    Medeek Wall Plugin
    1.5k Posts 27 Posters 1.1m Views 26 Watching
    • medeekM Offline
      medeek
      Version 2.4.1b - 09.09.2021
      • Changed the wall justification hotkey/option from the "Tab" key to the "Alt" key (Option key) for rectangular, shed, gable and hip draw wall tools.
      Nathaniel P. Wilkerson PE
      Medeek Engineering Inc
      design.medeek.com
      • medeekM Offline
        medeek
        I am pleased with the continual and steady progress made on the Wall plugin over the course of this summer. In light of this recent progress and in hopes of allowing more users access to the features of the plugins I will be immediately offering 10% off of the mdkBIM bundle price using the coupon codeLABORDAY21. (Sept. 11, 2021 thru Sept. 30, 2021).
        This will reduce the bundle price from $280.00 USD to $252.00 USD. This promo code is also valid when purchasing the Wall plugin separately as well as the Electrical plugin. The offer ends on Sept. 30th and no rain checks will issued thereafter.
        https://aws1.discourse-cdn.com/sketchup/original/3X/c/3/c3970710a908159beeec5e989b8ac88bb909bd20.jpeg
        design.medeek.com
        • medeekM Offline
          medeek
          Matt Donley did a great job on putting this video together. A concise but very informative presentation:
          design.medeek.com
          • medeekM Offline
            medeek
            I've been giving the "wall sandwich" thing some serious thought the last couple of days and I think I can implement a workable system however it will drastically change the way I am currently doing things as well as break any sort of backwards compatibility with previous versions of the plugin and their models.
            In the global settings I will probably have a select number of options you can choose from to build your custom wall sandwich (I will also have some standard ones pre-defined). Interior and Exterior walls will be different in that you cannot use wainscot and cladding with interior walls. Interior walls can be asymmetric with this new system so you can have different layers specified on each sides of the wall, unlike the current system which limits interior walls to symmetric configurations only.
            Exterior Walls:
            Ext. Side:
            • Wainscot
            • Cladding 1
            • Cladding 2
            • Airgap 1, 2, 3 etc...
            • Sheathing 1
            • Sheathing 2
            • Insul 1
            Int. Side:
            • Gypsum 1
            • Gypsum 2
            • Gypsum 3
            • Airgap 1,2, 3 etc...
            • Sheathing 1
            • Sheathing 2
            • Insul 1
            Interior Walls:
            Ext. Side:
            • Gypsum 1
            • Gypsum 2
            • Gypsum 3
            • Sheathing 1
            • Sheathing 2
            • Insul 1
            Int. Side:
            • Gypsum 1
            • Gypsum 2
            • Gypsum 3
            • Sheathing 1
            • Sheathing 2
            • Insul 1
            The actual layering can be in any order except for wainscot which will always be the outermost layer on an ext. wall. I'm not sure that two layers of cladding are really needed for an ext. wall but I'm just throwing it out there for now and see what sticks.
            As far as the framing/wall solid is concerned I only plan on having one layer for framing, if I were to change that up to a variable number of framing layers things would get very complicated with regards to corner configurations so it is best to not get too ambitious.
            The items shown are all of the possible layers for each side of the wall in question, one could theoretically enable all of them or none of them, and the number of air gaps is probably not limited.
            Am I missing anything? Thoughts?
            Your feedback now is important, once I install/implement a new wall sandwich system it will be more difficult to fundamentally change it from the form it originally takes.
            design.medeek.com
            • medeekM Offline
              medeek
              Version 2.4.2 - 09.25.2021
              • Enabled a boolean union option for window and door trim.
              • Added a "Union all Trim" parameter to the Door Trim Options within the global settings.
              • Added a "Union all Trim" parameter to the Window Trim Options within the global settings.
              http://design.medeek.com/resources/wallplugin/images2/wall_su576_800.jpg
              http://design.medeek.com/resources/wallplugin/images2/wall_su577_800.jpg
              http://design.medeek.com/resources/wallplugin/images2/wall_su578_800.jpg
              For presentation purposes (ie. elevation views) some designers and architects would prefer to show the window and door trim without each board delineated.
              design.medeek.com
              • medeekM Offline
                medeek
                I had some requests for "header" trimmers lately:
                https://aws1.discourse-cdn.com/sketchup/original/3X/0/7/07451508dd51c1e781d3a76c3582facc11ce0e73.jpeg
                Thoughts?
                design.medeek.com
                • medeekM Offline
                  medeek
                  Version 2.4.2b - 09.27.2021
                  • Enabled a boolean union option for garage door trim.
                  • Added a "Union all Trim" parameter to the Garage Door Trim Options within the global settings.
                  http://design.medeek.com/resources/wallplugin/images2/wall_su580_800.jpg
                  Somehow I failed to consider that this same feature might also be needed for garage doors on the first go around.
                  design.medeek.com
                  • medeekM Offline
                    medeek
                    Version 2.4.3 - 10.02.2021
                    • Fixed a minor bug within the subtractive geometry module.
                    design.medeek.com
                    • medeekM Offline
                      medeek
                      Tutorial 23 - Wall Corners (15:41 min.)
                      design.medeek.com
                      • medeekM Offline
                        medeek
                        Version 2.4.3b - 10.04.2021
                        • Fixed a bug with pocket doors.
