    Medeek Wall Plugin
    1.6k Posts 29 Posters 2.2m Views 28 Watching
    • medeekM
      medeek
      Version 2.2.6 - 08.01.2021
      • Fixed a minor bug with tee intersections for all wall types.
      Nathaniel P. Wilkerson PE
      Medeek Engineering Inc
      design.medeek.com
      • medeekM
        medeek
        Version 2.2.7 - 08.03.2021
        • Added insulation to the Medeek Estimator for rectangular walls.
        http://design.medeek.com/resources/wallplugin/images2/wall_su567_800.jpg
        design.medeek.com
        • medeekM
          medeek
          Version 2.2.8 - 08.04.2021
          • Fixed a bug with blocking and insulation for portal frame garage doors within rectangular walls.
          http://design.medeek.com/resources/wallplugin/images2/wall_su568_800.jpg
          Portal frames add a good deal of complexity to the framing, blocking and insulation. Some of the details were not completely worked out previously. I think I now have most if not all of these issues addressed.
          I also may need to spend some additional time on the holdown placement when multiple portal frames are adjacent to each other like in the example shown.
          design.medeek.com
          • medeekM
            medeek
            mdkBIM Tutorial 1: Modeling a Two Car Detached Garage (41:14 min.)
            A few issues popped out during the making of this tutorial:
            1.) Portal frame holdown placement, custom deletion and redundancy, feedback required.
            2.) Wall copy tool did not copy the insulation option setting.
            3.) The insulation algorithm seems inconsistent when dealing with tee intersections.
            View garage model here:
            3D Warehouse
            (3dwarehouse.sketchup.com)
            design.medeek.com
            • medeekM
              medeek
              Version 2.2.9 - 08.06.2021
              • Fixed a bug with framing, blocking and insulation for tee intersections for all wall types.
              • Fixed a minor bug with six panel doors when the door vertical offset is a non-zero value.
              http://design.medeek.com/resources/wallplugin/images2/wall_su569_800.jpg
              This resolves the issue #3 noted in the recent mdkBIM tutorial. I would highly recommend installing this latest update.
              design.medeek.com
              • medeekM
                medeek
                Version 2.3.0 - 08.08.2021
                • Fixed a bug with wall presets for rectangular walls.
                !!!! CRITICAL BUG FIX !!!!
                If you are using wall presets with rectangular walls and have upgraded to Version 2.2.4 or later then you will want to upgrade to this latest version which rectifies a bug introduced in Version 2.2.4.
                design.medeek.com
                • medeekM
                  medeek
                  Version 2.3.1 - 08.09.2021
                  • Added a vertical offset parameter for cladding material for gable walls.
                  • Added a vertical offset parameter for "Log" and "Shiplap" cladding materials for gable walls.
                  • Added a horizontal offset parameter for cladding material for gable walls.
                  • Added a horizontal offset parameter for "Board and Batten" and "Metal" 3D cladding materials for gable walls.
                  design.medeek.com
                  • medeekM
                    medeek
                    Version 2.3.2 - 08.12.2021
                    • Added a vertical offset parameter for cladding material for shed and hip walls.
                    • Added a vertical offset parameter for "Log" and "Shiplap" cladding materials for shed and hip walls.
                    • Added a horizontal offset parameter for cladding material for shed and hip walls.
                    • Added a horizontal offset parameter for "Board and Batten" and "Metal" 3D cladding materials for shed and hip walls.
                    Some rather tedious code updates but important that these wall types have all the options of the rectangular wall type.
                    design.medeek.com
                    • medeekM
                      medeek
                      Version 2.3.3 - 08.17.2021
                      • Fixed a minor bug with sliding glass doors when the door vertical offset is a non-zero value.
                      http://design.medeek.com/resources/wallplugin/images2/wall_su570_800.jpg
                      design.medeek.com
                      • medeekM
                        medeek
                        Version 2.3.4 - 08.18.2021
                        • Added logic into the add and edit menus to prevent users from using single and double quotes in beam and header names.
                        • Added logic into all HTML menus to prevent users from using vertical bars in beam and header names and within preset names.
                        design.medeek.com
                        • medeekM
                          medeek
                          Version 2.3.5 - 08.21.2021
                          • Fixed a bug with Simpson Strong Walls when "Terminal" wall end conditions are used in a wall assembly.
                          • Modified the "Edit Wall Assembly" context menu tool so that it behaves similar to the "Edit Wall" tool.
                          • Fixed a bug with the wall stretch tool so it now allows for wall stretch or shrinks that are less than 3".
                          • Enabled spaced headers (2 ply or 3 ply) for windows, doors and garages by using the key word "FILL" in the header description.
                          http://design.medeek.com/resources/wallplugin/images2/wall_su571_800.jpg
                          http://design.medeek.com/resources/wallplugin/images2/wall_su572_800.jpg
                          *Note, that the header must by a 2 ply or 3 ply header to use a spacer as shown. Also the header description must include a string in this format "FILL_OSB_0.375" or "FILL_PLY_0.4375". The second term is either OSB or PLY which will determine the material to use as the spacer. The third term is the thickness of the spacer (ie. 0.25, 0.375, 0.4375, 0.5 etc...). In a metric template you can specify the spacer thickness in millimeters instead of inches.
                          design.medeek.com
                          • medeekM
                            medeek
                            Version 2.3.6 - 08.23.2021
                            • Enabled a trim option for wrapped free standing columns.
                            http://design.medeek.com/resources/wallplugin/images2/wall_su573_800.jpg
                            The trim combined with the cap or astragal can give even more variations.
                            design.medeek.com
                            • medeekM
                              medeek
                              Version 2.3.7 - 08.28.2021
                              • Added gable walls to the Medeek Estimator.
