    [Plugin] LordOfTheToolbars - v2.9c - 20 Dec 24
    452 Posts 87 Posters 314.2k Views 86 Watching
    • fredo6F Offline
      @designerbursa said:
      When I go full screen, the status text bar at the bottom disappears.
      This should be fixed in the latest version of LOTT.
      To make the status text bar reappear
      • Open the Ruby Console
      • type (or copy/paste) the following command: Sketchup.send_action 59393 and press Enter
        ltchest
        Great plugin. Only trouble i have is that it never remembers the location of the toolbar. Every time i open sketchup i have to move the toolbar to the location that i want.
        Also, it does not seem to recognise Vray.
        Sketchup 21.2.332 (windows 10.0.19043 Build 19043)
        RTX2070 + GTX1080, Driver 472.12
        • fredo6F Offline
          What do you mean by 'toolbar'?
          • favorite palette?
          • Sketchup regular toolbar?
          For VRay, which version do you have?
          • JustinTSEJ Offline
            JustinTSE
            At some point I closed the command stripe at the top of the page and I can't seem to get it back. I've updated LibFredo, unloaded and reloaded the extension, clicked all the buttons, etc.
            In addition, when I click the quick command finder button it's not doing anything.
            I'm on LibFredo 11.9C. I'm sure this is something simple that I'm missing
            Thanks so much for your work on this!
            • fredo6F Offline
              Justin,
              Normally, the only way to discard the Vignette Stripe is to use the menu LordOfTheToolbars > Toggle Visibility of the Vignette Stripe, which is also a way to restore it. Is it what you did?
              If ever it is off-screen, use menu LordOfTheToolbars > Reset Vignette Stripe Position.
              For the Command Finder, it could also be off-screen or there is a bug.
              I suggest you keep the Ruby console opened to see if there are errors showing.
                rv1974
                Regarding this Vignette Stripe.. it causes lot of troubles - it tends to get lost (because I sporadically drag SU windows from one monitor to another and use the switch to jump to another PC with the same monitors). Recovering from preferences file and Show Vignette Stripe command don't help. Luckily LordOfTheToolbars > Reset Vignette Stripe Position works, but its not ideal solution.
                • fredo6F Offline
                  When you move the Sketchup window, do you see the Vignette Stripe and the palettes moving along the Sketchup window?
                    rv1974
                    I'll check later, currently machines are busy with tons of renderings.
                      JustinTSE
                      Perfect! This is what I needed.
                      I was looking for the menu in the wrong place - I suspected some sort of user error 😎
                        JustinTSE
                        So...sorry to bug you again. Whenever I click the quick command finder button in the vignette stripe, nothing happens on the page. In the ruby console I get the following error.
                        Error: #<RangeError: invalid codepoint 0xD83C in UTF-8>
                        c:/users/justi/appdata/roaming/sketchup/sketchup 2021/sketchup/plugins/fredo6_!libfredo6/body_lib6g6.rbe:5283:in all_menus' c:/users/justi/appdata/roaming/sketchup/sketchup 2021/sketchup/plugins/fredo6_!libfredo6/body_lib6g6.rbe:5283:in menu_mapping'
                        c:/users/justi/appdata/roaming/sketchup/sketchup 2021/sketchup/plugins/fredo6_!libfredo6/body_lib6g6.rbe:5359:in menu_structured_list' c:/users/justi/appdata/roaming/sketchup/sketchup 2021/sketchup/plugins/!!fredo6_lordofthetoolbars/lordofthetoolbarsfinddialog.rbe:215:in prepare_data'
                        c:/users/justi/appdata/roaming/sketchup/sketchup 2021/sketchup/plugins/!!fredo6_lordofthetoolbars/lordofthetoolbarsfinddialog.rbe:134:in dialog_invoke' c:/users/justi/appdata/roaming/sketchup/sketchup 2021/sketchup/plugins/!!fredo6_lordofthetoolbars/lordofthetoolbarsmanager.rbe:5266:in minifind_invoke'
