Red and blue mixed around ...
I'm using SU make 2015
The colours red and blue are transposed.
Vertical axis is red
Red axis is blue
Green (unless it has red or blue in it) is unaffected)
Materials that have red and/or blue in them are wrongPC version
It still works - but everything looks wrong
Are you using a custom startup template SketchUp file?
No. Just noticed it one day when I was using the software.
Right click on an axis line and choose Reset.
As much as I was hoping that would work, alas it did not.
The option to reset when R click on axis, 'reset' was greyed out.Also, it's not just the axis, its also the colour palette. The colours when in the palette appear correct, yet when they are applied, or viewed in an existing su file, they are red blue transposed (red is blue, blue is red, green is unaffected, rgb that is)
Thanks for your efforts thus far
I have no idea what is causing this
Hasn't happened in any other software
What graphics card? Since this just seemed to start one day, you should look at what has changed. You say you are using SketchUp 2015 Make and your profile says you are using 2017 Make. Which is it? Either way, they haven't changed for years. Maybe you need to update the graphics drivers. Go to the manufacturer's site and get their latest drivers to install. Then reboot the system and see if that fixed it.
After reading a similar post in another forum, I looked at the open GL settings, turned off fast feedback and ok, then went back in and turned it on again.
And the colour went back to normal.
Something about true colourThankyou for your efforts
