    [Plugin] Material Browser - v1.1.1 - 15 Nov 2025
    51 Posts 10 Posters 35.6k Views 10 Watching
    • samuel_tS Offline
      samuel_t
      What's new in 1.0.3 version?
      • One can filter materials by type (Brick, Wood, etc). Technically, a materials types dictionary is used and you can contribute to its development.
      • One can choose to display only model materials.
      • You don't need anymore to restart SketchUp after you've defined a custom SKM folder.
      • When materials source are displayed: a click on Texture Haven logo opens texture source page in external Web browser. Download a normal map (for example) becomes easier.
      • Plugin has been translated to french.
      Download latest Material Browser plugin from the SketchUcation PluginStore.
      • cmeedC Offline
        cmeed
        I downloaded again - the latest update from the SketchUcation PluginStore and this time its worked. It definitely didn't come in the first time. I'm up and running now ! whoop whoop
        So I've opened it for 30 second and i' already asking about features!!!
        Could we have the ability to group materials together in folders and see these folders in material browser? this was a great help in flex tools
        Material Question
        on a side note - do you know why i can't have more than 1 material with the same settings but different names? so
        Floor_Black (0,0,0)
        Curtain_Black(0,0,0)
        or how different these colours need to be to recognised as different from each other....
        So,
        Floor_Black (0,5,0)
        • samuel_tS Offline
          samuel_t
          I don't know yet if a feature of this kind will be implemented.
          @cmeed said:
          Material Question
          Floor_Black (0,0,0)
          So,
          Floor_Black (0,5,0)
          This looks like a SketchUp bug or limitation... You should create a topic about this issue.
          • samuel_tS Offline
            samuel_t
            What's new in 1.0.4 version?
            • Texture Haven materials catalog has been extended to 198 entries.
            • Downloaded textures are cached during 1 month... This accelerates re-import of concerned materials and saves bandwidth.
            • samuel_tS Offline
              samuel_t
              1.0.5 version brings a new materials source: CC0 Textures.
              • E Offline
                EvilBoris
                That's a really great plugin, I had some trouble getting it to work also: I had to disable a bunch of plugins for it to work, so there is a conflict somewhere.
                For reference, here is the error I was getting
                Error Loading File C:/Users/adam.fairclough/AppData/Roaming/SketchUp/SketchUp 2021/SketchUp/Plugins/material_browser/load.rb
                Error: #<TypeError: superclass mismatch for class StreamableStream>
                C:/Users/adam.fairclough/AppData/Roaming/SketchUp/SketchUp 2021/SketchUp/Plugins/material_browser/Libraries/zip/streamable_stream.rb:2:in <module:Zip>' C:/Users/adam.fairclough/AppData/Roaming/SketchUp/SketchUp 2021/SketchUp/Plugins/material_browser/Libraries/zip/streamable_stream.rb:1:in <top (required)>'
                C:/Program Files/SketchUp/SketchUp 2021/Tools/RubyStdLib/rubygems/core_ext/kernel_require.rb:92:in require' C:/Program Files/SketchUp/SketchUp 2021/Tools/RubyStdLib/rubygems/core_ext/kernel_require.rb:92:in require'
                C:/Users/adam.fairclough/AppData/Roaming/SketchUp/SketchUp 2021/SketchUp/Plugins/material_browser/Libraries/zip.rb:30:in <top (required)>' C:/Program Files/SketchUp/SketchUp 2021/Tools/RubyStdLib/rubygems/core_ext/kernel_require.rb:92:in require'
                C:/Program Files/SketchUp/SketchUp 2021/Tools/RubyStdLib/rubygems/core_ext/kernel_require.rb:92:in require' C:/Users/adam.fairclough/AppData/Roaming/SketchUp/SketchUp 2021/SketchUp/Plugins/material_browser/utils.rb:27:in <top (required)>'
                C:/Program Files/SketchUp/SketchUp 2021/Tools/RubyStdLib/rubygems/core_ext/kernel_require.rb:72:in require' C:/Program Files/SketchUp/SketchUp 2021/Tools/RubyStdLib/rubygems/core_ext/kernel_require.rb:72:in require'
                C:/Users/adam.fairclough/AppData/Roaming/SketchUp/SketchUp 2021/SketchUp/Plugins/material_browser/model.rb:26:in <top (required)>' C:/Program Files/SketchUp/SketchUp 2021/Tools/RubyStdLib/rubygems/core_ext/kernel_require.rb:72:in require'
                C:/Program Files/SketchUp/SketchUp 2021/Tools/RubyStdLib/rubygems/core_ext/kernel_require.rb:72:in require' C:/Users/adam.fairclough/AppData/Roaming/SketchUp/SketchUp 2021/SketchUp/Plugins/material_browser/materials_observer.rb:24:in <top (required)>'
                C:/Users/adam.fairclough/AppData/Roaming/SketchUp/SketchUp 2021/SketchUp/Plugins/material_browser/app_observer.rb:24:in <top (required)>' C:/Program Files/SketchUp/SketchUp 2021/Tools/RubyStdLib/rubygems/core_ext/kernel_require.rb:72:in require'
                C:/Program Files/SketchUp/SketchUp 2021/Tools/RubyStdLib/rubygems/core_ext/kernel_require.rb:72:in require' C:/Users/adam.fairclough/AppData/Roaming/SketchUp/SketchUp 2021/SketchUp/Plugins/material_browser/load.rb:25:in <top (required)>'
                • Z Offline
                  ZoranKP
                  HI. I just installed this and only get errors when SU starts.
                  A lot of errors all to do with this: 2021/Tools/RubyStdLib/rubygems/core_ext/kernel_require.rb:72:in `require'
                  I installed a few of your other plugins, all working fine.
