    3D Truss Models
    1.5k Posts 31 Posters 977.7k Views 30 Watching
    • medeekM Offline
      medeek
      Well the basics are more or less there but now the details...
      https://aws1.discourse-cdn.com/sketchup/original/3X/2/6/26c2133608c8ff2e09d459f4b951218cbc51c4ec.jpeg
      Notice that the hip, flying hip and valley rafters are still missing, that algorithm is going to be fun.
      Lots of little details that still need to be addressed to really make this usable in my opinion, especially when asymmetric roof planes are present within a roof assembly.
      View model here:
      3D Warehouse
      (3dwarehouse.sketchup.com)
      https://aws1.discourse-cdn.com/sketchup/original/3X/1/1/1161b2ee4acef8d1fd20352720207a6b2edcdf02.jpeg
      Nathaniel P. Wilkerson PE
      Medeek Engineering Inc
      design.medeek.com
      • medeekM Offline
        medeek
        Version 2.9.9 - 07.25.2021
        • Enabled the rafter framing module for complex roofs.
        I am releasing this update so that users can begin testing out the rafter framing module, however be warned that it is still missing many features and is technically in a BETA state right now as I sort out some of the details and finer points.
        Please send bug details or other concerns directly to my email address, nathan@medeek.com.
        https://aws1.discourse-cdn.com/sketchup/original/3X/c/d/cdf9e3287a04d7e05089720e5ef9118e33af5319.jpeg
        design.medeek.com
        • medeekM Offline
          medeek
          Most of my time is actually spent debugging or looking for ways to break the plugins (instabilities etc...)
          I found one small minor issue this morning when I generated this roof (I will issue the fix later today or tomorrow):
          https://aws1.discourse-cdn.com/sketchup/optimized/3X/3/4/34991470233240609e42ad8796c0c6992b2aaee9_2_690x455.jpeg
          https://aws1.discourse-cdn.com/sketchup/optimized/3X/2/8/2810a102746ad38cc18856d96400ae141c365a4d_2_690x412.jpeg
          The module is surprisingly robust even with more intensive roofs however the draw and edit time required for this geometry is noticeable on my ten year old PC. My youngest son keeps telling me to update to a newer machine with a better graphics card but I figure the older machine actually helps me keep my code lean and efficient.
          View model here:
          3D Warehouse
          design.medeek.com
          • medeekM Offline
            medeek
            Version 3.0.0 - 08.03.2021
            • Fixed a minor bug with the rafter framing module for complex roofs.
            • Adjusted the tool tips within the HTML edit menu for common trusses.
            design.medeek.com
            • medeekM Offline
              medeek
              Version 3.0.1 - 08.08.2021
              • Fixed a bug with the edit menu for common trusses and custom materials.
              design.medeek.com
              • medeekM Offline
                medeek
                Version 3.0.2 - 08.23.2021
                • Fixed a bug with ceiling joists for shed rafter roofs.
                • Fixed a bug with rafter roofs with glulam beams that have soffit and fascia enabled.
                • Updated the wireframe preview of the draw tool for select rafter and truss roof types.
                design.medeek.com
                • medeekM Offline
                  medeek
                  Just a reminder that all of the Truss plugin tutorial videos are listed here:
                  Medeek Design Inc. - Medeek Truss
                  (design.medeek.com)
                  design.medeek.com
                  • medeekM Offline
                    medeek
                    Version 3.0.3 - 10.02.2021
                    • Added custom materials to the roof and wall cladding parameters of the Sheathing tab within the Global Settings.
                    design.medeek.com
                    • medeekM Offline
                      medeek
                      Version 3.0.4 - 10.23.2021
                      • Added error checking code into various HTML menus for roof and wall materials.
                      design.medeek.com
                      • jujuJ Offline
                        juju
                        Is this up on your website yet? Doesn't seem like it?
                        v3.0.4 not
                        • medeekM Offline
                          medeek
                          Okay, check it now.
                          design.medeek.com
                          • medeekM Offline
                            medeek
                            Version 3.0.5 - 11.03.2021
                            • Added additional energy/raised heels for double fink truss (2 variants: wedge and slider).
