    Fredo6 Animator Can't Render w/ Vray
    5 Posts 2 Posters 4.8k Views 2 Watching
    • F
      Floedekage
      I've played with Fredo6 Animator some time ago and just got back to it. I had never gotten around to setting up a scene and trying to render it with Vray, so I've played around with it the past week.
      It seems I can't get it ro render using Vray -- not even a test image.
      The Ruby Console feedback is as follows:
      Test Image w/ Vray
      Error; #<ArgumentError; wrong number of arguments (0 for 1)>
      c;/users/kenny/appdata/roaming/sketchup/sketchup 2017/sketchup/plugins/fredo6_!libfredo6/body_lib6videomanager.rbe;495;in `init'
      c;/users/kenny/appdata/roaming/sketchup/sketchup 2017/sketchup/plugins/fredo6_!libfredo6/body_lib6videomanager.rbe;495;in `rendering_vray4_frame'
      c;/users/kenny/appdata/roaming/sketchup/sketchup 2017/sketchup/plugins/fredo6_!libfredo6/body_lib6videomanager.rbe;310;in `call'
      c;/users/kenny/appdata/roaming/sketchup/sketchup 2017/sketchup/plugins/fredo6_!libfredo6/body_lib6videomanager.rbe;310;in `rendering_frame'
      c;/users/kenny/appdata/roaming/sketchup/sketchup 2017/sketchup/plugins/fredo6_!libfredo6/body_lib6videomanager.rbe;1343;in `sample_image'
      c;/users/kenny/appdata/roaming/sketchup/sketchup 2017/sketchup/plugins/fredo6_animator/animatordialogvideogeneration.rbe;1475;in `request_sample_image'
      c;/users/kenny/appdata/roaming/sketchup/sketchup 2017/sketchup/plugins/fredo6_animator/animatordialogvideogeneration.rbe;1325;in `param_dialog_callback'
      c;/users/kenny/appdata/roaming/sketchup/sketchup 2017/sketchup/plugins/fredo6_!libfredo6/body_lib6webwdlg.rbe;844;in `call'
      c;/users/kenny/appdata/roaming/sketchup/sketchup 2017/sketchup/plugins/fredo6_!libfredo6/body_lib6webwdlg.rbe;844;in `j_action'
      c;/users/kenny/appdata/roaming/sketchup/sketchup 2017/sketchup/plugins/fredo6_!libfredo6/body_lib6webwdlg.rbe;710;in `j_callback'
      c;/users/kenny/appdata/roaming/sketchup/sketchup 2017/sketchup/plugins/fredo6_!libfredo6/body_lib6webwdlg.rbe;698;in `block in j_dispatch'
      c;/users/kenny/appdata/roaming/sketchup/sketchup 2017/sketchup/plugins/fredo6_!libfredo6/body_lib6webwdlg.rbe;690;in `each'
      c;/users/kenny/appdata/roaming/sketchup/sketchup 2017/sketchup/plugins/fredo6_!libfredo6/body_lib6webwdlg.rbe;690;in `j_dispatch'
      c;/users/kenny/appdata/roaming/sketchup/sketchup 2017/sketchup/plugins/fredo6_!libfredo6/body_lib6webwdlg.rbe;358;in `block in create_dialog'
      SketchUp;1;in `call'
      Generate Video w/ Vray
      ;beg_time => 0
      ;end_time => 20.0
      ;frame_rate => 25
      ;speed_factor => 1.0
      ;reversed_play => nil
      ;transparent => false
      ;dimX => 1034
      ;dimY => 590
      ;dim_mode => "viewport"
      ;filter => {
      }  (;filter)
      ;root_dir => "C;/Users/Kenny/Documents/Animator Videos"
      ;movie_dir => "34ths - 16-Aug-2021 00-57-56"
      ;movie_name => "Film 1"
      ;date_modified => 1629067231.09253
      ;break_aspect_ratio => nil
      ;movie_formats => {
         ;mp4 => true
         ;mov => true
      }  (;movie_formats)
      ;rendering_method => ;vray4
      MOVIE PX = 1034 PY = 590 transpa = false
      FORMATTED===========================
      c;/users/kenny/appdata/roaming/sketchup/sketchup 2017/sketchup/plugins/fredo6_!libfredo6/body_lib6videomanager.rbe;1094;in `movie_robot'
      c;/users/kenny/appdata/roaming/sketchup/sketchup 2017/sketchup/plugins/fredo6_!libfredo6/body_lib6videomanager.rbe;1012;in `block in movie_top_generate'
      Command FFmpeg for mp4 = "C;/Program Files/FFmpeg/ffmpeg.exe" -framerate 25 -i "Image%03d.png" -c;v libx264 -pix_fmt yuv420p -q;v 1 -vf scale=2*trunc(iw/2*3);-2 "Film 1.mp4" 2> FFmpeg_log_mp4.txt
      ===> Status FFmpeg for mp4 = false
      What am I doing wrong? I've tried following some other posts and delete appdata/LibFredo folder, repairing sketchup etc.
      • fredo6F
        Which version of VRay do you have installed?
        It seems to be a v4.x, but there is something wrong.
        • F
          Floedekage
          Hi Fredo6, I've got Vray version 3.40.02 installed. Thanks for the quick response. πŸ˜„
          • fredo6F
            I think Animator only supports VRay 4.2 and above.
            • F
              Floedekage
              Alright. I've been afraid of updating Vray ever since I set it up exactly as I needed it some years ago. Of course it worked perfectly after updating. πŸ‘ Thanks for the help Fredo and I'm sorry if this was written somewhere and I've just completely overlooked it.
