    [Plugin] LordOfTheToolbars - v2.9c - 20 Dec 24
    471 Posts 89 Posters 341.0k Views 88 Watching
    • fredo6F Offline
      @rv1974 said:
      Fredo, I guess there's some limitation inside the plugin that won't let the user to stretch a toolbar horizontally further than 150* icons (my idea is to use the display's bottom area 100% - from left to right edge) Could you extend this limitation please?
      Ok. The limit for a palette is width < 2000 pixels. I will extend it to 4000 px.
      @rv1974 said:
      I don't quite understand the meaning of 'Nb of columns' in the toolbar's properties. While it set to it's possible maximum value of 20 (why?) it still allows me to have 150 icons in a row.
      The number of columns (and rows) corresponds to the nominal size of the palette, which you can restore via its context menu. However, if you dimension palettes manually, you can have any size.
        rv1974
        That explains.. I've got 2560x1440 ones
          ltchest
          Does anyone know of a way to add the VRAY commands to a toolbar in LOTTB ? I'm using 1.5a & vray 5.10.06 in Sketchup pro 2021 v.21.1.299. VRAY is does not appear anywhere as an option for adding to LOTTB
          Sketchup 21.2.332 (windows 10.0.19043 Build 19043)
          RTX2070 + GTX1080, Driver 472.12
          • fredo6F Offline
            NEW RELEASE: LordOfTheToolbars v1.5b - 20 Sep 21
            Requirements
            • LibFredo6: v12.0a or above
            LordOfTheToolbars 1.5a is a minor release
            • Increase the maximum width of palettes to 5000 pixels
            Home Page of LordOfTheToolbars for information and Download.
            Main post of this LordOfTheToolbars thread.
            • fredo6F Offline
              NEW RELEASE: LordOfTheToolbars v1.5a - 17 Sep 21
              Requirements
              LordOfTheToolbars 1.5a is a major release
              • Rework of the import to be more explicit on what will be changed in the configuration based on a Import Summary Dialog
              • Automatic synchronization of configuration between multiple instances of Sketchup (Windows)
              • Compact mode for palette, without titlebar (Windows only)
              • Double-space to recall the last command (option in Default Parmeters)
              • Double Click in a palette to close it
              • Bug fixing and adjustments
              • fredo6F Offline
                You may have to restart Sketchup twice after installation of LOTT. The reason is that VRay installs in a special directory and arranges that its toolbars are not really accessible by program.
                • fredo6F Offline
                  @rv1974 said:
                  *)The precision of toolbar stretching (horizontally) is extremely poor, its 3-4 icons error.
                  It's nearly impossible to arrange icons precisely- very irritating.
                  How many icons do you have in the row?
                  @rv1974 said:
                  *)Sometimes some icons just don't show right click menu and the icons can't be deleted. They'd disappear only after SU restart.
                  Do you mean that you get the cursor showing as if you were doing a drag and drop?
                  @rv1974 said:
                  *)Locked toolbars and can't keep their locked position when SU window get relocated from monitor to monitor and back. In this regard, would it be possible to implement true docking?
                  True docking is not possible. When you move SU from one monitor to another, something happens which I don't understand. It might be that the API to dialog is buggy. Unfortunately, I have currently only one monitor (a laptop), so I cannot test.
                    rv1974
                    Some bug hunting here:
                    *)The precision of longtoolbar stretching (horizontally) is extremely poor, its up to 3-4 icons error. It's nearly impossible to arrange icons precisely - very irritating. On middle size toolbars it's almost OK - only 1 icon error.
                    *)Locked toolbars and vignette can't keep their lockedposition when SU window get relocated from monitor to monitor and back. In this regard, would it be possible to implement true docking?
                    Thank you
                      rv1974
                      ~90. all bottom area, from edge to edge.
                      I mean the menu attached below. Sometimes I grag new icons to my toolbar, then decide to say delete some of them, but nothing could be done because the right click menu is gone.
                      P.S. Another glitch I forgot to mention: Sometimes adding a separator would put it 3 icons to the left πŸ˜„
                        ltchest
                        [/quote]
                        You may have to restart Sketchup twice after installation of LOTT. The reason is that VRay installs in a special directory and arranges that its toolbars are not really accessible by program.[/quote]
                        Could you say a little more about this - i mean i have restarted Sketchup many times since installing LOTT. Should i uninstall LOTT, and then reinstall LOTT and then quite and start Sketchup twice, and then Bobs your Uncle ? thx
                        (Any news on the ability to make the vignette stay in position on the monitor where i want it ?)
                          simoncbevans
                          Great extension. I wonder if it is possible to make a custom made toolbar fly out? Would save getting in the way when you have it in the work area.
                            coreyfox
                            This is an amazing plugin! I have moved my workflow into using it, but as of yesterday it has been crashing my sketchup, before it can fully load, every time. See attachment - any suggestions on what might be happening here?
                            crash message
                            • fredo6F Offline
                              Which version of Sketchup are you running? If SU2021, please migrate to the latest version, because it solves issues related to menus.
                                ltchest
                                OK so i realise now that there is a switch to "Exclude" vray from the options, so i turned that off and it solved my problem. Amazing ! The only thing i really would appreciate would be to have control over where the vignette appears every time i start sketchup. Currently, i have to move it from Screen 2 onto Screen 1 every time 😞
                                R 1 Reply Last reply Reply Quote 0
                                  ltchest
                                  that is exactly what the vignette gives you
                                    coreyfox
                                    I'm on sketchup 2021.1.332
                                      ltchest
                                      one more thing about the Vignette. I am finding that, even without closing Sketchup, the Vignette jumps back over to the second screen (monitor). This doesnt happen all the time - just happens sometimes / occasionally. I will open a different drawing from Sketchup and the vignette moves back to where it was at startup 😞
                                        SingulArita
                                        Thank you for a great extension. Unfortunately, I have a few bugs. Line breaks are lost for some favorite vignettes. Icons rearrange and arrangement lose clarity. There is a problem with the line break for sure. Sometimes it happens to me that the icon duplicates and the original cannot be deleted, moved - right-clicked or removed the break before. I have not yet discovered the exact cause or procedure. But it's happening significantly and it's incredibly annoying.
                                        SketchUp 2020 20.0.363. Martin
                                        • H Offline
                                          hsy7758258
                                          on master toolbar manager,i can do noting,cant click or move the icon...
                                          show page dev tools,there are bug reporter
                                          • cmeedC Offline
                                            cmeed
                                            Hi Fredo,
                                            An amazing plugin - truly a game changer for Plugin reliant Su users! especially helpful on my laptop
                                            I got a suggestion and an issue.
                                            My suggestion is - could the palettes appear with the use of a shortcut then disappear when a plugin has been hit. with an option for the Palette to appear where the cursor is and in a user defined locations.
                                            My issue
                                            I'm having trouble altering my palettes. Icons/separators double up when I move them, with these ghost icons/separators I can't right click on them. Ive done al ot of combinations of holding shift / control but the its seems the same what ever combo i use....
                                            go here for a video of what i mean and then - of all things a crash!!
                                            https://www.dropbox.com/s/2rzj2dadzplgqxd/2021-11-10_21-58-55.mp4?dl=0
                                            Cheers
                                            • 13
                                            • 14
                                            • 15
                                            • 16
                                            • 17
                                            • 23
                                            • 24
                                            • 15 / 24