                              • Fixed a MacOS/Windows bug with the wall justification hotkey for all wall types.
                              I still need to add in Shed and Hip walls but it will go much quicker now that I have the gable walls as a template.
                              design.medeek.com
                              • medeekM
                                medeek
                                Version 2.3.8 - 08.29.2021
                                • Added shed and hip walls to the Medeek Estimator.
                                • Adjusted the auto-corner configuration algorithm to better predict terminal wall configurations when three walls come together at an inside or outside corner.
                                When multiple walls come together at a corner or junction it is arguably quite hard to predict the intent and desired configuration of the builder/designer/user.
                                I think what I have now addresses the immediate issue where a tee intersection was being created instead of a terminal connection, per the previous discussion.
                                I will need to continue to test this new algorithm further (put it through its paces) and also receive additional feedback from users. If you notice anything that appears unpredictable or counter-intuitive please feel free to email me so we can discuss.
                                design.medeek.com
                                • medeekM
                                  medeek
                                  Version 2.3.9 - 08.31.2021
                                  • Added a window clearance (shim space) parameter within the Windows tab of the Globals Settings.
                                  http://design.medeek.com/resources/wallplugin/images2/wall_su574_800.jpg
                                  Previously the shim space or window clearance was hard coded in as 1/4" or 6.35mm. Now the user can customize this clearance between the rough opening framing and the window frame. If you do adjust this parameter you will probably also want to adjust the Window Trim Inset parameter so it matches, this way the window trim will butt up against the window frame tight.
                                  This was a user requested update from New Zealand.
                                  design.medeek.com
                                  • medeekM
                                    medeek
                                    Version 2.4.0 - 09.01.2021
                                    • Fixed a bug with spaced headers when applied to trapezoidal windows.
                                    http://design.medeek.com/resources/wallplugin/images2/wall_su575_800.jpg
                                    This bug fix only applies to window headers since there are no sloped headers for doors or garage doors. This fix applies to 2-ply and 3-ply spaced headers.
                                    design.medeek.com
                                    • medeekM
                                      medeek
                                      Version 2.4.1b - 09.09.2021
                                      • Changed the wall justification hotkey/option from the "Tab" key to the "Alt" key (Option key) for rectangular, shed, gable and hip draw wall tools.
                                      design.medeek.com
                                      • medeekM
                                        medeek
                                        I am pleased with the continual and steady progress made on the Wall plugin over the course of this summer. In light of this recent progress and in hopes of allowing more users access to the features of the plugins I will be immediately offering 10% off of the mdkBIM bundle price using the coupon codeLABORDAY21. (Sept. 11, 2021 thru Sept. 30, 2021).
                                        This will reduce the bundle price from $280.00 USD to $252.00 USD. This promo code is also valid when purchasing the Wall plugin separately as well as the Electrical plugin. The offer ends on Sept. 30th and no rain checks will issued thereafter.
                                        https://aws1.discourse-cdn.com/sketchup/original/3X/c/3/c3970710a908159beeec5e989b8ac88bb909bd20.jpeg
                                        design.medeek.com
                                        • medeekM
                                          medeek
                                          Matt Donley did a great job on putting this video together. A concise but very informative presentation:
                                          design.medeek.com
                                          • medeekM
                                            medeek
                                            I've been giving the "wall sandwich" thing some serious thought the last couple of days and I think I can implement a workable system however it will drastically change the way I am currently doing things as well as break any sort of backwards compatibility with previous versions of the plugin and their models.
                                            In the global settings I will probably have a select number of options you can choose from to build your custom wall sandwich (I will also have some standard ones pre-defined). Interior and Exterior walls will be different in that you cannot use wainscot and cladding with interior walls. Interior walls can be asymmetric with this new system so you can have different layers specified on each sides of the wall, unlike the current system which limits interior walls to symmetric configurations only.
                                            Exterior Walls:
                                            Ext. Side:
                                            • Wainscot
                                            • Cladding 1
                                            • Cladding 2
                                            • Airgap 1, 2, 3 etc...
                                            • Sheathing 1
                                            • Sheathing 2
                                            • Insul 1
                                            Int. Side:
                                            • Gypsum 1
                                            • Gypsum 2
                                            • Gypsum 3
                                            • Airgap 1,2, 3 etc...
                                            • Sheathing 1
                                            • Sheathing 2
                                            • Insul 1
                                            Interior Walls:
                                            Ext. Side:
                                            • Gypsum 1
                                            • Gypsum 2
                                            • Gypsum 3
                                            • Sheathing 1
                                            • Sheathing 2
                                            • Insul 1
                                            Int. Side:
                                            • Gypsum 1
                                            • Gypsum 2
                                            • Gypsum 3
                                            • Sheathing 1
                                            • Sheathing 2
                                            • Insul 1
                                            The actual layering can be in any order except for wainscot which will always be the outermost layer on an ext. wall. I'm not sure that two layers of cladding are really needed for an ext. wall but I'm just throwing it out there for now and see what sticks.
                                            As far as the framing/wall solid is concerned I only plan on having one layer for framing, if I were to change that up to a variable number of framing layers things would get very complicated with regards to corner configurations so it is best to not get too ambitious.
                                            The items shown are all of the possible layers for each side of the wall in question, one could theoretically enable all of them or none of them, and the number of air gaps is probably not limited.
                                            Am I missing anything? Thoughts?
                                            Your feedback now is important, once I install/implement a new wall sandwich system it will be more difficult to fundamentally change it from the form it originally takes.
                                            design.medeek.com
                                            • 54
                                            • 55
                                            • 56
                                            • 57
                                            • 58
                                            • 80
                                            • 81
                                            • 56 / 81