                  Anything you can suggest to fix this?
                  Z
                  • Z Offline
                    ZoranKP
                    Why are there no replies to posts here? The extension does not work as I posed above.
                      masloprojekt
                      Hello,
                      Can You share a list of plugins you had to disable? I got the same errors. I would love to use this plugin, searching materials by name is so obvious it should be implemented in native tools of SketchUp, and this add on do so much more!
                      Thank You.
                      Maciej.
                      my error log
                      Error Loading File C:/Users/maslo/AppData/Roaming/SketchUp/SketchUp 2021/SketchUp/Plugins/material_browser/load.rb
                      C:/Users/maslo/AppData/Roaming/SketchUp/SketchUp 2021/SketchUp/Plugins/material_browser/Libraries/zip/streamable_stream.rb:2:in <module:Zip>' C:/Users/maslo/AppData/Roaming/SketchUp/SketchUp 2021/SketchUp/Plugins/material_browser/Libraries/zip/streamable_stream.rb:1:in <top (required)>'
                      C:/Users/maslo/AppData/Roaming/SketchUp/SketchUp 2021/SketchUp/Plugins/material_browser/Libraries/zip.rb:30:in <top (required)>' C:/Program Files/SketchUp/SketchUp 2021/Tools/RubyStdLib/rubygems/core_ext/kernel_require.rb:92:in require'
                      C:/Program Files/SketchUp/SketchUp 2021/Tools/RubyStdLib/rubygems/core_ext/kernel_require.rb:92:in require' C:/Users/maslo/AppData/Roaming/SketchUp/SketchUp 2021/SketchUp/Plugins/material_browser/utils.rb:27:in <top (required)>'
                      C:/Users/maslo/AppData/Roaming/SketchUp/SketchUp 2021/SketchUp/Plugins/material_browser/model.rb:26:in <top (required)>' C:/Program Files/SketchUp/SketchUp 2021/Tools/RubyStdLib/rubygems/core_ext/kernel_require.rb:72:in require'
                      C:/Program Files/SketchUp/SketchUp 2021/Tools/RubyStdLib/rubygems/core_ext/kernel_require.rb:72:in require' C:/Users/maslo/AppData/Roaming/SketchUp/SketchUp 2021/SketchUp/Plugins/material_browser/materials_observer.rb:24:in <top (required)>'
                      C:/Users/maslo/AppData/Roaming/SketchUp/SketchUp 2021/SketchUp/Plugins/material_browser/app_observer.rb:24:in <top (required)>' C:/Program Files/SketchUp/SketchUp 2021/Tools/RubyStdLib/rubygems/core_ext/kernel_require.rb:72:in require'
                      C:/Program Files/SketchUp/SketchUp 2021/Tools/RubyStdLib/rubygems/core_ext/kernel_require.rb:72:in require' C:/Users/maslo/AppData/Roaming/SketchUp/SketchUp 2021/SketchUp/Plugins/material_browser/load.rb:25:in <top (required)>'
                      • samuel_tS Offline
                        samuel_t
                        Hi everyone!
                        Sorry, I wasn't subscribed to current topic. I don't have conflicts on my computer. Try to disable all other plugins and re-enable them one by one. Yes I know it's a tedious task but I see no other way...
                        • samuel_tS Offline
                          samuel_t
                          I just published 1.0.6 version. It should fix "TypeError: superclass mismatch for class StreamableStream" issue. Please upgrade if you have this issue. Then, tell me if it works.
                          • samuel_tS Offline
                            samuel_t
                            A SketchUp 2021 user reported that Material Browser v1.0.6 conflicts with SketchUcation ExtensionStore. You can't enable these plugins at same time because they use the same Zip library.
                            I'm looking for a solution...
                            • samuel_tS Offline
                              samuel_t
                              1.0.7 version fixes "TypeError: superclass mismatch for class StreamableStream" issue. Material Browser plugin is now compatible with SketchUcation ExtensionStore plugin.
                              • samuel_tS Offline
                                samuel_t
                                1.0.8 version fixes "special chars in material name" issue. For example: a material named "<auto>1" doesn't cause anymore a missing thumbnail.
                                • judedouchJ Offline
                                  judedouch
                                  Thank you for your two above, prompt actions. It’s greatly appreciated.
                                  judedouch
                                  • samuel_tS Offline
                                    samuel_t
                                    1.0.9 version improves user experience. You don't need anymore to reopen Material Browser UI after you've checked "Display only model materials", etc.
                                    • E Offline
                                      EvilBoris
                                      Amazing!
                                      Thanks for letting me know you fixed the extension store issue 😄 😄
                                        Something weird is going on with your extension for some users...
                                        It's reported over at SketchUp.com
                                        It seems to be copying/moving its zip.rb and zip folder from your ../Libraries/ subfolder into the Plugin folder.
                                        First off it looked like SCF toolset doing this, as it has a similar Rubyzip set up, bt it seems to narrow down to you !
                                        Ideas ??
                                        https://forums.sketchup.com/t/what-is-zip-in-extension-manager-can-i-uninstall-it/172133
                                        • samuel_tS Offline
                                          samuel_t
                                          My bad. Old versions of material_browser.rbz file include Rubyzip library at root… That’s why there’s a zip.rb file and a zip folder at root of Plugins folder. You can safely uninstall the “zip” library with native Extension Manager. Then, if you want to continue to use Material Browser plugin: upgrade it. New versions of Material Browser plugin include Rubyzip library in a proper way.
                                          Source: https://forums.sketchup.com/t/what-is-zip-in-extension-manager-can-i-uninstall-it/172133/29
                                            Thanks for the explanation and the fix...
                                            • 1 / 3
