    [Plugin] LordOfTheToolbars - v4.0a - 22 Sep 26
    511 Posts 99 Posters 523.1k Views 97 Watching
    • fredo6F
      @rv1974 said:
      First problem: at some I've lost this 'vignette stripe'. I tried everything: reset factory,
      uninstall-reinstall plugin+fredolib- nothing. BTW no problems in ruby console. Trying to get it via shortcut flashes red sand clock for a fraction of second. Any idea how to get it back ❓
      P.S. I don't know if its related, single time only the toolbars didn't got back after 'clean mode'- I just restarted the program.
      There is a menu entry for toggling the visibility of the Vignette Stripe. Otherwise, it might be off screen, in which case I don't have an elegant solution because the Vignette Stripe remembers its position. Possibily, you may have to go to the folder
      C:\Users<your username>\AppData\Local\LIBFREDO6_DATA_Dir\Vaults
      In this folder there are files with name LibFredo6_HtmlDialog_SU2020_RT125.dat, one for each version of Sketchup and Scale factor (above SU2020 and scale 1.25). This is where the configuration of each dialog is stored. If you delete the file, then you reset the position of ALL dialogs, including the vignette stripe.
      Do you have multiple screen?
      F 1 Reply Last reply
        rv1974
        yes,dual screen (see p.1 2 posts above). I'll play with vaults, thanks for suggestion!
        • fredo6F
          NEW RELEASE: LordOfTheToolbars v1.3c - 03 Jun 21
          Requirements
          • LibFredo6: v11.8a or above
          LordOfTheToolbars 1.3c is a maintenance release with a first batch of bug fixing and adjustments, especially
          • Menu for Vignette Stripe reset position in case it is lost
          • Keep palettes within Sketchup window horizontally when dropped down
          Home Page of LordOfTheToolbars for information and Download.
          Main post of this LordOfTheToolbars thread.
          • K
            kakashi66
            Another piece of quality coding by Fredo. I'm looking forward to trying it especially if I can put a group of icons on might right hand screen.
            TBH I'm surprised as sketchup developed, no one thought about control toolbars like the tray idea. If I could organise plugins by maker in a tray I'd be a happy camper.
              rv1974
              I thought about "Fredo tray" too. It could include standard elements like tags, entity info etc plus new ones - vignette,LOTT toolbar,history and optionally command search (I still would prefer it glued to cursor though).
              Edit: BTW the update didn't bring vignette back, I solved it by deletig volts files- thank you for solution!
                rv1974
                I'd prefer to see one-line (per command) search results instead of two. When command name is too popular user gets a mile-long results list which one line design could cut in half. Plus it's way easier to find the needed command.
                P.S. Could history color setting by applied to command search as well? It'd aestetically unify plugin elements (and kill this nasty white where its possible)
                • fredo6F
                  Each item is on a single line. But if the text is too long for the width of the dialog, it wraps to the next line
                    makidoben
                    Usage: Free for the time being
                    What price would we be looking at if this plugin is going to be a cost after Expiration on: 31 Jul 2021... or would it still be free with a upgrade.
                      rv1974
                      Indeed, I squeezed the widget too much. thank you
                      • fredo6F
                        31 Jul 22 is just a technical date. I now try to put a limit to make sure users migrates to the latest versions, which ease the maintenance for me.
                        I have not decided whether and when LOTT would become a paid plugin. In any case, it should no more than $7 for a perpetual license, 3 seats, with a 30 days free trial period.
                          rv1974
                          Fredo please, if possible, implementtoolbars dropping out in upward direction. I'd like to keep the vignette at the bottom thus I need the custom toolbars to pop-UP upward. For bigger screens its better solution. Thank you.
                          • P
                            PedroE
                            Hello, I would like to make a suggestion and that is that each vignette could have a keyboard shortcut to have quick access to each vignette instead of cycling them, and if it were possible that you appear under the mouse like wacom toolbars. Thanks for sharing, you are a machine πŸ˜„
                            • P
                              PedroE
                              Solid tools are missed
                                abcgsketch
                                I would say 7$ is much more than a generous offer for such a necessary and powerful plugin!
                                I would be happy to contribute.
                                  rv1974
                                  Some tiny suggestions: could the upper part get ditched? Such a large display area is wasted. Separators.. they are huge. Is there possibility to clamp them?
                                    rv1974
                                    I have a feeling that with LOTT onboard, SU opening times SIGNIFICANTLY improved. πŸ‘
                                    Do you confirm as well?
                                      RLGL
                                      Ver 1.3e residing in the SU release 21.1.279 dated June 8 on Win 10
                                      First:
                                      As previously mentioned Solid Tools is MIA.
                                      Second:
                                      Entity Information panel does not open from my Custom tray, for some strange reason it pops out in the default tray (not used). The other panels (components etc) open from my custom panels.
                                        RLGL
                                        I have noticed the Solid Inspector2 is listed under ThomThom.
                                        ThomThom's Solid inspector is MIA as is Material tools.
                                        • fredo6F
                                          Can you check in the Extension Manager what is the 'Creator'.
                                          This is what LOTT takes for listing.
                                          • B
                                            barrieJ
                                            Is LOTT compatible with Mac OSX Mojave (10.14.6)? I have installed it several times using SU extension manager and sketchUcation plugin manager. After restarting SU a message says that LOTT was not installed although both managers indicated that it was installed and enabled but it didn't show up in any of SU menu's.
                                            • 25
                                            • 26
                                            • 2 / 26