                            Apparently when I added in the raised heel algorithms for this truss type a couple years ago I only added in the vert with strut option. It was brought to my attention a couple days ago that the other two options were missing. I apologize for the delay in making sure all three options were available for this truss type. We should be good to go now with the double fink truss.
                            design.medeek.com
                            • medeekM Offline
                              medeek
                              Version 3.0.6 - 11.30.2021
                              • Added ceiling gypsum to shed and shed w/ ledger rafter roofs.
                              • Enabled ceiling gypsum for all shed rafter roofs with ceiling joists enabled.
                              http://design.medeek.com/resources/trussplugin/images2/truss_su756_800.jpg
                              http://design.medeek.com/resources/trussplugin/images2/truss_su757_800.jpg
                              http://design.medeek.com/resources/trussplugin/images2/truss_su755_800.jpg
                              http://design.medeek.com/resources/trussplugin/images2/truss_su758_800.jpg
                              design.medeek.com
                              • medeekM Offline
                                medeek
                                Version 3.0.7 - 01.25.2022
                                • Added energy/raised heels for 4/2 scissor trusses (1 variant: vertical w/ strut).
                                http://design.medeek.com/resources/trussplugin/images3/truss_su759_800.jpg
                                design.medeek.com
                                • medeekM Offline
                                  medeek
                                  Version 3.0.8 - 01.29.2022
                                  • Added ceiling gypsum and ceiling battens to all floor assemblies.
                                  http://design.medeek.com/resources/trussplugin/images3/truss_su761_800.jpg
                                  I am still working on the new floor plugin however in the meantime it was not difficult to add the gypsum option to the existing floor truss/joist module.
                                  This feature added per customer request.
                                  design.medeek.com
                                  • medeekM Offline
                                    medeek
                                    Version 3.0.9 - 02.09.2022
                                    • Enabled soffit and fascia for hip truss sets.
                                    • Fixed a minor bug with the hip truss set module.
                                    • Removed the Gutter Extension parameter from the hip truss set edit menu.
                                    http://design.medeek.com/resources/trussplugin/images3/truss_su762_800.jpg
                                    design.medeek.com
                                    • medeekM Offline
                                      medeek
                                      The last few months have been mostly focused on the Wall Plugin and I have not spent much time on the Truss Plugin. There are still quite a few truss types that do not have advanced options enabled as well as the edit function (ie. monopitch scissor). Some of these truss types are not as commonly used and therefore there has been less pressure to work on them however I would like to get all of the truss and roof types up to speed so I will spend a few weeks doing that. I appreciate everyone's patience in this regard, there are still so many things to check off on the todo list for this plugin.
                                      design.medeek.com
                                      • medeekM Offline
                                        medeek
                                        Version 3.1.1 - 02.13.2022
                                        • Enabled advanced options for mono scissor trusses.
                                        • Enabled the "Edit Truss Assembly" function for all mono scissor trusses (imperial and metric units).
                                        http://design.medeek.com/resources/trussplugin/images3/truss_su764_800.jpg
                                        Also note that one can adjust the bottom chord pitch to be the same as the top chord pitch and with a raised heel (ie. 24") you can effectively create shed roof parallel chord trusses:
                                        http://design.medeek.com/resources/trussplugin/images3/truss_su765_800.jpg
                                        design.medeek.com
                                          GFXS
                                          I've been waiting for this update -- to date I've been having to manually edit trusses to add the raised heel. Though it's still missing another component that I need: For the heel blocking, could there be an option for a truss block instead of just LVL or whatever the default solid lumber. Also, an option to have the truss block on the high end and/or low end of the span (or just LVL/solid lumber for the low end). The truss block is common for many of our projects where a tall heel is required.
                                          Thanks for your hard work and dedication on updating these plug-ins. Best regards.
                                          • medeekM Offline
                                            medeek
                                            Let me give this some further thought. I like the idea of providing another option for truss blocking.
                                            Here are a couple examples of manufactured metal plated panels:
                                            design.medeek.com
                                            • 26
                                            • 27
                                            • 28
                                            • 29
                                            • 30
                                            • 75
                                            • 76
                                            • 28 / 76
