    Medeek Wall Plugin
    1.6k Posts 29 Posters 2.4m Views 28 Watching
    • medeekM
      medeek
      Version 2.3.5 - 08.21.2021
      • Fixed a bug with Simpson Strong Walls when "Terminal" wall end conditions are used in a wall assembly.
      • Modified the "Edit Wall Assembly" context menu tool so that it behaves similar to the "Edit Wall" tool.
      • Fixed a bug with the wall stretch tool so it now allows for wall stretch or shrinks that are less than 3".
      • Enabled spaced headers (2 ply or 3 ply) for windows, doors and garages by using the key word "FILL" in the header description.
      http://design.medeek.com/resources/wallplugin/images2/wall_su571_800.jpg
      http://design.medeek.com/resources/wallplugin/images2/wall_su572_800.jpg
      *Note, that the header must by a 2 ply or 3 ply header to use a spacer as shown. Also the header description must include a string in this format "FILL_OSB_0.375" or "FILL_PLY_0.4375". The second term is either OSB or PLY which will determine the material to use as the spacer. The third term is the thickness of the spacer (ie. 0.25, 0.375, 0.4375, 0.5 etc...). In a metric template you can specify the spacer thickness in millimeters instead of inches.
      Nathaniel P. Wilkerson PE
      Medeek Engineering Inc
      design.medeek.com
      • medeekM
        medeek
        Version 2.3.6 - 08.23.2021
        • Enabled a trim option for wrapped free standing columns.
        http://design.medeek.com/resources/wallplugin/images2/wall_su573_800.jpg
        The trim combined with the cap or astragal can give even more variations.
        design.medeek.com
        • medeekM
          medeek
          Version 2.3.7 - 08.28.2021
          • Added gable walls to the Medeek Estimator.
          • Fixed a MacOS/Windows bug with the wall justification hotkey for all wall types.
          I still need to add in Shed and Hip walls but it will go much quicker now that I have the gable walls as a template.
          design.medeek.com
          • medeekM
            medeek
            Version 2.3.8 - 08.29.2021
            • Added shed and hip walls to the Medeek Estimator.
            • Adjusted the auto-corner configuration algorithm to better predict terminal wall configurations when three walls come together at an inside or outside corner.
            When multiple walls come together at a corner or junction it is arguably quite hard to predict the intent and desired configuration of the builder/designer/user.
            I think what I have now addresses the immediate issue where a tee intersection was being created instead of a terminal connection, per the previous discussion.
            I will need to continue to test this new algorithm further (put it through its paces) and also receive additional feedback from users. If you notice anything that appears unpredictable or counter-intuitive please feel free to email me so we can discuss.
            design.medeek.com
            • medeekM
              medeek
              Version 2.3.9 - 08.31.2021
              • Added a window clearance (shim space) parameter within the Windows tab of the Globals Settings.
              http://design.medeek.com/resources/wallplugin/images2/wall_su574_800.jpg
              Previously the shim space or window clearance was hard coded in as 1/4" or 6.35mm. Now the user can customize this clearance between the rough opening framing and the window frame. If you do adjust this parameter you will probably also want to adjust the Window Trim Inset parameter so it matches, this way the window trim will butt up against the window frame tight.
              This was a user requested update from New Zealand.
              design.medeek.com
              • medeekM
                medeek
                Version 2.4.0 - 09.01.2021
                • Fixed a bug with spaced headers when applied to trapezoidal windows.
                http://design.medeek.com/resources/wallplugin/images2/wall_su575_800.jpg
                This bug fix only applies to window headers since there are no sloped headers for doors or garage doors. This fix applies to 2-ply and 3-ply spaced headers.
                design.medeek.com
                • medeekM
                  medeek
                  Version 2.4.1b - 09.09.2021
                  • Changed the wall justification hotkey/option from the "Tab" key to the "Alt" key (Option key) for rectangular, shed, gable and hip draw wall tools.
                  design.medeek.com
                  • medeekM
                    medeek
                    I am pleased with the continual and steady progress made on the Wall plugin over the course of this summer. In light of this recent progress and in hopes of allowing more users access to the features of the plugins I will be immediately offering 10% off of the mdkBIM bundle price using the coupon codeLABORDAY21. (Sept. 11, 2021 thru Sept. 30, 2021).
                    This will reduce the bundle price from $280.00 USD to $252.00 USD. This promo code is also valid when purchasing the Wall plugin separately as well as the Electrical plugin. The offer ends on Sept. 30th and no rain checks will issued thereafter.
                    https://aws1.discourse-cdn.com/sketchup/original/3X/c/3/c3970710a908159beeec5e989b8ac88bb909bd20.jpeg
                    design.medeek.com
                    • medeekM
                      medeek
                      Matt Donley did a great job on putting this video together. A concise but very informative presentation:
                      design.medeek.com
                      • medeekM
                        medeek
                        I've been giving the "wall sandwich" thing some serious thought the last couple of days and I think I can implement a workable system however it will drastically change the way I am currently doing things as well as break any sort of backwards compatibility with previous versions of the plugin and their models.
                        In the global settings I will probably have a select number of options you can choose from to build your custom wall sandwich (I will also have some standard ones pre-defined). Interior and Exterior walls will be different in that you cannot use wainscot and cladding with interior walls. Interior walls can be asymmetric with this new system so you can have different layers specified on each sides of the wall, unlike the current system which limits interior walls to symmetric configurations only.
