    Medeek Wall Plugin
    1.6k Posts 29 Posters 2.4m Views 28 Watching
    • medeekM
      medeek
      After some discussion with various stakeholders (ie. super users) and considering the competition (ie. Revit LT) here is a more competitively priced version 2 of the new pricing schedule:
      1.) Subscription License:
      Medeek Wall $50.00/year
      Medeek Truss $50.00/year
      Medeek Foundation $40.00/year
      Medeek Electrical $30.00/year
      mdkBIM $120.00/year (Wall, Truss, Foundation)
      2a.) Permanent License: (NEW with free renewals for one year)
      Medeek Wall $150.00
      Medeek Truss $150.00
      Medeek Foundation $120.00
      Medeek Electrical $90.00
      mdkBIM $320.00 (Wall, Truss, Foundation)
      2b.) Permanent License: (RENEW for one year)
      Medeek Wall $75.00
      Medeek Truss $75.00
      Medeek Foundation $60.00
      Medeek Electrical $45.00
      Nathaniel P. Wilkerson PE
      Medeek Engineering Inc
      design.medeek.com
      • medeekM
        medeek
        The new licensing and pricing structure is now live.
        *Note: Licenses or serial numbers are independent and cannot be converted from permanent to subscription or vice versa.
        Only permanent licenses can be renewed. Subscription licenses simply expire at the end of their term and a new (1 year) subscription can be purchased.
        A subscription does not mean you are auto-enrolled into purchasing a new subscription at the end of your subscription term, it is up to the user to purchase a new license at the end of the subscription term or simply discontinue the use of the plugin and not purchase a new subscription.
        design.medeek.com
        • medeekM
          medeek
          Version 2.2.3 - 07.11.2021
          • Added the ability to create custom "Metal" wall cladding materials within the Material Library.
          • Enabled "3D" Metal wall cladding for all wall types: Rectangular, Gable, Shed and Hip.
          http://design.medeek.com/resources/wallplugin/images2/wall_su560_800.jpg
          http://design.medeek.com/resources/wallplugin/images2/wall_su561_800.jpg
          http://design.medeek.com/resources/wallplugin/images2/wall_su559_800.jpg
          The "metal" 3D cladding requires four numeric parameters:
          metal_9.0_1.0_0.75_45
          The first number is the rib spacing, the second number is the rib width, the third number is the rib depth and the fourth number is the angle of the rib bend. 45 and 60 degrees are probably the most typical here.
          You can also now append further descriptive text on the end of the string, for example:
          metal_9.0_1.0_0.75_45_ascblue
          This also applies for all other 3D cladding names/types.
          The base thickness of the metal cladding is controlled by the cladding thickness parameter for the wall.
          design.medeek.com
          • medeekM
            medeek
            Version 2.2.4 - 07.12.2021
            • Added a horizontal offset parameter for cladding material for rectangular walls.
            • Added a horizontal offset parameter for "Board and Batten" and "Metal" 3D cladding materials for rectangular walls.
            This parameter will allow the custom horizontal positioning of the cladding material/texture so that multi-story structures can be properly rendered.
            !!! CAUTION !!!
            This update adds one new parameter to the rectangular walls and will require the user to delete and recreate any rectangular wall presets. This upgrade does not affect gable wall or any other presets (ie. windows, door, garage, gable wall, shed wall, hip wall).
            http://design.medeek.com/resources/wallplugin/images2/wall_su562_800.jpg
            Note that you can use both vertical and horizontal offsets at the same time or separately, giving you full control over the cladding placement/alignment.
            design.medeek.com
            • medeekM
              medeek
              Version 2.2.5 - 07.16.2021
              • Added an additional (advanced framing) layer for window sills into the Layers tab of the Global Settings.
              http://design.medeek.com/resources/wallplugin/images2/wall_su563_800.jpg
              design.medeek.com
              • medeekM
                medeek
                Now that I've found a natural break in the Truss plugin development I want to address the wall preset issue that has been dogging me for way too long.