                        design.medeek.com
                        • medeekM Offline
                          medeek
                          design.medeek.com
                          • medeekM Offline
                            medeek
                            Version 2.4.4 - 10.12.2021
                            • Fixed a minor bug with trapezoid and pentagon windows when utilized with the "No Framing" mode.
                            • Enabled an option for "zero" start and end wall studs for all wall types.
                            http://design.medeek.com/resources/wallplugin/images2/wall_su581_800.jpg
                            design.medeek.com
                            • medeekM Offline
                              medeek
                              First look at a couple of multi-ply stud walls:
                              https://aws1.discourse-cdn.com/sketchup/original/3X/d/d/dd38ac0ce521fb7e94ae4bd97a43da0e6d0fb382.jpeg
                              Now I just need to do some further testing to make sure all of the other algorithms work correctly with this type of stud configuration (ie. windows, doors, insulation, blocking).
                              design.medeek.com
                              • medeekM Offline
                                medeek
                                Version 2.4.5 - 10.19.2021
                                • Added a "Stud Ply" parameter to the Walls tab of the global settings.
                                • Enabled double and triple ply studs for rectangular walls.]
                                http://design.medeek.com/resources/wallplugin/images2/wall_su582_800.jpg
                                http://design.medeek.com/resources/wallplugin/images2/wall_su584_800.jpg
                                !!! WARNING !!!
                                This update will require that the user delete and recreate their wall presets for rectangular walls. This update does not affect other wall presets or door and window presets.
                                design.medeek.com
                                • medeekM Offline
                                  medeek
                                  Previously I was issuing educational licenses for the mdkBIM suite at no charge however the shear volume of licenses has begun to overwhelm me and take up too much time (manual license creation).
                                  I've now created an easier system to manage which allows me to quickly issue an educational discount code to the student or educator after receiving their credentials or verification.
                                  The new discount code will allow students or educators to purchase the entire mdkBIM suite (permanent license - $280.00) at 10% of the regular cost: $28.00 USD
                                  design.medeek.com
                                  • medeekM Offline
                                    medeek
                                    Version 2.4.6 - 10.22.2021
                                    • Added two additional advanced options for in-wall columns: Top Plt. Cut, Btm Plt. Cut.
                                    • Added two additional parameters into the Columns tab of the global settings.
                                    • Fixed a critical bug with the wall copy tool that was created with the prior update.
                                    • Added error checking code into the rectangular wall edit menu for sheathing, cladding, and gypsum materials.
                                    • Added error checking code into the window edit menu for the shutter material.
                                    http://design.medeek.com/resources/wallplugin/images2/wall_su586_800.jpg
                                    With the in-wall columns I've also changed the draw and edit tool so that the columns can be drawn at the end of the walls, there is no longer the one-stud limitation, not even sure why I added that in originally.
                                    design.medeek.com
                                    • medeekM Offline
                                      medeek
                                      Version 2.4.7 - 10.24.2021
                                      • Fixed a bug with shed walls for the following end configurations: Inside Corner, Inset Inside Corner.
                                      http://design.medeek.com/resources/wallplugin/images2/wall_su587_800.jpg
                                      This fix should resolve the issues we were seeing with the shed wall. I probably missed these bug(s) initially because the inside corner with a shed wall is not very common and sometimes I don't test every possible permutation even though I should.
                                      I may need to go back into the gable and hip wall modules and test them a bit further.
                                      design.medeek.com
                                      • medeekM Offline
                                        medeek
                                        Version 2.4.7b - 10.25.2021
                                        • Added the following additional Wide Flange (W) beams to the beam module: W10X22, W10X26, W10X30, W10X33, W10X39, W10X45, W12X26, W12X30, W12X35, W12X40.
                                        design.medeek.com
                                        • medeekM Offline
                                          medeek
                                          Version 2.4.8 - 10.30.2021
                                          • Added an end cripples option for all window types.
                                          http://design.medeek.com/resources/wallplugin/images2/wall_su588_800.jpg
                                          I will probably also need to add in this option for doors and garage doors.
                                          !!! WARNING !!!
                                          This update will require deleting and recreating any window presets. This update will not affect any other preset types (ie. wall, door, garage door etc...)
                                          design.medeek.com
                                          • medeekM Offline
                                            medeek
                                            Version 2.4.9 - 10.31.2021
                                            • Added an end cripples option for all man doors.
                                            • Added an end cripples option for all garage doors.
                                            • Fixed a bug with exterior trim for arched garage doors when the "trim union" option is enabled.
                                            http://design.medeek.com/resources/wallplugin/images2/wall_su589_800.jpg
                                            http://design.medeek.com/resources/wallplugin/images2/wall_su590_800.jpg
                                            !!! WARNING !!!
                                            This update will require deleting and recreating any door and garage door presets. This update will not affect any other preset types (ie. wall, window etc…)
                                            design.medeek.com
                                            • 40
                                            • 41
                                            • 42
                                            • 43
                                            • 44
                                            • 75
                                            • 76
                                            • 42 / 76
