    [Plugin] ComponentReporter++ v1.2
    71 Posts 22 Posters 72.3k Views 22 Watching
      mozarov
      Hi TIG, Thank you very much for the plugin. Is there a way to get all DCs reported within another DC?
      I've attached dynamic drawer model as an example. I'd like to get report of nested parts of a drawer.
      Thanks again.
      Dynamic drawer 210925.skp
        If you edit the component-instance the nested instances should become accessible ?
        Then your reports will be based of the instances in each nested collection...
          mozarov
          TIG thank you for quick answer. I have named component instances (ie right, left, bottom part etc.) inside dynamic drawer component but still get report of drawers outer dimensions only. I am trying to get report of inner parts of the drawer. Like your ComponentReporter++ cycles through all components and gives report of all components within other component. I would like to get same report of all mined nested DC parts of a DC drawer. Thanks again.
            mozarov
            Please help me out TIG. I am banging my head to a wall for months now. How to make your code cycle through nested DCs ant get their LenX, LenY, LenZ, other attributes to csv?
            Plaease help, I am stuck.
            Dynamic drawer 220210.skp
              Doesn't my earlier posts about DCs cover this ?
              https://sketchucation.com/forums/viewtopic.php?p=659662#p659662
              Edit the object to access the DCs within it ?
                mozarov
                Sorry I don't explain it right. Be selecting a drawer I get report of drawers "parent" attributes. Please see the attached picture.
                What I am trying to get is DC childrens report, like on the second screenshot.
                Please help me out.
                  mozarov
                  Hello TIG
                  I have edited your code and it exports all DCs of the model. How to make it export only selected DCs?
                  I think I have to write ss = model.selection line somewhere. But where should I put it?
                  Thank you for your help.
                  =begin
                  (c) TIG 2011
                  Script:
                  TIG-exportDCs2csv.rb
                  Type;
                    TIG.exportDCs2csv
                  in the Ruby Console to run it.
                  Exports all DCs is the model with a Name,LenX,LenY,LenZ,Layer[s]...
                  'CSV' file - in the model's folder and named after the model thus;
                  ModelName.skp >>> ModelNameDCs.csv
                  If a new model is unsaved the current directory receives the new file.
                  All Layers used in the DC are listed by name and visible ones marked
                  thus >>LayerName<<
                  Edit sep="," if something other than separating comma is desired e.g. ';'
                  Make sep="\t" if a TSV file is desired and change ext="csv" to ext="tsv".
                  It uses the current Model Units.
                  Version;
                  1.0 20111104 First issue.
                  1.1 20111221 DCs customized.
                  =end
                  require 'sketchup.rb'
                  module TIG
                    unless file_loaded?(__FILE__)
                  	UI.menu("Plugins").add_item("TIG.exportDCs2csv2"){TIG.exportDCs2csv2()}
                    file_loaded(__FILE__)
                    def self.exportDCs2csv2() #Exports everything without selection
                      sep="," ### <<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<
                      ext="csv" ### <<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<
                      model = Sketchup.active_model
                      defs=model.definitions
                      dcs=[]
                      defs.each{|dc|
                        next if not dc.attribute_dictionary("dynamic_attributes")
                        dcs << dc
                      if not dcs
                        UI.messagebox("No DCs were available.\nExiting.")
                  	  return nil
                      end#if
                      insts = ss.grep(Sketchup;;ComponentInstance) #insts=[]
                      dcs.each{|dc|insts << dc.instances}
                      insts.flatten!
                      insts.uniq!
                      insts.compact!
                      data=[]
                      insts.each{|inst|
                        defn=inst.definition
                        #name=defn.name.tr(sep,"_")
                        repname=defn.get_attribute("dynamic_attributes","repname",0).to_s
                  	  repmat=defn.get_attribute("dynamic_attributes","repmat",0).to_s
                  	  rept=defn.get_attribute("dynamic_attributes","rept",0).to_s
                  	  repl=defn.get_attribute("dynamic_attributes","repl",0).to_s
                  	  repw=defn.get_attribute("dynamic_attributes","repw",0).to_s
                  	  reppvc=defn.get_attribute("dynamic_attributes","reppvc",0).to_s
                        dat=repname+sep+repmat+sep+rept+sep+repl+sep+repw+sep+reppvc
                        data << dat
                      path=model.path
                      if not path or path==""
                        path=Dir.pwd
                        title="Untitled"
                      else
                        path=File.dirname(path)
                        title=model.title
                      end#if
                      ofile=File.join(path,title+'DCs.'+ext).tr("\\","/")
                      begin
                        file=File.new(ofile,"w")
                      rescue### trap if open
                        UI.messagebox("File;\n\n  "+ofile+"\n\nCannot be written - it's probably already open.\nClose it and try making it again...\n\nExiting...")
                  	  return nil
                      data.each{|d|file.puts(d)}
                      file.close
                      puts (data.length.to_s)+" DCs written to\n"+ofile
                      puts 'DONE.'
                      begin
                        UI.openURL("file;/"+ofile)
                      rescue
                    end#def
                  end#module
                    Edit this part:
                    to limits defs to those selected DC instances
                    #defs=model.definitions
                    ins = model.selection.grep(Sketchup;;ComponentInstance)
                    defs=[]
                    ins.each{|i|
                      next unless i.definition.attribute_dictionary("dynamic_attributes")
                      defs << i.definition
                    defs.uniq
                    There's probably a more elegant way to do this, but I'm trying to reuse the old code with minimal editing
                      mozarov
                      Hello TIG
                      I have changed the piece of code you gave me but now it doesnt get nested childrens DC attributes. Only selected Parents cabinet attributes are reported. My dynamic cabinet has nested dynamic parts which contains DC attributes RepL, RepW and so on. Please help, just one tiny step left.
                      Here is the code I have now.
                      	defs=[]
                      	ins.each{|i|
                      	defs.uniq
                          dcs=[]
                          defs.each{|dc|
                            dcs << dc
                          if not dcs
                           return nil
                          end#if
                          insts=[]
                          insts.flatten!
                          insts.uniq!
                          insts.compact!
                          data=[]
                          insts.each{|inst|
                            data << dat
                        You asked for selected DCs I gave you that !
                        Now you want any DCs inside the selected DCs ??
                        That's much more convoluted.
                        You could find all DCs in the definitions that have instances, then reduce that list by testing for those in the selection, OR those that have a DC instance that has a parent that's the definition of one of the nested DC instances...
                        But as I said it complicated and beyond simple advice at the moment...
                        Perhaps someone else can chip in while I' very busy on other things...
                          mozarov
                          Hi TIG
                          Thanks for your help. It just shows how little I understand abaut the task. May I ask for your permission to post this code somewhere else on the internet?
                          Besides if it isn't too hard I could pay for solving this problem. Please contact me if you interested.
                          Thanks again for your help.
                          • 4 / 4