                My idea has always been to make the storage system for the presets manually editable by the user (if required) so I have simply stored the data as long strings of text in a simple text file (.txt)
                Here is an example of a bunch of wall presets:
                Medeek Wall Preset File
                2|Stucco Rockwool|20210510115553|Int-Ext|Front|97.125|80.0|5.5|1.5|16.0|Left|0.0|2|1.5|1|1.5|NO|YES|Outside Corner|90.0|1.5|1|California|Stud Depth|YES|Outside Corner|90.0|1.5|1|California|Stud Depth|YES|YES|0.4375|FLUSH|YES|0.25|0.0|MITER|YES|5.0|NO|YES|0.0|0.0|0.0|0.0|0.0|ZIP_12|STUCCO_LIGHT_TAN|WALLGYPSUM|RKW|YES|NO|NO|NO|NO|0.5|WALLGYPSUM|NO|0.4375|FLUSH|ZIP_12|Center|YES|1|48.0|ON SHEATHING|0.75|YES|3.5|YES|3.5|YES|#ffffff|YES|3.5|0.75|NO|48.0|YES|5.5|0.75|NO|YES|7.25|0.75|YES|YES|0.75|1.25|36.0|4.0|1.0|MITER|BRICK_RED|YES|4.0|1.0|YES|0.0|0.0|MODE1|BRICK_RED|A|16.0|12.0|12.0|2.0|1.0|QUOIN
                3|Stucco Pink|20210510124401|Int-Ext|Front|97.125|80.0|5.5|1.5|16.0|Left|0.0|2|1.5|1|1.5|NO|YES|Outside Corner|90.0|1.5|1|California|Stud Depth|YES|Outside Corner|90.0|1.5|1|California|Stud Depth|YES|YES|0.4375|FLUSH|YES|0.25|0.0|MITER|YES|0.5|YES|NO|0.0|0.0|0.0|0.0|0.0|OSB_FELT|STUCCO_LIGHT_TAN|WALLGYPSUM|PFG|NO|NO|NO|NO|NO|0.5|WALLGYPSUM|NO|0.4375|FLUSH|OSB_FELT|HDU8|0.0|SB78-24|24.0|BOTH|FRAMING|Center|YES|1|48.0|ON SHEATHING|0.75|YES|3.5|YES|3.5|YES|#ffffff|YES|3.5|0.75|NO|48.0|YES|5.5|0.75|NO|YES|7.25|0.75|YES|YES|0.75|1.25|36.0|4.0|1.0|MITER|BRICK_RED|YES|4.0|1.0|YES|0.0|0.0|MODE1|BRICK_RED|A|16.0|12.0|12.0|2.0|1.0|QUOIN
                4|test2|20210510145752|Int-Ext|Front|97.125|80.0|5.5|1.5|16.0|Left|0.0|2|1.5|1|1.5|NO|YES|Outside Corner|90.0|1.5|1|California|Stud Depth|YES|Outside Corner|90.0|1.5|1|California|Stud Depth|YES|YES|0.4375|FLUSH|YES|0.25|0.0|MITER|YES|0.5|NO|NO|0.0|0.0|0.0|0.0|0.0|OSB|HARDI_CM_HM|WALLGYPSUM|PFG|NO|NO|NO|NO|NO|0.5|WALLGYPSUM|NO|0.4375|FLUSH|OSB|HDU8|0.0|SB78-24|24.0|BOTH|FRAMING|Center|YES|1|48.0|ON SHEATHING|0.75|YES|3.5|YES|3.5|YES|#ffffff|YES|3.5|0.75|NO|48.0|YES|5.5|0.75|NO|YES|7.25|0.75|YES|YES|0.75|1.25|36.0|4.0|1.0|MITER|BRICK_RED|YES|4.0|1.0|YES|0.0|0.0|MODE1|BRICK_RED|A|16.0|12.0|12.0|2.0|1.0|QUOIN
