette. There may be errors displayed.
                                      • H
                                        Hypernurd
                                        I was really excited to add this essential plug-in to my SU installation. Unfortunately, it isn't functioning for me.
                                        My system :
                                        • iMac Pro (2017) - 32GB Ram, 3.2Ghz Xeon W
                                        • macOS Monterey (12.0.1)
                                        • Sketchup 2021 & 2020
                                        Problem :
                                        • Cannot drag and drop icons to custom tool palettes or toolbars.
                                        Initially I thought this was a SU2021 problem so I reinstalled 2020 but the problem persists. I have done a thorough system clean (Caches, etc) but still the problem persists in both versions of SU.
                                        Any help or advice would be appreciated.
                                        BWm,
                                        Hypernurd
                                        • fredo6F
                                          @hypernurd said:
                                          Problem :
                                          Could you open the Ruby console to see what is the error. Thanks
                                          • fredo6F
                                            NEW RELEASE: LordOfTheToolbars v1.6a - 27 Dec 21
                                            Requirements
                                            • LibFredo6: v12.3a or above
                                            LordOfTheToolbars 1.6a includes
                                            • Adjustments for future compatibility
                                            • Bug fixing and visual adjustments
                                            Home Page of LordOfTheToolbars for information and Download.
                                            Main post of this LordOfTheToolbars thread.
                                            • 26
                                            • 27
                                            • 6 / 27