                        c:/users/justi/appdata/roaming/sketchup/sketchup 2021/sketchup/plugins/!!fredo6_lordofthetoolbars/lordofthetoolbarsvignettedialog.rbe:859:in minifind_invoke' c:/users/justi/appdata/roaming/sketchup/sketchup 2021/sketchup/plugins/!!fredo6_lordofthetoolbars/lordofthetoolbarsvignettedialog.rbe:590:in dialog_callback_exec'
                        c:/users/justi/appdata/roaming/sketchup/sketchup 2021/sketchup/plugins/!!fredo6_lordofthetoolbars/lordofthetoolbarsvignettedialog.rbe:565:in dialog_callback' c:/users/justi/appdata/roaming/sketchup/sketchup 2021/sketchup/plugins/fredo6_!libfredo6/body_lib6chromiumwdlg.rbe:2297:in call'
                        c:/users/justi/appdata/roaming/sketchup/sketchup 2021/sketchup/plugins/fredo6_!libfredo6/body_lib6chromiumwdlg.rbe:2297:in master_callback' c:/users/justi/appdata/roaming/sketchup/sketchup 2021/sketchup/plugins/fredo6_!libfredo6/body_lib6chromiumwdlg.rbe:2086:in j_action'
                        c:/users/justi/appdata/roaming/sketchup/sketchup 2021/sketchup/plugins/fredo6_!libfredo6/body_lib6chromiumwdlg.rbe:2045:in j_callback' c:/users/justi/appdata/roaming/sketchup/sketchup 2021/sketchup/plugins/fredo6_!libfredo6/body_lib6chromiumwdlg.rbe:2031:in block in j_dispatch'
                        c:/users/justi/appdata/roaming/sketchup/sketchup 2021/sketchup/plugins/fredo6_!libfredo6/body_lib6chromiumwdlg.rbe:2023:in each' c:/users/justi/appdata/roaming/sketchup/sketchup 2021/sketchup/plugins/fredo6_!libfredo6/body_lib6chromiumwdlg.rbe:2023:in j_dispatch'
                        c:/users/justi/appdata/roaming/sketchup/sketchup 2021/sketchup/plugins/fredo6_!libfredo6/body_lib6chromiumwdlg.rbe:1332:in `block in create_dialog'
                        I'm currently running LibFredo 11.9c and LordofTheToolbars 1.4d.
                        If I click the quick command finder in the toolbar on the screen, I get this error and it hides the vignette stripe
                        c:/users/justi/appdata/roaming/sketchup/sketchup 2021/sketchup/plugins/!!fredo6_lordofthetoolbars/bootstrap_lordofthetoolbars.rbe:351:in launch' c:/users/justi/appdata/roaming/sketchup/sketchup 2021/sketchup/plugins/!!fredo6_lordofthetoolbars/bootstrap_lordofthetoolbars.rbe:303:in action__mapping'
                        c:/users/justi/appdata/roaming/sketchup/sketchup 2021/sketchup/plugins/fredo6_!libfredo6/lib6plugin.rbe:129:in call' c:/users/justi/appdata/roaming/sketchup/sketchup 2021/sketchup/plugins/fredo6_!libfredo6/lib6plugin.rbe:129:in launch_action'
                        c:/users/justi/appdata/roaming/sketchup/sketchup 2021/sketchup/plugins/fredo6_!libfredo6/lib6plugin.rbe:227:in launch_action' c:/users/justi/appdata/roaming/sketchup/sketchup 2021/sketchup/plugins/!!fredo6_lordofthetoolbars/bootstrap_lordofthetoolbars.rbe:249:in launch_action'
                        c:/users/justi/appdata/roaming/sketchup/sketchup 2021/sketchup/plugins/!!fredo6_lordofthetoolbars/bootstrap_lordofthetoolbars.rbe:285:in block in declare_command' c:/users/justi/appdata/roaming/sketchup/sketchup 2021/sketchup/plugins/fredo6_!libfredo6/lib6plugin.rbe:1382:in command_invoke'
                        c:/users/justi/appdata/roaming/sketchup/sketchup 2021/sketchup/plugins/fredo6_!libfredo6/lib6plugin.rbe:1363:in block (2 levels) in build_config_commands' c:/users/justi/appdata/roaming/sketchup/sketchup 2021/sketchup/plugins/fredo6_!libfredo6/lib6traductor.rbe:1377:in block in add_command'
                        c:/users/justi/appdata/roaming/sketchup/sketchup 2021/sketchup/plugins/!!fredo6_lordofthetoolbars/controller_lordofthetoolbars.rbe:142:in `block in new'
                        • fredo6F Offline
                          @Justin,
                          Looks like there a plugin with an exotic menu entry (Chinese or so) and this is creating an error.