                5|4/2 Wall|20210510145837|Int-Ext|Front|97.125|80.0|5.5|1.5|16.0|Left|0.0|2|1.5|1|1.5|NO|YES|Outside Corner|90.0|1.5|1|California|Stud Depth|YES|Outside Corner|90.0|1.5|1|California|Stud Depth|YES|YES|0.4375|FLUSH|YES|0.25|0.0|MITER|YES|0.5|NO|NO|0.0|0.0|0.0|0.0|0.0|OSB|HARDI_CM_HM|WALLGYPSUM|PFG|NO|NO|NO|NO|NO|0.5|WALLGYPSUM|NO|0.4375|FLUSH|OSB|HDU8|0.0|SB78-24|24.0|BOTH|FRAMING|Center|YES|1|48.0|ON SHEATHING|0.75|YES|3.5|YES|3.5|YES|#ffffff|YES|3.5|0.75|NO|48.0|YES|5.5|0.75|NO|YES|7.25|0.75|YES|YES|0.75|1.25|36.0|4.0|1.0|MITER|BRICK_RED|YES|4.0|1.0|YES|0.0|0.0|MODE1|BRICK_RED|A|16.0|12.0|12.0|2.0|1.0|QUOIN
                6|120wall|20210606121902|Int-Ext|Front|120.0|80.0|5.5|1.5|16.0|Left|0.0|2|1.5|1|1.5|NO|YES|Outside Corner|90.0|1.5|1|California|Stud Depth|YES|Outside Corner|90.0|1.5|1|California|Stud Depth|YES|YES|0.4375|FLUSH|YES|0.25|0.0|MITER|YES|0.5|NO|NO|0.0|0.0|0.0|0.0|0.0|OSB|HARDI_CM_HM|WALLGYPSUM|PFG|NO|NO|NO|NO|NO|0.5|WALLGYPSUM|NO|0.4375|FLUSH|OSB|HDU8|0.0|SB78-24|24.0|BOTH|FRAMING|Center|YES|1|48.0|ON SHEATHING|0.75|YES|3.5|YES|3.5|YES|#ffffff|YES|3.5|0.75|NO|48.0|YES|5.5|0.75|NO|YES|7.25|0.75|YES|YES|0.75|1.25|36.0|4.0|1.0|MITER|BRICK_RED|YES|4.0|1.0|YES|0.0|0.0|MODE1|BRICK_RED|A|16.0|12.0|12.0|2.0|1.0|QUOIN
                7|150HD|20210606122002|Int-Ext|Front|150.0|80.0|5.5|1.5|16.0|Left|0.0|2|1.5|1|1.5|NO|YES|Outside Corner|90.0|1.5|1|California|Stud Depth|YES|Outside Corner|90.0|1.5|1|California|Stud Depth|YES|YES|0.4375|FLUSH|YES|0.25|0.0|MITER|YES|0.5|NO|YES|0.0|0.0|0.0|0.0|0.0|OSB|HARDI_CM_HM|WALLGYPSUM|PFG|NO|NO|NO|NO|NO|0.5|WALLGYPSUM|NO|0.4375|FLUSH|OSB|HDU8|0.0|SB78-24|24.0|BOTH|FRAMING|Center|YES|1|48.0|ON SHEATHING|0.75|YES|3.5|YES|3.5|YES|#ffffff|YES|3.5|0.75|NO|48.0|YES|5.5|0.75|NO|YES|7.25|0.75|YES|YES|0.75|1.25|36.0|4.0|1.0|MITER|BRICK_RED|YES|4.0|1.0|YES|0.0|0.0|MODE1|BRICK_RED|A|16.0|12.0|12.0|2.0|1.0|QUOIN
                8|150BLKHD|20210606122102|Int-Ext|Front|150.0|80.0|5.5|1.5|16.0|Left|0.0|2|1.5|1|1.5|NO|YES|Outside Corner|90.0|1.5|1|California|Stud Depth|YES|Outside Corner|90.0|1.5|1|California|Stud Depth|YES|YES|0.4375|FLUSH|YES|0.25|0.0|MITER|YES|0.5|NO|YES|0.0|0.0|0.0|0.0|0.0|OSB|HARDI_CM_HM|WALLGYPSUM|PFG|YES|NO|NO|NO|NO|0.5|WALLGYPSUM|NO|0.4375|FLUSH|OSB|HDU8|0.0|SB78-24|24.0|BOTH|FRAMING|Center|YES|1|48.0|ON SHEATHING|0.75|YES|3.5|YES|3.5|YES|#ffffff|YES|3.5|0.75|NO|48.0|YES|5.5|0.75|NO|YES|7.25|0.75|YES|YES|0.75|1.25|36.0|4.0|1.0|MITER|BRICK_RED|YES|4.0|1.0|YES|0.0|0.0|MODE1|BRICK_RED|A|16.0|12.0|12.0|2.0|1.0|QUOIN
                Notice how I've used the vertical bar to separate the values/parameters, any deliminator could be used but the vertical bar is not something one would use typically in any of the fields as values so it makes for a convenient choice.