                        Exterior Walls:
                        Ext. Side:
                        • Wainscot
                        • Cladding 1
                        • Cladding 2
                        • Airgap 1, 2, 3 etc...
                        • Sheathing 1
                        • Sheathing 2
                        • Insul 1
                        Int. Side:
                        • Gypsum 1
                        • Gypsum 2
                        • Gypsum 3
                        • Airgap 1,2, 3 etc...
                        • Sheathing 1
                        • Sheathing 2
                        • Insul 1
                        Interior Walls:
                        Ext. Side:
                        • Gypsum 1
                        • Gypsum 2
                        • Gypsum 3
                        • Sheathing 1
                        • Sheathing 2
                        • Insul 1
                        Int. Side:
                        • Gypsum 1
                        • Gypsum 2
                        • Gypsum 3
                        • Sheathing 1
                        • Sheathing 2
                        • Insul 1
                        The actual layering can be in any order except for wainscot which will always be the outermost layer on an ext. wall. I'm not sure that two layers of cladding are really needed for an ext. wall but I'm just throwing it out there for now and see what sticks.
                        As far as the framing/wall solid is concerned I only plan on having one layer for framing, if I were to change that up to a variable number of framing layers things would get very complicated with regards to corner configurations so it is best to not get too ambitious.
                        The items shown are all of the possible layers for each side of the wall in question, one could theoretically enable all of them or none of them, and the number of air gaps is probably not limited.
                        Am I missing anything? Thoughts?
                        Your feedback now is important, once I install/implement a new wall sandwich system it will be more difficult to fundamentally change it from the form it originally takes.
                        design.medeek.com
                        • medeekM
                          medeek
                          Version 2.4.2 - 09.25.2021
                          • Enabled a boolean union option for window and door trim.
                          • Added a "Union all Trim" parameter to the Door Trim Options within the global settings.
                          • Added a "Union all Trim" parameter to the Window Trim Options within the global settings.
                          http://design.medeek.com/resources/wallplugin/images2/wall_su576_800.jpg
                          http://design.medeek.com/resources/wallplugin/images2/wall_su577_800.jpg
                          http://design.medeek.com/resources/wallplugin/images2/wall_su578_800.jpg
                          For presentation purposes (ie. elevation views) some designers and architects would prefer to show the window and door trim without each board delineated.
                          design.medeek.com
                          • medeekM
                            medeek
                            I had some requests for "header" trimmers lately:
                            https://aws1.discourse-cdn.com/sketchup/original/3X/0/7/07451508dd51c1e781d3a76c3582facc11ce0e73.jpeg
                            Thoughts?
                            design.medeek.com
                            • medeekM
                              medeek
                              Version 2.4.2b - 09.27.2021
                              • Enabled a boolean union option for garage door trim.
                              • Added a "Union all Trim" parameter to the Garage Door Trim Options within the global settings.
                              http://design.medeek.com/resources/wallplugin/images2/wall_su580_800.jpg
                              Somehow I failed to consider that this same feature might also be needed for garage doors on the first go around.
                              design.medeek.com
                              • medeekM
                                medeek
                                Version 2.4.3 - 10.02.2021
                                • Fixed a minor bug within the subtractive geometry module.
                                design.medeek.com
                                • medeekM
                                  medeek
                                  Tutorial 23 - Wall Corners (15:41 min.)
                                  design.medeek.com
                                  • medeekM
                                    medeek
                                    Version 2.4.3b - 10.04.2021
                                    • Fixed a bug with pocket doors.
                                    design.medeek.com
                                    • medeekM
                                      medeek
                                      design.medeek.com
                                      • medeekM
                                        medeek
                                        Version 2.4.4 - 10.12.2021
                                        • Fixed a minor bug with trapezoid and pentagon windows when utilized with the "No Framing" mode.
                                        • Enabled an option for "zero" start and end wall studs for all wall types.
                                        http://design.medeek.com/resources/wallplugin/images2/wall_su581_800.jpg
                                        design.medeek.com
                                        • medeekM
                                          medeek
                                          First look at a couple of multi-ply stud walls:
                                          https://aws1.discourse-cdn.com/sketchup/original/3X/d/d/dd38ac0ce521fb7e94ae4bd97a43da0e6d0fb382.jpeg
                                          Now I just need to do some further testing to make sure all of the other algorithms work correctly with this type of stud configuration (ie. windows, doors, insulation, blocking).
                                          design.medeek.com
                                          • medeekM
                                            medeek
                                            Version 2.4.5 - 10.19.2021
                                            • Added a "Stud Ply" parameter to the Walls tab of the global settings.
                                            • Enabled double and triple ply studs for rectangular walls.]
                                            http://design.medeek.com/resources/wallplugin/images2/wall_su582_800.jpg
                                            http://design.medeek.com/resources/wallplugin/images2/wall_su584_800.jpg
                                            !!! WARNING !!!
                                            This update will require that the user delete and recreate their wall presets for rectangular walls. This update does not affect other wall presets or door and window presets.
                                            design.medeek.com
                                            • 55
                                            • 56
                                            • 57
                                            • 58
                                            • 59
                                            • 80
                                            • 81
                                            • 57 / 81