                          I'll see if I can either solve the problem or protect the code against this type of error.
                            rv1974
                            Well it appears that LOTT hates when SU window is dragged from one monitor to another.
                            *) The Vignette Palette (VP) completely disappears. 'Toggle VP visibility' and reset VP position' commands sometimes help sometimes don't. Pop up VP command works consistently well. Typically restarting SU restores UI order, but its kind of so-so solution.
                            *) If I have some lockedfavorite toolbar(s) and VP logically I'd expect them to be moved with SU window (=glued), now it's not happening.
                            *) the location of locked toolbars is messed when SU window come back to it's original place.
                              rv1974
                              Another observation (in complex files): opened command search (CS) window causes micro lags in navigation and triple click (to select connected edges) work inconsistently. Everything gets back to normal after CS is closed.
                                ltchest
                                Hello - I was referring to the vignette bar (pic attached / didnt realise what it was called before 😄. I am trying to keep this above the main toolbar space so it doesnt take up any screen space. BUT, every time i launch sketchup i have to move it back to where i want it. Is there a way to make this stay in position ? For VRAY, i am using 5.10.06. It does'nt make any difference where i position it on the screen, it always reverts back to the same place on my second monitor (which is not where i need it). I tried the option to lock it in position, but it makes no difference in my case.
                                thanks for looking into it !
                                • favorite palette?
                                  [attachment=2:2rugi70v]<!-- ia2 -->LOTT Favorite palette.png<!-- ia2 -->[/attachment:2rugi70v]
                                  [attachment=1:2rugi70v]<!-- ia1 -->LOTT Sketchup toolbar.png<!-- ia1 -->[/attachment:2rugi70v]
                                  rv1974
                                  Wow! This is truly remarkable release! Thank you so much your efforts!
                                  • fredo6F Offline
                                    For the compact palette, I did not find a way to remove the small top frame, while keeping the window resizable. Apparently, this is Windows 10 focing this appearance.
                                      rv1974
                                      Fredo, I guess there's some limitation inside the plugin that won't let the user to stretch a toolbar horizontally further than 150* icons (my idea is to use the display's bottom area 100% - from left to right edge) Could you extend this limitation please?
                                      *- I don't quite understand the meaning of 'Nb of columns' in the toolbar's properties. While it set to it's possible maximum value of 20 (why?) it still allows me to have 150 icons in a row.
                                      P.S. Double Spasebar for last command is so nice!
                                      • fredo6F Offline
                                        Ok. The limit for a palette is width < 2000 pixels. I will extend it to 4000 px.
                                        The number of columns (and rows) corresponds to the nominal size of the palette, which you can restore via its context menu. However, if you dimension palettes manually, you can have any size.
                                          rv1974
                                          That explains.. I've got 2560x1440 ones
                                            ltchest
                                            Does anyone know of a way to add the VRAY commands to a toolbar in LOTTB ? I'm using 1.5a & vray 5.10.06 in Sketchup pro 2021 v.21.1.299. VRAY is does not appear anywhere as an option for adding to LOTTB
                                            • 22
                                            • 23
                                            • 7 / 23