                This system works well enough for storing and retrieving the data however the huge downside is that it is an ordered array of values and if I add in a new parameter (somewhere in the middle) then it throws off previous versions of preset files (ie. no backward compatibility).
                I need a better way or method of storing this data. It can't be binary since it needs to be visible to the user but it needs to be either some sort of structure, hash or XML so that I can easily add additional parameters to the system when required.
                Any suggestions?
                design.medeek.com
                • jujuJ
                  juju
                  @medeek said:
                  Any suggestions?
                  my 10c (excl. taxes)
                  The external user editable file is a great idea, but looking at the TXT file example I don't think someone will want to play with it, it's not clear what the various parameters each do (it might be to some though).
                  Perhaps consider writing a multi-platform app that interpret all of it (read and write) with a friendly user interface. I guess this brings you back to the extension really then? Keeping the external file with the saved settings would still be handy and can be readily backed up.
                  If you really want to have the parameters manually editable, perhaps a comprehensive guide would be sufficient? You don't need to teach construction or regulations, just explain (with examples perhaps) what the various parameters do.
                  • medeekM
                    medeek
                    I’m thinking I could probably preserve my overall system as is and just use a custom text method rather than JSON or some other more cumbersome system.
                    I agree the current text file only includes the value and not the key so it is hard to interpret even for myself.
                    Essentially the first two parameters would remain the same (ie. preset number and preset name).
                    However all of the other entries (that are deliminated by the vertical bars) would change from a simple value to a key/value pair.
                    For example instead of
                    |Int-Ext|
                    I would change it to
                    |walltype=Int-Ext|
                    The equal sign would become the secondary deliminator. I can still store the entire string as a single line in my text files however it will become approximately double in length (no big deal).
                    I can then split the string into an array and then run a foreach on the array and turn it into a hash, from there it is just a matter of pulling data from the the hash.
                    Any thoughts on this plan and possible flaws I may have overlooked?
                    design.medeek.com
                    • medeekM
                      medeek
                      Stacked windows and doors have been a topic a few times on this thread and I have incrementally improved the algorithms so that the plugin can deal with them.
                      However there still exists the situation where you have openings stacked that are not aligned or possibly the same size:
                      https://aws1.discourse-cdn.com/sketchup/original/3X/7/0/70c93c65fd1c86468ffa1e7bc43ea030e7b4e8c6.jpeg
                      My feeling is one should avoid this type of situation in ones design but apparently it comes up often enough that I find myself fielding questions on how best to deal with this type of configuration. Currently the easiest way to deal with it is to use the Trim and Split tool available in Truss plugin so that you end up with something like this:
                      https://aws1.discourse-cdn.com/sketchup/original/3X/b/0/b04c7aef4320cd284cfccfa2d5bbef21b627525d.jpeg
                      The problem with this is that we are now back to manual edits and we lose the parametrics of the plugin, so the solution is not really acceptable for many, myself included.
                      1.) My first question is how common is this sort of thing and is it something I should worry about? No point in spending a lot of time on a specific framing situation that is only the concern of less that 5% of the user base.
                      2.) The next question assuming that question #1 is the affirmative is how best to frame out this sort of situation. Is what I have in the second screenshot the correct way to handle this?
                      design.medeek.com
                      • medeekM
                        medeek
                        Tutorial 22 - Wall Copy Tool (6:21 min.)
                        design.medeek.com
                        • medeekM
                          medeek
                          Version 2.2.6 - 08.01.2021
                          • Fixed a minor bug with tee intersections for all wall types.
                          design.medeek.com
                          • medeekM
                            medeek
                            Version 2.2.7 - 08.03.2021
                            • Added insulation to the Medeek Estimator for rectangular walls.
                            http://design.medeek.com/resources/wallplugin/images2/wall_su567_800.jpg
                            design.medeek.com
                            • medeekM
                              medeek
                              Version 2.2.8 - 08.04.2021
                              • Fixed a bug with blocking and insulation for portal frame garage doors within rectangular walls.
                              http://design.medeek.com/resources/wallplugin/images2/wall_su568_800.jpg
                              Portal frames add a good deal of complexity to the framing, blocking and insulation. Some of the details were not completely worked out previously. I think I now have most if not all of these issues addressed.
                              I also may need to spend some additional time on the holdown placement when multiple portal frames are adjacent to each other like in the example shown.
                              design.medeek.com
                              • medeekM
                                medeek
                                mdkBIM Tutorial 1: Modeling a Two Car Detached Garage (41:14 min.)
                                A few issues popped out during the making of this tutorial:
                                1.) Portal frame holdown placement, custom deletion and redundancy, feedback required.
                                2.) Wall copy tool did not copy the insulation option setting.
                                3.) The insulation algorithm seems inconsistent when dealing with tee intersections.
                                View garage model here:
                                3D Warehouse
                                (3dwarehouse.sketchup.com)
                                design.medeek.com
                                • medeekM
                                  medeek
                                  Version 2.2.9 - 08.06.2021
                                  • Fixed a bug with framing, blocking and insulation for tee intersections for all wall types.
                                  • Fixed a minor bug with six panel doors when the door vertical offset is a non-zero value.
                                  http://design.medeek.com/resources/wallplugin/images2/wall_su569_800.jpg
                                  This resolves the issue #3 noted in the recent mdkBIM tutorial. I would highly recommend installing this latest update.
                                  design.medeek.com
                                  • medeekM
                                    medeek
                                    Version 2.3.0 - 08.08.2021
                                    • Fixed a bug with wall presets for rectangular walls.
                                    !!!! CRITICAL BUG FIX !!!!
                                    If you are using wall presets with rectangular walls and have upgraded to Version 2.2.4 or later then you will want to upgrade to this latest version which rectifies a bug introduced in Version 2.2.4.
                                    design.medeek.com
                                    • medeekM
                                      medeek
                                      Version 2.3.1 - 08.09.2021
                                      • Added a vertical offset parameter for cladding material for gable walls.
                                      • Added a vertical offset parameter for "Log" and "Shiplap" cladding materials for gable walls.
                                      • Added a horizontal offset parameter for cladding material for gable walls.
                                      • Added a horizontal offset parameter for "Board and Batten" and "Metal" 3D cladding materials for gable walls.
                                      design.medeek.com
                                      • medeekM
                                        medeek
                                        Version 2.3.2 - 08.12.2021
                                        • Added a vertical offset parameter for cladding material for shed and hip walls.
                                        • Added a vertical offset parameter for "Log" and "Shiplap" cladding materials for shed and hip walls.
                                        • Added a horizontal offset parameter for cladding material for shed and hip walls.
                                        • Added a horizontal offset parameter for "Board and Batten" and "Metal" 3D cladding materials for shed and hip walls.
                                        Some rather tedious code updates but important that these wall types have all the options of the rectangular wall type.
                                        design.medeek.com
                                        • medeekM
                                          medeek
                                          Version 2.3.3 - 08.17.2021
                                          • Fixed a minor bug with sliding glass doors when the door vertical offset is a non-zero value.
                                          http://design.medeek.com/resources/wallplugin/images2/wall_su570_800.jpg
                                          design.medeek.com
                                          • medeekM
                                            medeek
                                            Version 2.3.4 - 08.18.2021
                                            • Added logic into the add and edit menus to prevent users from using single and double quotes in beam and header names.
                                            • Added logic into all HTML menus to prevent users from using vertical bars in beam and header names and within preset names.
                                            design.medeek.com
                                            • 54
                                            • 55
                                            • 56
                                            • 57
                                            • 58
                                            • 80
                                            • 81
                                            • 56 / 81
